If I create a new PDF document with a series of form fields and then need to update, e.g. the word document is changed to include or change fields, can I update the existing PDF without having to re-do all the fields
Hi cammic3319
Yes you can change the word document, then make a new PDF then replace the form with the fields with the new PDF.
If you are careful and do not change the position of the fields then it will fit right in.
If you change or add fields then with Acrobat you will have to rearrange the fields to match.
Ron A
