ecm-Vottero
Using "calculate" in Acrobat Form to display document metadata (Author, etc.)
Apr 2, 2012 8:49 AM
Tags: #javascript #acrobat-forms #calculate #acrobat_10_pro
Can someone assist with a javascript that will retrieve the document "Subject" or "author" so that I can use that data on an acrobat form?  (I am creating a form that will then be inserted as the first page in an existin adobe document and I want the form to display details about that document.
  • George Johnson
    Aug 11, 2002
    Apr 2, 2012 9:12 AM   in reply to ecm-Vottero
    You probably don't want to use the calculate event, as it is triggered only when a field value changes. You can place someting like the following in the initial page's Page Open event:
    getField("SUBJECT").value = info.Subject;
    For more information, see: http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/JS_API_A croJS.88.396.html
    Apr 2, 2012 9:20 AM   in reply to ecm-Vottero
    The document title and author are contained in the document object's 'info' property.
    // display the info items in the JavaScript console.
    for (var i in this.info)
    console.println(i + ": "+ this.info[i]);
    There is also a 'metadata' property for the document object, but this is much harder to process.
