Hi
I just recently bought the flash professional CS5.5 upgrade version.
On the side of the box it says I cannot use this programn without CS5. Also I couldn`t find Cs5 on its own anywhere.
Can I still use this programn without CS5? Im not opening the box until I can find out.
If you bought an upgrade version you will need to have one of the earlier versions installed.
I would imagine the box would contain it.
there is nothing in the box that that gives the serial number of a previously installed Flash
for it to say I needed one of the previous programns
To "Upgrade", yes you will need to own and have installed one of the previous versions withiin the registration range.... so MX2004 will not work... for example.
Adninjastrator
Perhaps the individual applications are different but the suites do not require a previous version installed. It simply makes it easier because it auto-absorbs the previous serial number.
I recently reinstalled my entire OS and installed CS5.5 upgrade itself. I also installed Flash Builder upgrade and Dreamweaver CS5.5 upgrade without prior installs, no issues.
A strategy that will work is simply download the CS5.5 trial version and install it. When it asks you for your key, enter the key you have. Then you will be prompted for a previous versions key. Enter that and you're done as long as the previous key is within the upgrade range. There's no difference besides perhaps samples between the boxed version and the Trial download.
