Font List Display Bug
Apr 3, 2012 11:16 AM
Tags: #drop #font #bug #down
Im having issues with the font drop down.
styles are being repeated and in the main drop down fonts are out of order.
as seen in the screen shot
    Apr 3, 2012 2:51 PM   in reply to naftolimann
    There is a known bug regarding font styles being repeated.See this link to see if it is similar:
    Type styles doubling in menu dropdown
    What are you doing and where do you see this from?
    Mac or PC?
    OS?
    Pattie
    Apr 3, 2012 3:57 PM   in reply to Pattie F
    I get the repeated font Styles.
    Mac 10.6.8
    Apr 3, 2012 4:03 PM   in reply to charles badland
    Hi Charles,
    Would you happen to have a bootable backup volume or Time Machine volume attached?  Just wondering.
    Apr 3, 2012 6:57 PM   in reply to station_one
    Yes. Time Machine working overtime.
    Apr 3, 2012 7:11 PM   in reply to charles badland
    Maybe it's picking the duplicate styles from there.  Just speculating.
    Apr 3, 2012 7:39 PM   in reply to station_one
    Maybe it's picking the duplicate styles...
    My first was my first thought too was dup fonts. Font Book found a few.
    This is, however, specific to PsCS6.
    but... Time Machine is a good point. I'm not sure how to check on dup fonts in TM. I'm just using (for now) Font Book to organize fonts. It has just been recently (during PsCS6 testing) that I have been getting messages that TM drive is full and needs to overwrite.
    Interesting.
    Thanks for the suggestion.
    Apr 3, 2012 8:25 PM   in reply to charles badland
    charles badland wrote:
    ...not sure how to check on dup fonts in TM...
    By temporarily unmounting the TM volume before relaunching Ps maybe?
    Apr 4, 2012 1:05 AM   in reply to naftolimann
    I think that this may be being being triggered by the fonts being duplicated in several different Libraries.
    On my Mac (OSX 10.6.8), the same fonts were listed in HD/System/Library/Fonts; and in HD/Library/Fonts.
    I have now set FontAgent Pro to "Manage System Fonts" and I am no longer seeing duplicated font names in the PS CS6 Font menu.
    I have also removed the Asian and Middle Eastern Adobe fonts from the  HD/System/Library/Fonts folder and so they no longer appear in the menu and this does not seem to have upset Photoshop in any way.
    I do not use FontBook (I emptied and disabled it years ago) so it's not part of the equation here.
    ______
    One problem:
    Fonts which work perfectly well in InDesign CS 5.5 (namely the complete and extended set of Minion Pro) will not work in Photoshop CS6 and trigger this error message:
    Apr 4, 2012 9:21 AM   in reply to CameraAnn
    I have discovered where my MinionPro problem was coming from:
    The set of ten Minion Pro fonts that are installed in the HD/Library/Fonts folder (which are of 2012 vintage) work correctly in Photoshop CS6 (including the two Condensed faces).
    My "complete family" set of 48 faces dates from 2002 and it is the Condensed, Display, Caption and Subhead faces in the 2002 set which trigger the error message both in Photoshop CS6 and in CS5 — although they work perfectly well in both illustrator and Indesign CS 5.5.
    I very seldom set type in Photoshop and it was only because I was systematically testing the extended Type families in CS6 that I came upon this anomaly.
    It probably isn’t that important, because it is unlikely that many people use Caption, Subhead and Display type-styles in Photoshop but the Bug should be recorded in Adobe’s database.
    I hadn’t discovered the problem before this — even though I have had the 48-face Minion Pro family installed on my computers for the past ten years!
    Apr 4, 2012 9:47 AM   in reply to naftolimann
    I'm not having any font issues but I'll provide a little information to hopefully help with the troubleshooting of the issue.
    My system is a Mac Pro OSX 10.7.3 and I've turned off Font Book and Time Machine due to severe issues in the past. Haven't had any trouble since.
    In place of Font Book, I use Linotype FontExplorer X. That resolved all of my font problems permanently.
    Apr 4, 2012 11:06 AM   in reply to naftolimann
    Yes, this is a TYPE bug.
    Delete Photoshop preferences file (hold down shift + option or command keys at once) on launch may help, please try.
    Sorry for the inconvenience.
    Apr 4, 2012 2:24 PM   in reply to naftolimann
    Thanks to Kyoko, we have a script that may help with this issue.
    Please give it a try at the link below:
    Pattie
    FAQ: How do I clear out my font cache?
