Spry Menubar not operating in Safari
Apr 2, 2012 3:13 AM
Tags: none (add) #cs5 #safari #dreamweaver #spry #menubarI am using a Spry vertical menubar in Dreamweaver CS5 and it shows fine in IE and Firefox but it does not show in Safari.
This is my SpryMenuBar.js
// SpryMenuBar.js - version 0.13 - Spry Pre-Release 1.6.1
SpryMenuBar.js
This file handles the JavaScript for Spry Menu Bar. You should have no need
to edit this file. Some highlights of the MenuBar object is that timers are
used to keep submenus from showing up until the user has hovered over the parent
menu item for some time, as well as a timer for when they leave a submenu to keep
showing that submenu until the timer fires.
(function() { // BeginSpryComponent
if (typeof Spry == "undefined") window.Spry = {}; if (!Spry.Widget) Spry.Widget = {};
Spry.BrowserSniff = function()
var b = navigator.appName.toString();
var up = navigator.platform.toString();
var ua = navigator.userAgent.toString();
this.mozilla = this.ie = this.opera = this.safari = false;
var re_opera = /Opera.([0-9\.]*)/i;
var re_msie = /MSIE.([0-9\.]*)/i;
var re_gecko = /gecko/i;
var re_safari = /(applewebkit|safari)\/([\d\.]*)/i;
var r = false;
if ( (r = ua.match(re_opera))) {
this.opera = true;
this.version = parseFloat(r[1]);
} else if ( (r = ua.match(re_msie))) {
this.ie = true;
} else if ( (r = ua.match(re_safari))) {
this.safari = true;
this.version = parseFloat(r[2]);
} else if (ua.match(re_gecko)) {
var re_gecko_version = /rv:\s*([0-9\.]+)/i;
r = ua.match(re_gecko_version);
this.mozilla = true;
this.windows = this.mac = this.linux = false;
this.Platform = ua.match(/windows/i) ? "windows" :
(ua.match(/linux/i) ? "linux" :
(ua.match(/mac/i) ? "mac" :
ua.match(/unix/i)? "unix" : "unknown"));
this[this.Platform] = true;
this.v = this.version;
if (this.safari && this.mac && this.mozilla) {
this.mozilla = false;
Spry.is = new Spry.BrowserSniff();
// Constructor for Menu Bar
// element should be an ID of an unordered list (<ul> tag)
// preloadImage1 and preloadImage2 are images for the rollover state of a menu
Spry.Widget.MenuBar = function(element, opts)
this.init(element, opts);
Spry.Widget.MenuBar.prototype.init = function(element, opts)
this.element = this.getElement(element);
// represents the current (sub)menu we are operating on
this.currMenu = null;
this.showDelay = 250;
this.hideDelay = 600;
if(typeof document.getElementById == 'undefined' || (navigator.vendor == 'Apple Computer, Inc.' && typeof window.XMLHttpRequest == 'undefined') || (Spry.is.ie && typeof document.uniqueID == 'undefined'))
// bail on older unsupported browsers
return;
// Fix IE6 CSS images flicker
if (Spry.is.ie && Spry.is.version < 7){
try {
document.execCommand("BackgroundImageCache", false, true);
} catch(err) {}
this.upKeyCode = Spry.Widget.MenuBar.KEY_UP;
this.downKeyCode = Spry.Widget.MenuBar.KEY_DOWN;
this.leftKeyCode = Spry.Widget.MenuBar.KEY_LEFT;
this.rightKeyCode = Spry.Widget.MenuBar.KEY_RIGHT;
this.escKeyCode = Spry.Widget.MenuBar.KEY_ESC;
this.hoverClass = 'MenuBarItemHover';
this.subHoverClass = 'MenuBarItemSubmenuHover';
this.subVisibleClass ='MenuBarSubmenuVisible';
this.hasSubClass = 'MenuBarItemSubmenu';
this.activeClass = 'MenuBarActive';
this.isieClass = 'MenuBarItemIE';
this.verticalClass = 'MenuBarVertical';
this.horizontalClass = 'MenuBarHorizontal';
this.enableKeyboardNavigation = true;
this.hasFocus = false;
// load hover images now
if(opts)
for(var k in opts)
if (typeof this[k] == 'undefined')
var rollover = new Image;
rollover.src = opts[k];
Spry.Widget.MenuBar.setOptions(this, opts);
// safari doesn't support tabindex
if (Spry.is.safari)
this.enableKeyboardNavigation = false;
if(this.element)
this.currMenu = this.element;
var items = this.element.getElementsByTagName('li');
for(var i=0; i<items.length; i++)
if (i > 0 && this.enableKeyboardNavigation)
items[i].getElementsByTagName('a')[0].tabIndex='-1';
this.initialize(items[i], element);
if(Spry.is.ie)
this.addClassName(items[i], this.isieClass);
items[i].style.position = "static";
if (this.enableKeyboardNavigation)
var self = this;
this.addEventListener(document, 'keydown', function(e){self.keyDown(e); }, false);
if(Spry.is.ie)
if(this.hasClassName(this.element, this.verticalClass))
this.element.style.position = "relative";
var linkitems = this.element.getElementsByTagName('a');
for(var i=0; i<linkitems.length; i++)
linkitems[i].style.position = "relative";
Spry.Widget.MenuBar.KEY_ESC = 27;
Spry.Widget.MenuBar.KEY_UP = 38;
Spry.Widget.MenuBar.KEY_DOWN = 40;
Spry.Widget.MenuBar.KEY_LEFT = 37;
Spry.Widget.MenuBar.KEY_RIGHT = 39;
Spry.Widget.MenuBar.prototype.getElement = function(ele)
if (ele && typeof ele == "string")
return document.getElementById(ele);
return ele;
Spry.Widget.MenuBar.prototype.hasClassName = function(ele, className)
if (!ele || !className || !ele.className || ele.className.search(new RegExp("\\b" + className + "\\b")) == -1)
return false;
return true;
Spry.Widget.MenuBar.prototype.addClassName = function(ele, className)
if (!ele || !className || this.hasClassName(ele, className))
return;
ele.className += (ele.className ? " " : "") + className;
Spry.Widget.MenuBar.prototype.removeClassName = function(ele, className)
if (!ele || !className || !this.hasClassName(ele, className))
return;
ele.className = ele.className.replace(new RegExp("\\s*\\b" + className + "\\b", "g"), "");
// addEventListener for Menu Bar
// attach an event to a tag without creating obtrusive HTML code
Spry.Widget.MenuBar.prototype.addEventListener = function(element, eventType, handler, capture)
try
if (element.addEventListener)
element.addEventListener(eventType, handler, capture);
else if (element.attachEvent)
element.attachEvent('on' + eventType, handler);
catch (e) {}
// createIframeLayer for Menu Bar
// creates an IFRAME underneath a menu so that it will show above form controls and ActiveX
Spry.Widget.MenuBar.prototype.createIframeLayer = function(menu)
var layer = document.createElement('iframe');
layer.tabIndex = '-1';
layer.src = 'javascript:""';
layer.frameBorder = '0';
layer.scrolling = 'no';
menu.parentNode.appendChild(layer);
layer.style.left = menu.offsetLeft + 'px';
layer.style.top = menu.offsetTop + 'px';
layer.style.width = menu.offsetWidth + 'px';
layer.style.height = menu.offsetHeight + 'px';
// removeIframeLayer for Menu Bar
// removes an IFRAME underneath a menu to reveal any form controls and ActiveX
Spry.Widget.MenuBar.prototype.removeIframeLayer = function(menu)
var layers = ((menu == this.element) ? menu : menu.parentNode).getElementsByTagName('iframe');
while(layers.length > 0)
layers[0].parentNode.removeChild(layers[0]);
// clearMenus for Menu Bar
// root is the top level unordered list (<ul> tag)
Spry.Widget.MenuBar.prototype.clearMenus = function(root)
var menus = root.getElementsByTagName('ul');
for(var i=0; i<menus.length; i++)
this.hideSubmenu(menus[i]);
this.removeClassName(this.element, this.activeClass);
// bubbledTextEvent for Menu Bar
// identify bubbled up text events in Safari so we can ignore them
Spry.Widget.MenuBar.prototype.bubbledTextEvent = function()
return Spry.is.safari && (event.target == event.relatedTarget.parentNode || (event.eventPhase == 3 && event.target.parentNode == event.relatedTarget));
// showSubmenu for Menu Bar
// set the proper CSS class on this menu to show it
Spry.Widget.MenuBar.prototype.showSubmenu = function(menu)
if(this.currMenu)
this.clearMenus(this.currMenu);
if(menu)
this.addClassName(menu, this.subVisibleClass);
if(typeof document.all != 'undefined' && !Spry.is.opera && navigator.vendor != 'KDE')
if(!this.hasClassName(this.element, this.horizontalClass) || menu.parentNode.parentNode != this.element)
menu.style.top = menu.parentNode.offsetTop + 'px';
if(Spry.is.ie && Spry.is.version < 7)
this.createIframeLayer(menu);
this.addClassName(this.element, this.activeClass);
// hideSubmenu for Menu Bar
// remove the proper CSS class on this menu to hide it
Spry.Widget.MenuBar.prototype.hideSubmenu = function(menu)
if(menu)
this.removeClassName(menu, this.subVisibleClass);
menu.style.top = '';
menu.style.left = '';
this.removeIframeLayer(menu);
// initialize for Menu Bar
// create event listeners for the Menu Bar widget so we can properly
// show and hide submenus
Spry.Widget.MenuBar.prototype.initialize = function(listitem, element)
var opentime, closetime;
var link = listitem.getElementsByTagName('a')[0];
var submenus = listitem.getElementsByTagName('ul');
var menu = (submenus.length > 0 ? submenus[0] : null);
if(menu)
this.addClassName(link, this.hasSubClass);
if(!Spry.is.ie)
// define a simple function that comes standard in IE to determine
// if a node is within another node
listitem.contains = function(testNode)
// this refers to the list item
if(testNode == null)
return false;
if(testNode == this)
return true;
else
return this.contains(testNode.parentNode);
// need to save this for scope further down
var self = this;
this.addEventListener(listitem, 'mouseover', function(e){self.mouseOver(listitem, e);}, false);
this.addEventListener(listitem, 'mouseout', function(e){if (self.enableKeyboardNavigation) self.clearSelection(); self.mouseOut(listitem, e);}, false);
this.addEventListener(link, 'blur', function(e){self.onBlur(listitem);}, false);
this.addEventListener(link, 'focus', function(e){self.keyFocus(listitem, e);}, false);
Spry.Widget.MenuBar.prototype.keyFocus = function (listitem, e)
this.lastOpen = listitem.getElementsByTagName('a')[0];
this.addClassName(this.lastOpen, listitem.getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
this.hasFocus = true;
Spry.Widget.MenuBar.prototype.onBlur = function (listitem)
this.clearSelection(listitem);
Spry.Widget.MenuBar.prototype.clearSelection = function(el){
//search any intersection with the current open element
if (!this.lastOpen)
return;
if (el)
el = el.getElementsByTagName('a')[0];
// check children
var item = this.lastOpen;
while (item != this.element)
var tmp = el;
while (tmp != this.element)
if (tmp == item)
return;
try{
tmp = tmp.parentNode;
}catch(err){break;}
item = item.parentNode;
this.hideSubmenu(item.parentNode);
var link = item.getElementsByTagName('a')[0];
this.removeClassName(link, this.hoverClass);
this.removeClassName(link, this.subHoverClass);
this.lastOpen = false;
Spry.Widget.MenuBar.prototype.keyDown = function (e)
if (!this.hasFocus)
return;
if (!this.lastOpen)
return;
var e = e|| event;
var listitem = this.lastOpen.parentNode;
var link = this.lastOpen;
var hasSubMenu = (menu) ? true : false;
var opts = [listitem, menu, null, this.getSibling(listitem, 'previousSibling'), this.getSibling(listitem, 'nextSibling')];
if (!opts[3])
opts[2] = (listitem.parentNode.parentNode.nodeName.toLowerCase() == 'li')?listitem.parentNode.parentNode:null;
var found = 0;
switch (e.keyCode){
case this.upKeyCode:
found = this.getElementForKey(opts, 'y', 1);
break;
case this.downKeyCode:
found = this.getElementForKey(opts, 'y', -1);
break;
case this.leftKeyCode:
found = this.getElementForKey(opts, 'x', 1);
break;
case this.rightKeyCode:
found = this.getElementForKey(opts, 'x', -1);
break;
case this.escKeyCode:
case 9:
this.clearSelection();
default: return;
switch (found)
case 0: return;
case 1:
//subopts
this.mouseOver(listitem, e);
break;
case 2:
//parent
this.mouseOut(opts[2], e);
break;
case 3:
case 4:
// left - right
this.removeClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
break;
var link = opts[found].getElementsByTagName('a')[0];
if (opts[found].nodeName.toLowerCase() == 'ul')
opts[found] = opts[found].getElementsByTagName('li')[0];
this.addClassName(link, opts[found].getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
this.lastOpen = link;
opts[found].getElementsByTagName('a')[0].focus();
//stop further event handling by the browser
return Spry.Widget.MenuBar.stopPropagation(e);
Spry.Widget.MenuBar.prototype.mouseOver = function (listitem, e)
if(this.bubbledTextEvent())
// ignore bubbled text events
return;
if (listitem.closetime)
clearTimeout(listitem.closetime);
if(this.currMenu == listitem)
// move the focus too
if (this.hasFocus)
link.focus();
// show menu highlighting
this.addClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
if(menu && !this.hasClassName(menu, this.subHoverClass))
var self = this;
listitem.opentime = window.setTimeout(function(){self.showSubmenu(menu);}, this.showDelay);
Spry.Widget.MenuBar.prototype.mouseOut = function (listitem, e)
return;
var related = (typeof e.relatedTarget != 'undefined' ? e.relatedTarget : e.toElement);
if(!listitem.contains(related))
if (listitem.opentime)
clearTimeout(listitem.opentime);
this.currMenu = listitem;
// remove menu highlighting
if(menu)
var self = this;
listitem.closetime = window.setTimeout(function(){self.hideSubmenu(menu);}, this.hideDelay);
if (this.hasFocus)
link.blur();
Spry.Widget.MenuBar.prototype.getSibling = function(element, sibling)
var child = element[sibling];
while (child && child.nodeName.toLowerCase() !='li')
child = child[sibling];
return child;
Spry.Widget.MenuBar.prototype.getElementForKey = function(els, prop, dir)
var found = 0;
var rect = Spry.Widget.MenuBar.getPosition;
var ref = rect(els[found]);
var hideSubmenu = false;
//make the subelement visible to compute the position
if (els[1] && !this.hasClassName(els[1], this.MenuBarSubmenuVisible))
els[1].style.visibility = 'hidden';
this.showSubmenu(els[1]);
hideSubmenu = true;
var isVert = this.hasClassName(this.element, this.verticalClass);
var hasParent = els[0].parentNode.parentNode.nodeName.toLowerCase() == 'li' ? true : false;
for (var i = 1; i < els.length; i++){
//when navigating on the y axis in vertical menus, ignore children and parents
if(prop=='y' && isVert && (i==1 || i==2))
continue;
//when navigationg on the x axis in the FIRST LEVEL of horizontal menus, ignore children and parents
if(prop=='x' && !isVert && !hasParent && (i==1 || i==2))
continue;
if (els[i])
var tmp = rect(els[i]);
if ( (dir * tmp[prop]) < (dir * ref[prop]))
ref = tmp;
found = i;
// hide back the submenu
if (els[1] && hideSubmenu){
this.hideSubmenu(els[1]);
els[1].style.visibility = '';
return found;
Spry.Widget.MenuBar.camelize = function(str)
if (str.indexOf('-') == -1){
return str;
var oStringList = str.split('-');
var isFirstEntry = true;
var camelizedString = '';
for(var i=0; i < oStringList.length; i++)
if(oStringList[i].length>0)
if(isFirstEntry)
camelizedString = oStringList[i];
isFirstEntry = false;
else
var s = oStringList[i];
camelizedString += s.charAt(0).toUpperCase() + s.substring(1);
return camelizedString;
Spry.Widget.MenuBar.getStyleProp = function(element, prop)
var value;
try
if (element.style)
value = element.style[Spry.Widget.MenuBar.camelize(prop)];
if (!value)
if (document.defaultView && document.defaultView.getComputedStyle)
var css = document.defaultView.getComputedStyle(element, null);
value = css ? css.getPropertyValue(prop) : null;
else if (element.currentStyle)
value = element.currentStyle[Spry.Widget.MenuBar.camelize(prop)];
catch (e) {}
return value == 'auto' ? null : value;
Spry.Widget.MenuBar.getIntProp = function(element, prop)
var a = parseInt(Spry.Widget.MenuBar.getStyleProp(element, prop),10);
if (isNaN(a))
return 0;
return a;
Spry.Widget.MenuBar.getPosition = function(el, doc)
doc = doc || document;
if (typeof(el) == 'string') {
el = doc.getElementById(el);
if (!el) {
return false;
if (el.parentNode === null || Spry.Widget.MenuBar.getStyleProp(el, 'display') == 'none') {
//element must be visible to have a box
return false;
var ret = {x:0, y:0};
var parent = null;
var box;
if (el.getBoundingClientRect) { // IE
box = el.getBoundingClientRect();
var scrollTop = doc.documentElement.scrollTop || doc.body.scrollTop;
var scrollLeft = doc.documentElement.scrollLeft || doc.body.scrollLeft;
ret.x = box.left + scrollLeft;
ret.y = box.top + scrollTop;
} else if (doc.getBoxObjectFor) { // gecko
box = doc.getBoxObjectFor(el);
ret.x = box.x;
ret.y = box.y;
} else { // safari/opera
ret.x = el.offsetLeft;
ret.y = el.offsetTop;
parent = el.offsetParent;
if (parent != el) {
while (parent) {
ret.x += parent.offsetLeft;
ret.y += parent.offsetTop;
parent = parent.offsetParent;
// opera & (safari absolute) incorrectly account for body offsetTop
if (Spry.is.opera || Spry.is.safari && Spry.Widget.MenuBar.getStyleProp(el, 'position') == 'absolute')
ret.y -= doc.body.offsetTop;
if (el.parentNode)
parent = el.parentNode;
else
parent = null;
if (parent.nodeName){
var cas = parent.nodeName.toUpperCase();
while (parent && cas != 'BODY' && cas != 'HTML') {
ret.x -= parent.scrollLeft;
ret.y -= parent.scrollTop;
if (parent.parentNode)
parent = parent.parentNode;
else
parent = null;
return ret;
Spry.Widget.MenuBar.stopPropagation = function(ev)
if (ev.stopPropagation)
ev.stopPropagation();
else
ev.cancelBubble = true;
if (ev.preventDefault)
ev.preventDefault();
else
ev.returnValue = false;
Spry.Widget.MenuBar.setOptions = function(obj, optionsObj, ignoreUndefinedProps)
if (!optionsObj)
return;
for (var optionName in optionsObj)
if (ignoreUndefinedProps && optionsObj[optionName] == undefined)
continue;
obj[optionName] = optionsObj[optionName];
})(); // EndSpryComponent
This is my html code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<!-- TemplateBeginEditable name="Fit4Action" -->
<title>Outdoor Group Fitness & Personal Training for the Sutherland Shire, Jannali, Oyster Bay, Bonnet Bay and Como - Home Page</title>
<meta name="Description" content="Outdoor Group Fitness sessions for all shapes, sizes and abilities. NO lengthy contracts, NO admin fees. Just fun, motivating, fat-burning workouts. If you want to be Slimmer, Fitter, Stronger this season, it's time to get Fit 4 Action" />
<meta name="Keywords" content="outdoor group fitness, outdoor group training, Sutherland, boot camp,training, exercise,health,fitness,personal training,weight loss,lose weight,diet,fat loss,weight loss,nutrition,fitness training,well-being, wellness,bmi,whtr,group fitness,bootcamp,boot-camp,one on one,bonnet bay,jannali,sutherland,como,oyster bay,kirrawee,bangor,menai,gymea,caringbah,cronulla,woollooware, miranda,woronora,illawong" />
<!-- TemplateEndEditable -->
<link rel="stylesheet" type="text/css" href="../stylesheet.css" />
<!-- TemplateBeginEditable name="head" -->
<script src="../SpryAssets/SpryAccordion.js" type="text/javascript"></script>
<script src="../SpryAssets/jquery-1.4.2.js" type="text/javascript"></script>
<script src="../jQuery/js/jquery.jsocial.js" type="text/javascript"></script>
<script src="../SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
<link href="../SpryAssets/SpryAccordion.css" rel="stylesheet" type="text/css" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<style type="text/css">
body {
background-color: #84DFFA;
background-image: url(../images/sidebar.jpg);
h1 {
color: #666;
</style>
<script type="text/javascript">
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-20461848-1']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
</script>
<link href="../jQuery/css/style.css" rel="stylesheet" type="text/css" />
<script type="text/xml">
<oa:widgets>
<oa:widget wid="2149023" binding="#social" />
</oa:widgets>
</script>
<link href="../SpryAssets/SpryMenuBarVertical.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="container">
<div class="bannerArea">
<div class="bannernav"><a href="../PrivacyStatment.html" >Privacy Policy</a> |<a href="../ContactUs.html"> Contact Us</a></div>
<div class="toplogo"><a href="../index.html"><img src="../images/transparent.gif" width="253" height="145" border="0" /></a></div>
</div>
<div class="contentArea">
<div class="leftnavigation">
<ul id="MenuBar1" class="MenuBarVertical">
<li><a href="../index.html" title="Fit 4 Action Home">Home</a></li>
<li><a href="../AboutUs.html" title="About Fit 4 Action" class="MenuBarItemSubmenu">About Us</a>
<ul>
<li><a href="../AboutUs.html#OurMission" title="Our Mission">Mission Statement</a></li>
<li><a href="../AboutUs.html#Expect" title="What to Expect">What to Expect</a></li>
<li><a href="../AboutUs.html#Journey" title="Your Journey">Your Journey</a></li>
<li><a href="../AboutUs.html#Trainer" title="Your Trainer">Your Trainer</a></li>
</ul>
</li>
<li><a href="../WhyExercise.html" title="Why Exercise" class="MenuBarItemSubmenu">Why Exercise</a>
<ul>
<li><a href="../WhyExercise.html#Fitness">What is Fitness</a></li>
<li><a href="../WhyExercise.html#WhyExercise">Why Exercise</a></li>
<li><a href="../WhyExercise.html#Reasons">21 Reasons to Exercise</a></li>
</ul>
</li>
<li><a href="../Services.html" title="Training Options" class="MenuBarItemSubmenu">Services</a>
<ul>
<li><a href="../Services.html" title="Services">Outdoor Group Fitness</a></li>
<li><a href="../Services.html#OPT">Personal Training</a></li>
</ul>
</li>
<li><a href="../OutdoorGroupFitnessSutherland.html" title="Outdoor Group Fitness Sutherland">Group Fitness</a></li>
<li><a href="../Schedule.html">Schedule</a></li>
<li><a href="../BMI.html" title="Calculators & Tools" class="MenuBarItemSubmenu">Calculators & Tools</a>
<ul>
<li><a href="../BMI.html">BMI Calculator</a></li>
<li><a href="../WHtR.html">WHtR Calculator</a></li>
</ul>
</li>
<li><a href="../Events/index.html">Events</a></li>
<li><a href="../Testimonials.html" title="BMI">Testimonials</a></li>
<li><a href="../Links.html">Links</a></li>
<li><a href="../ContactUs.html" class="MenuBarItemSubmenu">Contact Us</a>
<ul>
<li><a href="../ContactUs.html#Form">Submit an Equiry</a></li>
<li><a href="../ContactUs.html#Location">Our Location</a></li>
</ul>
</li>
<li><a href="../LogIn.php">Log In</a></li>
</ul>
<p> </p>
<a href="http://www.fitness.org.au/" target="_blank"><img src="../images/fitness_australia.jpg" width="158" height="60" border="0" /></a>
</div>
<div class="content"><!-- TemplateBeginEditable name="content" -->
<div class="contentleft">
<h1>Get Fit 4 2011</h1>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
</div>
<div class="contentright">
<div id="SpryAccordion1" class="Accordion" tabindex="0">
<div class="AccordionPanel">
<div class="AccordionPanelTab tabTop">
<div class="accordion_340_tab"> Social communities</div>
</div>
<div class="AccordionPanelContent" style="display: block">
<div class="acontent">
<div class="social">
<p>You can find Fit 4 Action on the following social sites.</p>
<p>Click the icon below to jump to our page </p>
</div>
// BeginOAWidget_Instance_2149023: #social
$('.social').jsocial({
twitter : '@fit4ActionPT',
facebook : 'facebook.com/pages/Fit-4-Action/174324765926014?ref=ts',
// flickr : 'myID_2',
// delicious : 'myID_3',
linked : 'linkedin.com/in/fit4action',
// youtube : 'youtube.com/myID',
// feed : 'myID_4',
// friendfeed : 'myID_5',
// digg : 'myID_6',
// lastfm : 'myID_7',
center : false,
inline : true,
small : false,
newPage : true
// EndOAWidget_Instance_2149023
</script>
<iframe src="http://www.facebook.com/plugins/likebox.php?href=http%3A%2F%2Fwww.face book.com%2Fpages%2FFit-4-Action%2F174324765926014%3Fref%3Dts&width =200&colorscheme=light&show_faces=false&stream=false&h eader=false&height=62" scrolling="no" frameborder="0" style="border:none; overflow:hidden; width:200px; height:100px;" allowTransparency="true"></iframe>
</div>
</div>
</div>
<div class="AccordionPanelTab middleTab">
<div class="accordion_340_tab">Special Offers</div>
</div>
<h2> </h2>
<h2>PERSONAL TRAINING</h2>
<p><strong><a href="../freesession/index.html"><img src="../images/Free-Session.jpg" width="208" height="58" border="0" /></a></strong></p>
<p align="justify">Unsure if a Personal Trainer is for you?</p>
<p align="justify">Fit 4 Action know they can help and are offering a <strong>Free Session </strong>to sample Personal Training without obligation.</p>
<p align="justify">Prefer group sessions to motivate you?</p>
<p align="justify">Give us a try and your first week is FREE</p>
<p align="justify"><strong> Click <a href="../freesession/index.html">here</a> to find out more!</strong></p>
</div>
</div>
</div>
<div class="accordion_340_tab"> Latest News</div>
</div>
<h2>Sydney Morning Herald Half Marathon entries now open!!</h2>
<p>Need a challenge to keep you motivated in your training?</p>
<p>Join the Fit 4 Action team and take on the 21.5km half marathon course on May 20, 2012.</p>
<p>Click for <a href="http://www.smhhalfmarathon.com.au/" target="_blank">here</a> more information.</p>
<p><a href="http://www.smhhalfmarathon.com.au/" target="_blank"><img src="../images/Half-Marathon-Lead.jpg" width="204" height="92" border="0" longdesc="http://www.smhhalfmarathon.com.au/" /></a></p>
<p>Dont forget to enter the team name <strong>Fit4Action</strong> when you register.</p>
<h2> </h2>
</div>
</div>
</div>
</div>
<div class="AccordionBottom"></div>
</div>
<div style="clear:both; text-align: center;">
<blockquote>
<blockquote>
<blockquote>
<p> </p>
<p><span style="text-align: left; font-size: 12px; margin-left: 75px;"><a href="../index.html"> -Home </a><a href="../AboutUs.html">-About Us</a> <a href="../WhyExercise.html">-Why Exercise</a> <a href="../Services.html">-Services</a> <a href="../OutdoorGroupFitnessSutherland.html">-Group Fitness</a> <a href="../Schedule.html">-Schedule</a> <a href="../BMI.html">-Calcs</a> <a href="../Events/index.html">-Events</a> <a href="../Testimonials.html">-Testimonials</a> <a href="../Links.html">-Links</a> <a href="../ContactUs.html">-Contact Us</a></span></p>
</blockquote>
</blockquote>
</blockquote>
</div>
</div>
<div style="clear:both;"></div>
</div>
<div class="footerArea">
<div class="copyright">© 2011 Fit 4 Action. All rights reserved.</div>
</div>
</div>
var SpryAccordion1 = new Spry.Widget.Accordion("SpryAccordion1", {useFixedPanelHeights:true, defaultPanel:2});
var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgRight:"../SpryAssets/SpryMenuBarRightHover.gif"});
</script>
</body>
</html>
