Arcinsanity
Flash player local storage setting resetting to none
Apr 4, 2012 11:01 PM
Tags: #settings #windows_7 #windows #flash_player #64_bit #local_storage
     I have windows 7 64 bit using both fire fox and IE when i right click on a flash video etc and go to local storage setting it is set to none, if i move the slider then click close it does absolutely nothing, when i reopen the setting for the same video it is still at none. i tried reseting the global storage setting using http://www.macromedia.com/support/documentation/en/flashplayer/help/se ttings_manager03.html and the settings manager dosnt function at all. when i try to click allow third party storage nothing happens a check dosnt even apear in the box. if i try to move the slider it just resets back to none. i thought 10kb was the default for all websites... but i cant change the default either.
  • Chris Campbell
    May 4, 2010
    Apr 5, 2012 4:27 PM   in reply to Arcinsanity
    Could you try the steps outlined in this FAQ to see if they help?
    Unable to set Flash Player Settings (Windows)
    Jul 25, 2012 12:29 PM   in reply to Arcinsanity
    I don't have Win7 but should not matter which windows you have.  Location and values for this *STUPID* top secret config file I am about to refer to should be the same for any version Windows.
    In fact, after reviewing your issue again, you might simply be victum of corrupted 'settings.sol' file.  If that is the case you might try using only the first 2 steps in my hack instructions.  After you complete step #2, just delete the 'settings.sol' file, restart your browser, go run a Flash video and Flash Player will see the config file is missing so it will create a nice clean virgin copy from scratch.  Can't hurt to try.
    http://forums.adobe.com/message/4566499#4566499
    Now what I was about to suggest at first, if you have a slight understanding of hex code and want make permanent adjustment to the default setting then try following my hack, step 1 all the way through to step #6.  WOrking really great for me.  Not totally hating the app and cursing the programmer every time I use it now.
