I am currently making an address book and have had to occasionally remove names from the listings. What this means is that there are now blank cells all through out my address book. How can I remove those cells?
I don't have to worry about the fill and strokes of this particular table since both the fill and the stroke is set to none.
The problem I am having with deleting an entire row is that in this case there are two cells in each row and even though one cell may be empty the other might have text in it. Therefore deleting a row would also delete some of the text it that row along with the blank cell.
I guess in that case I don't understand the problem. Blank cells is normal but if you must have it as one, you need to select the 2 cells in the row and "merge cells". Personally I would just leave it as is and turn any strokes you have on the table off so you don't see the lines. You can't "remove the cells" individually.
Alternatively, make your address book using paragraph styles with tabs.
My hunch is that you're expecting something like table cell behavior in Word - which gives you the choice of "shift cells up" or "shift cells left" when you delete a few individual cells in the middle of a table. However, as you've discovered, you really can't delete individual table cells in InDesign.
You ought to post a screenshot so that your readership isn't guessing what your addressbook looks like - only then can we make reasonable suggestions. However, for what it's worth, it sounds to me like Rik is on the right track; a table is not a good way to manage this data. If you can show us what your data looks like, we can probably suggest 1) an easy way to get your data out of the table, and 2) a way to handle the data that will make future updates easy.
Yeah Joel, what you are saying is what I meant; I am looking for a way to shift cells around. I am not familar with Microsoft Word but it sounds like the feature I am talking about. That seems odd to me that InDesign woudn't have that feature. The only way to do this (while keeping the names in alphabetical order) is to cut and paste each name one at a time? Yikes! The reason I designed it using tables like this is because this is the way that my client said they wanted it to be. Fortantly my list of names is relatively short so cutting and pasting shouldn't take too much time. I am surprised that Word would be much smarter at doing this; InDesign has had the tables feature for qutie a while now I would have thought they would have worked this out by now.
<cough>
Corrupt tables are pretty much the primary cause of corrupt Word documents. I've never seen a table cause a corrupt InDesign document. Word allows a lot of table-mangling, but I'd say that giving table-manglers what they want is the exact opposite of "smart." Tables in Word are pure hell. InDesign's table implementation (purchased from a third party plugin developer, if I recall correctly), while not as... er... flexible as that of Word, is far more stable. I guess it depends on what you think is smart.
Anyhow, back to what you want:
Well, I hope you bill hourly.
There is a way to automate this, I think, using InDesign's Data Merge feature. If you aren't billing hourly, then it may be worth setting up - moving all of the content into an application like Excel, a spreadsheet app where it's really easy to do address-book-entry-management the way you want, and does not induce corruption when you have to spot-delete individual cells, unlike some other apps I can think of. You can then save a file out of Excel, and InDesign can automagically fill up your tables with content from your Excel file, with no gaps. When your client wants changes, then you just tweak your Excel file a bit, export, and then run the Data Merge to get your gap-free table back.
However, that'd be a lot of work, and I can't even guarantee that it would work, never having tried it. But it's where I'd go in your shoes if my dataset wasn't this small:
Lastly, I think that your client might not care about whether or not they're in table cells; they just want it to look that way, right? If so, there are many, many ways to set up your doc that don't involve tables, that still yield the desired appearance. If you want to go in that direction, I can toss out a few ideas - I think that Rik already has, although his suggestion is a little bit low on detail. ![]()
There are a few ways to combat this, and as Joel has pointed out, I doubt your client would really care if it was IN tables, as long as it looked like it was.
Using Data Merge: Link to Adobe Help on Data Merge
The best and most efficient way for future updates is Data Merge. However, you would not be able to put each piece of content in a table. You would need to add each field inside a text box that you have sized to the maximum size each address would be - example, you have 8 addresses per page so the width of the box would be half page size and the height of each would be 1/4 page size. Only create one text box using this method. Once you have the box, use the Data merge panel to preview 'multiple records per page' and it should then populate the page with as many boxes as it can. If it looks ok, you can run the merge.
Each box would contain something like:
<<name>>
<<address>>
<<address2>>
<<address3>>
<<phone>>
<<cell>>
<<car>>
If <cell> was blank, then the <car> moves up in it's place etc etc.
Not Using Data Merge
There are no doubt a few other ways too but these should give you a good start.
I haven't read the whole thread, so this may be a bit off, but I just looked at the picture. Data Merge could, in theory, do this and leave out the blank lines. I say in theory because Blank means blank -- no spaces or punctuation you've added between fields on the line. And of course you would have to set up your text file and run the merge, which is time consuming (the setting up part) and you may already be deep into this (in fact it sounds like you already have a file you want to edit).
Another possibility that I don't think has been mentioned is to convert the table to text (Table > Convert Table to Text...). Though there are other options, typically you would use tabs inthe converted text to define the columns (you look like you have only one column) and paragraph returns to define the rows. Once it's text you can edit and the text will reflow, or run find/change to remove multiple whitespace or all paragraphs with a particular style, or whatever.
I have to agree with the others here that making a directory that is an actual "Table" rather than tabulated text is a nightmare.
For what it's worth I just finished up a directory project. It lists member names, addresses, email websites, and multiple phone numbers, any of which might be missing, all with an index number. The main listing is sorted by town, then by business name (and uses a numbered list to generate the index number), and it also has two alphabetical lists of just names or business names with the main list number. I use data merge, and I spend an hour or two initially setting up an Excel spreadsheet with the information (I get a database dump from the client), then export a new text file and do my merge. Inevitably the client makes three or four rounds of changes, and because many of these affect ordering it is often easier to re-sort in Excel, then run the merge again. The part that is time-consuming is the work in Excel, not the merge itself, though I have only a few hundred names.
@Joel Cherney
Yes, fortunately I am charging hourly! The dataset idea sounds like a much better way to go. The reason I went with tables was because the client handed me the document in Microsoft Publisher with the tables already setup and wanted it to look like the Publisher file. Knowing that I had to work with a Publisher file I thought my options were very limited (I have heard about some options for importing publisher docs but I remember people were talking about it being a pain to do.) If she gave me the information as a word or excel file I know that I would have more options to work with.
Datasets sound like a good idea. I haven’t had to make anything like a directory before so I have never used them. Using to track cells seems like a much better thing to do.
@RikRamsay14
Thanks for the instructions on using data merge. I will try this the text time someone gives me an excel file and wants to turn it into a directory. I was trying to tell my clients that it would be much easier on me if she gave a me a word or excel file to begin with.
@Peter Spier
I didn’t even consider the ways that you mentioned to set up the file to make it look like a table without it actually being a table. That would make sense. There is only one question I have on using the paragraph returns; wouldn’t using a paragraph return mean that the text in the rows would no longer be lined up with each other?
Your sample looks to me like a simple two-column layout. Since I don't see the cell edges I don't know what is waht in terms of table layout now, but it's easy to set up a baseline grid and align the first line of a paragraph to it, if you want to have the same amount of listings in each column and vary the space between, with each lisitng starting at a set distance from the top. If the number of listings can vary it's even simpler.
