poojapooja
AppStats using onGetAppStats() in main.asc
Apr 3, 2012 10:29 PM
Tags: #statistics
I am trying to collect appstats using this code in main.asc.
What is wrong here?
application.onConnect = function( p_client, p_autoSenseBW )
     this.acceptConnection(p_client);
     nc_poll=new NetConnection();
     nc_poll.connect("rtmp://localhost:1111/admin","admin","a1s2d3f4");
     nc_poll.call("getAppStats",new onGetAppStats(), "vod");
    function onGetAppStats()
    this.onResult = function(info)
      trace("POOJA 1111");
      outputBox.text = "Info for "+appName.text+ " returned:" + newline;
      trace("POOJA 2222");
      printObj(info, outputBox);
    function printObj(obj, destination)
     trace("POOJA 3333");
     for (var prop in obj)
     destination.text += "\t";
     destination.text += prop + " = " + obj[prop] + newline;
     if (typeof (obj[prop]) == "object")
     trace("POOJA 4444");
      printObj(obj[prop], destination);
thanks
    Apr 4, 2012 8:54 AM   in reply to poojapooja
    1. Wait for the onStatus event from the NetConnection before invoking methods. Otherwise, you may be calling a method on a netconnection that hasn't been completed.
    2. Are you defining the nc_poll variable outside of the onConnect method? If not, the scope of nc_poll is the onConnect function, so when the function returns, the nc_poll variable will have gone out of scope, and will be eligible for garbage collection.
    Apr 9, 2012 8:26 AM   in reply to poojapooja
    You're still calling getAppStats on the connection without being sure the connection is established. Invoke a method outside of onConnect in response to the onStatus event.
    Apr 10, 2012 4:30 AM   in reply to poojapooja
    Create the connection in your onAppStart method, rather than the onConnect method.
    Alternately, you can create a new class to manage this, and instantiate an instance of that class in your onAppStart.
