Hi, I recently installed Photoshop CS5, however every time I open the application, I am receiving this error message at the loading screen:
"Could not open a scratch file because the file is locked or you do not have the necessary access privileges. Use the ‘Get Info’ command in the Finder to unlock the file or change permissions on the file or enclosing folders."
I've looked online for solutions everywhere, but I've obviously been unsuccessful and I'm at the point where I have no idea what else to try, other than a clean install of my OS, however that is a last resort as I currently do not have an external hard drive to transfer my files to do so. So far I have tried these things:
I have a 2010 Macbook Pro, 4GB RAM running OS X Lion 10.7.3 with 2 patitions on my harddrive (OS X and Windows 7). I have 15GB free on my OS X partition currently, which may not seem like much, however I have run Photoshop CS5 previously as a trial and other versions of Photoshop and the small amount of harddrive space has never affected the software's ability to create a scratch file.
The strange thing, however, is that I can use Photoshop CS5 & CS6 on a guest account that I created recently, which means that the problem I am having is permissions based. Logging into a seperate account is a good enough solution for now, but it is incredibly tedious to keep changing accounts just to use Photoshop.
Has anyone got any other ideas? As I mentioned previously, reinstalling is a last resort as I currently don't have the neccessary resources.
Thanks.
I'm not seeing that option in the 'Get Info' screen, however after some Googling it seems like this could work. Is there any way that I can get this option to appear?
EDIT: After a bit more reading, it turns out that the option will not appear if you are currently booted into said harddrive. I'm unsure about how to get around this.
Sorry, I overlooked the fact that you are on a MacBook laptop and are using your boot drive as your scratch disk drive. My bad. ![]()
Then, I have no further ideas. 15 GB is way too little space for Photoshop's scratch disk drive, especially when that very small space is being shared with the swap files of the OS. I wouldn't be surprised if the reason only an administrator can run it on your machine is actually a protective measure.
Hm, I'll create and boot into a small partition and try to check the option that way. If that doesn't work, I guess I'll have to do a clean install.
I've used Photoshop when I had even less space than 15GB so I'm unsure about that, but I may clear some stuff out and see if that works anyway.
It's painfully obvious that I'm not qualified to give advice in a situation like yours. Sorry.
Generally speaking, one should NOT partition the only drive in a laptop, as the space available to the swap files of the OS and to the Photoshop scratch disk does not need to be limited a priori by the constraints of partitions.
Of course, I'm deliberately ignoring your apparent need for a Windows partition, because i wouldn't remotely know how to handle that.
I managed to fix this myself, almost by accident, after failing every method suggested that I came across.
My problem was due to 'read only' access being set to some folders in ~/private/ on my main account, meaning that Photoshop could not create an important, temporary scratch file in this location.
To anyone else who comes across this thread due to having the same problem, here's the solution:
Although this solution was ideal for my home laptop, giving 'read and write' access to important folders like these can probably lead to lowered security so please do it at your own risk.
The /private folder is a hidden folder. However, if you navigate to Go > Go to Folder and within the Go to Folder window enter just "/private/" without the quotes, then it should take you to the private folder. Make sure you're typing it exactly as it is here. Folder/file names are case sensitive.
