greetings,
I have created a multiple-choice quiz which has three questions, one correct and two distractors.
The quiz works fine as long as you select the correct answer on your first attempt. If you select either the two incorrect answers, the quiz slide will "auto advance" before you had a chance to select another answer. Whilst it is possible to go back to the question slide I would like the participant to have at least four attempts to get it right before the quiz slide "auto advances".
In terms of setup, the question properties are set to allow four attempts before failure
.I have also tried to set the actions on failure to "no action" but this has absolutely no effect.
Similarly setting the preferences to show "retake button" does not seem to work.
I'd be very grateful for any help that anyone could give.
Cameron
You can set the number of attempts at a question level as well as at the quiz level. Each performs a different job.
It sounds like you may be confusing the Quiz Attempts setting (under Quiz Preferences > Pass or Fail > If Failing Grade > Allow User) with the Question Attempts setting which is reached by selecting the quiz slide and going to Quiz Properties > Action accordion > Attempts.
Can you confirm that you actually have the Question Attempts set to 4?
yes, I confirm that the question attempt are set to 4.
Since I posted this query, I have a bit more fiddling and have discovered that, if I set the "action on success" for the distractors to "no action" the problem is resolved.
I'm not sure whether or not the fact that I am using the Advanced Answer option to give feedback on incorrect and correct answers has any influence on the matter.
I'm, just to make sure that I fully understand the distinction between quiz attempts and question attempts. The quiz is comprised of all the individual questions that are asked? In other words a learning module will typically have one quiz comprised of a number of questions.
Have I got it, or am I still missing the distinction?
Many thanks for your efforts.
Hello,
Wanted just to reply on your sentence '... just to make sure that I fully understand the distinction between quiz attempts and question attempts".
Recently I published a couple of blog posts in which I tried to summarize the functionalities of quizzes, question/score slides and also provided some tweaking possibilities. Maybe you could find them useful?
Question Question Slides - part 2
Lilybiri
Hi Lilybiri,
thanks for the links that you sent. Like all of your
material it's really helpful and has expanded my understanding greatly.
Thank you SO much.
I have read many of your postings ( I would have
said all but I had not seen these) and have got a huge amount from them.
If you ever find yourself in New Zealand, please contact me, my wife and
I would be privileged to show you around our bit of the planet.
and best wishes
Cameron Gay
On Tue, 03 Apr 2012 03:32:39 -0600,
Lilybiri wrote:
RE: ALLOWING STUDENT MULTIPLE ATTEMPTS TO ANSWER A
QUESTION
created by Lilybiri Re: Allowing student multiple attempts to answer a question in Quizzing/LMS - View the full
discussion Re: Allowing student multiple attempts to answer a question
