Vilius Šumskas
HLS streaming leftovers
Apr 3, 2012 2:41 AM
Tags: #hls #recording
We have HLS live streaming events streamed using default livepkgr application and default liveevent. However even if we stop the stream, users can still play last 5-6 seconds of the stream on their iOS devices.
The link http://ourdomain/hls-live/liveevent/streamname.m3u8 also still works even if we stop the stream. The main problem here is that when we want to create a new stream with the same name again it doesn't work anymore. FMLE application shows that it is publishing the stream, however all clients just replays the old 5-6 seconds again and again.
What could be the problem and how to fix it?
    Apr 3, 2012 2:53 AM   in reply to Vilius Šumskas
    Correct answer lies in this thread http://forums.adobe.com/thread/981286?tstart=0
    Apr 3, 2012 4:26 AM   in reply to Vilius Šumskas
    adbe-record-mode= setting
    Here setting can be
    1. "record" - which will create a fresh recording everytime you start publishing. Remove the old one. You need to be sure about this.
    2. "append" - which is default one. In this case recording is appended to the previous recording. But for this to work correctly, you must have either
           a.  Proper ATC settings in application.xml. (which i can't remember offhand)
                           or
           b. must have absolute timestamps from the encoder. In FMLE, sending absolute timestamp can be enabled by making syncronisation to true in config.ini of the FMLE.
    So as you said, you don't want to keep recordings ( any dvr data).. settting adbe-record-mode=record is best for you.
    Apr 3, 2012 4:57 AM   in reply to Vilius Šumskas
    oh yes.. config.xml (sorry for the confusion)
    And do I need to delete all old streams from the server when I adjust absolute timestamp settings in FMLE?
    - you can always avoid doing that "manually" by using "adbe-record-mode=record" .. But if you want new recording to append to previous, you shouldn't use this mode.. It depend upon your use case
    Apr 3, 2012 5:12 AM   in reply to Nitin Goel
    Hi Nitin and all other employees here,
    about this:
    Here setting can be
                           or
    I have never succeded to setup 24/7 live HLS to work properly and to stream live with the append default - regardles of the Application.xml settings.
    (FMS streams via HLS only whats written on the disk in the duration set in diskmanagement - which is not rewritten if append parameter is on, which is the default - am i right? According to tests i've done, i am but please do correct me if i'm wrong)
    Could you share these (correct Application.xml settings to stream 24/7 live with the default append parameter) with us?
    Also, all of this append/record stuff is undocumented (which is criminal in my opinion since a lot of clients cant stream live HLS until they change this parameter) although there are a couple of posts on this forum, can we get a complete quide about these two paramters - including the info on how to change these on server side (in .asc).
    Are there any differences if we setup these server side instead of FMLE? (whats the correct setting in .asc server side "" or "record"?)
    Someone please answer...
    Apr 3, 2012 7:18 AM   in reply to Vilius Šumskas
    Q- So can you confirm that changing timestamp parameter needs deleting old streams on the server?
    A-
    - if old stream is also published with the "syncronisation=true" param - then not.
    - if there is timestamp timeline mismatch (i.e one is published with absolute timestamp and other with non absolute) - then yes. And you can do deletion either manually or using "adbe-record-mode=record" every time.
    Apr 3, 2012 1:09 PM   in reply to Nitin Goel
    Hi Nitin
    could you please answer me as well?
    Thank you in advance!
    Apr 3, 2012 10:06 PM   in reply to nnmk
    Hi nnmk,
    Q- Could you share these (correct Application.xml settings to stream 24/7 live with the default append parameter) with us?
    A- I have raised your concerns with my team.. Will talk to experts of this area in my team.. Please bear with me.. Let me check correct solution..
    Q- Also, all of this append/record stuff is undocumented (which is criminal in my opinion since a lot of clients cant stream live HLS until they change this parameter) although there are a couple of posts on this forum, can we get a complete quide about these two paramters - including the info on how to change these on server side (in .asc).
    A- You need to replace the instances of "append" with "record" in main.asc . I will talk to documentation team on this.
    Q-Are there any differences if we setup these server side instead of FMLE?
    A- No, but if you send it via FMLE, its on per stream basis. While if you change the livepkgr app, it once for all streams. And change in livepkgr app will require reloading the app.
    Thanks for your patience..
    Apr 4, 2012 6:53 AM   in reply to Nitin Goel
    Hi Nitin,
    many thanks for replying!
    I (and i believe some part of this community, especially the paying customers with interest in 24/7 rtmp+hds+hls live streaming) avait you answers!
