I recently upgarded my flash player to the most recent version. I am using Windows XP Home addition 32-bit system. Now when when the flash content tries to run I receve an Error 2048 and "failed to load the resource" and "can not access the resource file". It apparently is not an installation proble. Is there something on my system's security settings that is keeping the flash content from working? How do I clear that up?
Hi Chris,
Thank you for your response. A little delay in getting in a reply. My 1st time in the forums. I would appreciate any help that you can provide.
In answer to your question. There are 4 URLs that I am concerned with currently. All are at the same root URL. These are flash video's that I wish to send and use with people. I was able to access them with no problem until I upgraded my flash player. I don't think it is a flash player problem judging from the number of users getting this same error code, but I don't know. Most indications are that somehow the content on the following URLs is being blocked. Can you help identify what is blocking the resource download? The sites that do not work are:
1. www.onepennybillionaire.com/biddollar/tz.aspx
2. www.yougetpaidtoadvertise.com/biddollar/main.aspx
3. www.got20seconds.com/biddollar/cst.aspx
4. www.yougetpaidtoadvertise.com/biddollar/webinar.aspx
Any ideas are appreciated.
Thank you for your help
Hello Chris,
Thank you for your reply. I think I have identified the problem. I am not surprised that they worked for you. I did some further testing. The missing ingredient is that not only did I upgrade my flash, I ALSO started using a wireless hotspot operating at 4G speeds. The limiting factor for downloading the content was the speed of the wirelesss adapter card installed in my computer that conected to the hotspot. The adapter is maxed out at 54mbps which is not fast enough to support the resource download timeout limit producing error 2048. Solution - upgrade the wireless adapter in my PC to an Intel Centrino device with 450mbps capability. I'll confirm its success after the upgrade.
Hi Chris,
This is regarding error #2048 and #2032.One of my user got error #2032 when he tried to access the application I have made.
To understand the error i compiled a simple flex code and saved the swf file on his desktop and then tried opening it through internet explorer but i received error #2048 in IE.
I am not able to understand the cause of the error.the application is working fine everywhere else.I need to fix it at the earliest.
The sample code which gave the error# 2048 is:
<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:flexiframe="http://code.google.com/p/flex-iframe/" layout="vertical" verticalAlign="top" xmlns:comp="components.*" xmlns:local="*" horizontalAlign="center" paddingTop="2" paddingLeft="2" paddingBottom="2" paddingRight="2" cornerRadius="1" alpha="1.0" borderStyle="solid" width="100%" creationComplete="loadData();"> <mx:Script> <![CDATA[ import flash.events.MouseEvent; import flash.net.navigateToURL; import flash.sampler.NewObjectSample; import mx.collections.ArrayCollection; import mx.collections.Sort; import mx.collections.SortField; import mx.controls.*; import mx.controls.DataGrid; import mx.controls.List; import mx.events.*; import mx.events.CloseEvent; import mx.events.DataGridEvent; import mx.events.IndexChangedEvent; import mx.events.ItemClickEvent; import mx.managers.PopUpManager; import mx.rpc.events.FaultEvent; import mx.rpc.events.ResultEvent; import mx.utils.ArrayUtil; import mx.utils.StringUtil; public function loadData():void { Alert.show("it is in here"); } ]]> </mx:Script> <mx:VBox width="100%" height="100%" backgroundColor="#f8f8f8" horizontalAlign="center" paddingLeft="5" paddingRight="5" paddingBottom="10">
<mx:Label width="100%" id="Title" textAlign="center" fontFamily="GE Inspira" fontSize="20" color="#666699" fontWeight="bold" text="Hello"></mx:Label>
</mx:VBox>
</mx:Application>
Sneha
Hi Sneha,
Could you please open a new bug report on this over at bugbase.adobe.com? Please post back with the URL so that others affected can add their comments and votes.
You might also want to post on the Flash Professional forums? This forum is primarily for end users, the Pro forums will get you in touch with a wider developer audience.
Chris
Most of the peoples always upgrade with new technologies. You are unable to load your source file on your flash player this means your MOV file is corrupted and displaying you an error message 2048. Even I was in identical problem where was unable to run contents of flash on my flash player. Then I used good repair software which helped me to repair error message 2048. Now-a-days there are many repair software’s available in market reviewed by industry experts. One such software is Repair MOV file software. First you can make use of its free version and later if satisfied with results then can go for full form.
Thanks![]()
shanky
