stickynotes3
Sticky notes in Acrobat Reader x
Mar 30, 2012 3:26 PM
Unable to activate stcky notes to be able to use in Acrobat Reader X...
What needs to be done to make this happen?
    Mar 30, 2012 5:57 PM   in reply to stickynotes3
    Have you tried to activate Reader rights in Acrobat?
    Apr 2, 2012 10:51 AM   in reply to stickynotes3
    Is this happening for all you PDFs? When you open a PDF, do you see a lock icon in the Navigation Pane on the left hand side? If so, your PDFs have been secured to disallow commenting.
    Apr 9, 2012 3:53 AM   in reply to stickynotes3
    For Reader X, sticky notes and highlighter type of annotations are by default available and can be added on any pdf unless that pdf is secured (or has some special permissions due to which commenting has been disabled.). If you wish to enable all the types of annotations then you need to do the following. Open the pdf in Acrobat (any version). Click Save As->Reader Extended Pdf->Enable Commenting and Measuring.
    Hope that helps.
    Abhilasha
