I need to know what the aspect ratio of an image is so i can apply css properties to it depending on it being square, landscape, or portrait. is there a propery that will return this information?
so?:
local function whatOrientation ( imageID )
local variableName = photo:getRawMetadata('croppedDimensions')
local outPutName = nil
if variableName.width > variableName.height then
outPutName = "landscape"
else
outPutName = "portrait"
end
if variableName.width == variableName.height then
outPutName = "square"
end
return outPutName
end
then use it in the galleryinfo.lrweb somewhow?
I am beyond new to using lua, and have a 15 year ago background in C that was never continued so I am way out of practice.
my goal is to set each thumbnail generated from the web gallery with a class selector for my css styles. I think what i am looking to do would be best setup in javascript but i would love if lightroom (lua in this case) can take some of the load off. so in the end i might have a gallery with 20 images, and 20 thumbnails, each thumbnail depending on its orientation I would set the selector when the gallery is generated. Any theory where to start or where I should be calling this function.
thanks again for responding,
Ryan
You probably want to have outputName set to something valid, unless the caller can handle nil. LrPhoto:getRawMetadata() can return nil, as well, so you might want to check for nil before trying to use it.
Also, note that LrPhoto:getRawMetadata() will need to be called from within an LrTask, either one you create yourself, or one provided by the SDK context you are running this in.
