KateZB
Help! multi-calculation JS needed...I have no clue!
Apr 3, 2012 11:09 AM
Tags: #custom #script #calculation #acrobat-forms #acrobat_pro_x
Hello, I have a horrific (to my mind) multi-step problem...and I figured out the math I need to use, but not sure how the heck to get it to work in JS - I am at wits' end!
Please, gurus of JS, help me!
So:
1. The User types a number into "cell a"
2. The number in "cell a" needs to be x by $120
3. then the resulting value of "cell a x $120" is then x by 40%, which populates "cell b"
4. then "cell b" is x by .9782, and populates "cell c"
5. To get the value for "cell d", divide "cell c" by "cell a".
Now, for the most evil part to my non-scripting mind:
6. if the value of "cell d" is less-than $48, multiply "cell d" by $48 anyway to get the value for "cell e"
    If the value for "cell d" is greater than $48, use the greater number to calculate "cell e".
Argh! Ack!
There is more to the form, but I can figure out those bibs and bobs...it's just the run above is making my eyes cross.
    Apr 3, 2012 7:23 PM   in reply to KateZB
    Do you know how to do 1-5?
    The calculation for #6 is actually much simpler than you are making it - just use the Max of '48' and 'cell d' to calculate 'cell e' (you haven't quite explained clearly how you are calculating 'cell e' -- are you multiplying cell d by itself?)
    var cellD = this.getField('cell d').value
    var multiplier = Math.max(48, cellD);
    this.getField('cell e') = multiplier * cellD  // Is this what you want?
    Apr 4, 2012 8:24 AM   in reply to KateZB
    It often helps to use descriptive names for your fields (and variables). 'cell a', 'cell b', etc. don't really help much.
    I am guessing at what your values are representing:
    'cell a' = QTY
    $120 = Price (per unit)
    40% = Discount??
    'cell b' = Total Price (line item)
    'cell c' = ??
    'cell d' = ??
    'cell e' = ??
    So, an example to understand what is happening with the numbers (X represents the unknown multiplier that I questioned for cell e):
    'cell a' = 5
    'cell b' = 5 * $120 * .4     [240]
    'cell c' = 240 * .9782       [234.768]
    'cell d' = 234.768 / 5       [46.9536]
    'cell e' = X * Max(48, 46.9536)       [ X * 48]
    Is this correct?
    Apr 4, 2012 1:21 PM   in reply to KateZB
    This still doesn't make much sense to me.
    According to that, Test Rate will always be the same: 120 * .4 * .9782     [46.9536]
    TotalUSD = #Cand * (120*.4*.9782)
    TestRate = TotalUSD / #Cand
    is the same as
    TestRate = #Cand * (120*.4*.9782) / #Cand
    is the same as
    TestRate = #Cand/ #Cand * (120*.4*.9782)
    is the same as
    TestRate = 1 * (120*.4*.9782)
