Help please. Mixdown says it takes 17 hours, then hangs
Apr 4, 2012 1:27 AM
All of a sudden when I bounce my session to a track or bounce the master to a track, it says the mixdown is going to take many hours, from 8-17 hours to mix the session, then it HANGS, after about 10 seconds and doesn't mixdown anymore. I'm very concerned because this is an important session that I now can't mixdown.
I remember having this problem once years ago but can't remember what the solution was.
Please help with any ideas or solutions. I have tried bouncing down tracks, eliminating effects, but no difference so far. There are only half a dozen tracks, it's very frustrating. I feel helpless!
Thanks.
    Apr 4, 2012 1:32 AM   in reply to ozworldz
    Maybe try bouncing down to a different location?
    Apr 4, 2012 9:20 AM   in reply to ozworldz
    What happens if you do a File>Export ?
    Apr 4, 2012 10:26 AM   in reply to ozworldz
    I'm thinking maybe you have a lot of blank space after your last clip?
    If that is the case then you can fix it by editing the sesx file
    I don't know how to do it using CS5 but if you edit the sesx with a text editor  then on the 5th line look for "duration=" (the line starts with "<session")
    Edit the value for duration to be a value a few samples bigger than the end of the last clip and then save the sesx file
    Apr 4, 2012 2:18 PM   in reply to ozworldz
    My bad.
    So is there a lot of space after the last clip?
    Is this session an ses or xml file?
    Apr 4, 2012 7:01 PM   in reply to ozworldz
    How about you just email me the ses file (no audio) via the aatranslator.com.au web site and I'll check it out
