I am unable to install FB 4.5 on my laptop. Here is the error message :
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 3 error(s), 3 warning(s)
WARNING: DS013: Payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin 10.1.52.14 is already installed and the session payload {46DF1D41-88FD-448c-BAC5-6FDA31247378} Adobe Flash Player 10 Plugin 10.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX 10.1.52.14 is already installed and the session payload {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp 1.0.0.0 is already installed and the session payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 has no upgrade/conflict relationship with it.
ERROR: DS013: Verifying payload integrity : Failed with code 1
----------- Payload: {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 -----------
FATAL: DS003: Cannot extract 'C:\Users\MSH\Desktop\Adobe Flash Builder 4.5 Installer\Adobe Flash Builder 4.5\payloads\AdobeFlashBuilder-mul\Assets1_1.zip' to 'C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{650C9D09-D5BD-4532-8BEE-01DBC1DF5537}'. Error: Error 0
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Flash Builder 4.5: Install failed
Help is appreciated..
Thanks and Regards,
MSH
worked fine for me. try rebooting the machine and trying agin
After around 7-8 attempts, finally installed.. I had to uninstall Flash Player 10 ActiveX and Plugin manually.... then only it installed
Trying to install FB 4.5 - comes up with this error on my machine - anyone have any concrete ideas on how to overcome this...
I've tried rebooting, removing activex plugins etc but of no help....
WARNING: DW031: Payload:{650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 has been updated and has been selected for repair. The patch {CEAC4FFA-E7DE-4434-890A-F0AC7792DE5E} Adobe Flash Builder 4.5_4.5.1_AdobeFlashBuilder-mul 4.5.1.0 will be uninstalled now.
----------- Payload: {551D0A52-5E4A-4898-9FFF-FEAA5E89585A} Adobe Flash Player 10 ActiveX 10.0.0.0 -----------
ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\DOCUME~1\nanunh\LOCALS~1\Temp\InstallAX.exe, command: -install activex -msi
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\DOCUME~1\nanunh\LOCALS~1\Temp\InstallAX.exe, command: -install activex -msi
ERROR: DW050: - Adobe Flash Player 10 ActiveX: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 6 - Silent workflow completed with errors.
[ 1460] Mon Aug 15 17:52:20 2011 INFO
In Program Files for 'Adobe' directory give full access control permission and try reinstalling. It worked in another situation at my workplace.
Link on how to edit the permission, in case if you need:
MSH
Hey,
i know it's been a while since your last post but i'm facing the same issue now, i executed the .exe file as an adiminstrator but i still got the same error you mentioned up there!
anybody can help me out with that?
thx!
Mostafa.
