Can a ppt be imported to use with the quiz creator, so that I can capture math symbols?*
1. Have PowerPoint and Captivate open.
2. In PowerPoint, click the Slideshow view - it takes over the whole screen.
3. Toggle to Captivate. For best results you should be working with two monitors.
4. Click the red Record button.
5. Make your choices in this screen that opens - select PowerPoint Slide show as what you want to capture.
6. You probably have other selections, too. Make PowerPoint snap to the recording area you have set.
7. Then, after clicking the red Record button in the Captivate window, the PowerPoint slide show will jump to the size that you have indicated in Captivate to be your recording size. A red border will display around the PowerPoint slide, which lets you know this is the area that is being recorded.
8. Click the mouse or Enter to advance through the PowerPoint slide show.
9. Click End when you are ready to quit recording.
10. Toggle to the PowerPoint Slide show and press ESC to return PowerPoint to the edit mode.
11. In Captivate, navigate to the slide that is the first PowerPoint that you want as a background. In the middle of the screen, right-click and select "Copy Background.
12. Navigate to the question slide where you want this background. Right-click on the slide and Paste as background.
Then, move your question objects on the question slide around to fit the background.
Hope this helps.
scsocha <forums@adobe.com> wrote:
scsocha http://forums.adobe.com/people/scsocha created the discussion
"Re: Powerpoint and quizzes?"
To view the discussion, visit: http://forums.adobe.com/message/4308793#4308793
Do not just copy the PowerPoint slide and paste it into Captivate. You'll need to capture it in Captivate.
Hope this helps.
To view the discussion, visit: http://forums.adobe.com/message/4308962#4308962
You could also import the PPT slide into captivate.
File > New Project > Project from MS Powerpoint
Import the slide you want into the new project. Select the slide and copy it. Go to the Master Slide panel, paste. Create your Question Slides, select the master slide in the slide properties.
