Preload to Memory ( is that even possible )  ?
Apr 3, 2012 10:09 PM
   So I noticed with the app I am working on.  There are some stutters the first time a section animates on the stage.  Once its been seen on the stage is performs great for the duration of the session.
     is there a way to preload all these movieclips to memory or something so that they will always perform great from the first time they are displayed to the stage ?
    Apr 3, 2012 11:11 PM   in reply to Applauz78
    I've found I sometimes experience less stutter if I have everything on the display list and control through visible rather than add/remove children.
    Also you can try hiding through off screen x or y properties.
    Apr 4, 2012 6:18 AM   in reply to Applauz78
    It sounds like you're using GPU. When you do, the bitmap doesn't get transferred to the GPU until the first time it is within the stage area. If you smoothly animate it from outside of the stage, it will stutter as  it goes into the stage area. You can solve that by placing it in the stage area for at least one frame's worth of time before you move it. It can be invisible at the time, it will still be cached. Then on the frame where you start to animate it, set it to be visible.
    Apr 4, 2012 9:49 AM   in reply to Applauz78
    The simple solution is to have a loading screen and simply place all your concent on the stage hiddent behind the loading screen image, then proceed to the level or animation you are loading, this way you get that first time on stage part out of the way in the background.
    Apr 4, 2012 9:53 AM   in reply to Applauz78
    Put that second level movie clip to load on the stage as well.
    Apr 4, 2012 9:55 AM   in reply to Applauz78
    Of course that will be the case. You would need the sub movieclip to be in the stage area of the movieclip. You're only just getting a hint of why I like Direct more than GPU, if Direct ends up being good enough!
    Apr 4, 2012 10:14 AM   in reply to Applauz78
    Love me some TweenMax, TweenLite. Anyhow you can then pretween your content before you show it to the user, do an accelerated tween so in like .1 seconds.
    Apr 4, 2012 10:31 AM   in reply to Applauz78
    I wasn't expecting that having the sub movieclip on the stage would help. If it's on the stage area of the movieclip it is in, then I would expect it to work.
    Apr 4, 2012 10:47 AM   in reply to Applauz78
    Oh I sounded over complicated on my post, I am still in that whole hide your content you want to load in the background mode, then tween it it while its hidden once, just an accelerated version of it, then when you tween it for the user it will be pre tweened.
    This is kind of a hacky way of doing it, but if it works and solves your issue then who cares, right?
    Apr 4, 2012 11:33 AM   in reply to Applauz78
    So it still stutters when you tween it the second time? Seems strange since you said after you tween it once the second time around it runs smooth, so the hidden tween would be the tweening it once and the visible tween would be the smooth tween.Did you tween it the first time while its set to visible = false? If so do it with it being visible, although hidden, you know what I mean.
    Apr 4, 2012 11:36 AM   in reply to Mark.Raykhenberg
    The visibility won't affect whether it's cached. Whether it's inside the stage area does. Having the same symbol cached at a different position in the hierarchy doesn't mean that other cases where the symbol is used is also cached.
    Apr 4, 2012 11:42 AM   in reply to Applauz78
    What is the movie clip in question, is it just a still graphic or is it a timeline animation, or are you tweening children inside the parent mc from the stage?
    Apr 4, 2012 11:49 AM   in reply to Applauz78
    And then you are tweening those 15 movie clips from the main stage?
    And from previous post it sounds like you have tried putting those 15 mcs in the preloading hidden screen? correct?
    From my experience flash seems to have a bit of a delay playing sounds or movie clips or anything the first time it encounters it however playing it once before seems to solve this problem, not sure why any of my pro tips are not helping
    Apr 4, 2012 12:00 PM   in reply to Applauz78
    Try preloading those 15 mcs separately on the preload hidden screen, just for my own amusement.
    Also try it without addChild but just plop those movie clips down on the timeline.
    How long after you addChild the MainMovie_MC do you tween it?
    Apr 4, 2012 12:30 PM   in reply to Applauz78
    Now I am totally confused. You tried taking out the 15mcs from the parent and putting them on the timeline? I was suggesting just duplicating them on the timeline as their own entities and still keeping them in the parent mc, I am guessing you put them all in one mc for a reason. Also how does your loading screen work? Are you pausing on it for a second or two or do you just let the movie play through that frame? You might need to stop there for a few seconds to allow flash to load up all the assets.
