I am getting really bad results processing Nikon D800 files in LR4. Noise and CA are prevalent even at very low ISO and the images just aren't sharp. I thought due to the high resolution of this camera that the files may need a little more sharpening, but when I do that the noise gets out of control. I thought it was a camera issue and contacted Nikon. They basically wouldn't even talk to me unless I was using their Capture NX software so I downloaded it and ran comparisons. The difference was like night and day - the files looked great in Capture NX. I have run all my previous Nikon cameras, D200, D300, D2X, D700 through LR up to version 3 and have had no issues till this new camera. I really don't want to shift my workflow over to Nikons software at this point. I realize LR 4 and compatibility for the new D800 hit at the same time and am just hoping they have not had enough time to work on this particular camera suppport but am wondering what others with the D800 are seeing.
Sorry, I have been out of town. My Sharpness settings are pretty low about level 30-40 at.08 and no NR. I really think it might be the camera, but Nikon Capture is night much better on the file. I don't know if you can see it in this comparison of ACR and Capture NX after sizing and jpegging, maybe in the hair but there is a distinct difference.
Dorin Nicolaescu-Musteață wrote:
I played with a studio shot from Imaging Resource and it looked perfectly fine. Samples at dpreview look good too (and the do use ACR, afaik).
What are your sharpening and NR settings?
Here is an LR 4.1 and Capture NX comparison. You can't really set the same sharpness setting since the two programs have different controls . The settings in LR 4.i are 40, 0.8 and 35 (detail) I also gave it a little sharpening in PS as it seemed way softer than the capture one. But when I run the sharpness up in LR 4 the noise gets crazy even at ISO 100.
I'm unable to download Nikon D800 pictures onto LR4 too ... I've seen hints that Adobe is preparing a fix but nothing definite. The D800 is one of the world's top performing cameras and this is very disappointing. It would be reassuring if folk at Adobe could spare a moment to respond directly to these concerns.
Also one of the newest. As you can see above people are using Lightroo for their D800 files so you can too!
Yes, I can see from the messages above that "some" people are can download Nikon D800 files onto Lightoon 4.
However, not "everyone". In my case, my attempts to download are greeted with a message that LR4 does not recognise the D800 files. It is possible, I wonder, the Nikon video files or the Nikon live view files are causing this non-recognition by LR4.
In my experience Nikon Capture NX2 is not an option. It is "clunky" by comparison with LR2 and amazingly does not cater for video files created by Nikon camers.
Again, I ask if someone at Adobe can spare a moment to respond to these concerns.
yes I notice the contrast difference after I ran out the files. I didn't do anything to exposure or contrast settings in either file in Lightroom or Capture NX but I forgot that in Capture NX picture controls are recognized on RAW files so it probably picked up something there. There is some apparent sharpening by the increase in black but I don't think that it is that different that the sharpness difference can't be seen. Increasing the sharpness in LR4 to the point where it mimics Capture NX just makes the noise level go crazy. I have just never had an issue with sharpening and noise increase in LR on any previous cameras. The D700 files always looked great.
These seem equally sharp to me.
That said, the NX version has more sharpening applied and also has darker shadows, which gives higher contrast and more perceived sharpness as a result.
That depends on what you're comparing. If you're looking at the per-pixel level (e.g., 100%), sure the images from the D800 may appear to be more sensitive to sharpening -- that's because each pixel is physically smaller (compared to the D700) and thus has correspondingly higher noise level. Sharpening in Lightroom works at the pixel level, so it is expected that you'll need to be more careful with applying Masking and luminance noise reduction with the higher-res D800 files.
Those samples are at 100%. There is no noise reduction used in any of them but I can't find a combination of settings that will sharpen them adequetly and keep the noise in check. Capture NX doesn't seem to have that problem, but I hate to switch workflows after using LR for som many years.
What level of masking are you using? If your masking is too low, then it might explain why noise is being sharpened (and, thus, introducing even more noise). Not sure if you mentioned the masking setting yet, but I didn't see anything about it while browsing the thread.
