WMB-mdillon
Cannot uninstall Adobe Flash Player 11 Active X
Apr 4, 2012 11:57 AM
Hello,
I am hoping someone out there can help.  I have been having a hard time uninstalling Adobe Flash Player 11 Active X from a large group of Windows XP SP3 PC's.  I run the latest Adobe Flash Uninstaller via a script and when I go into Add/Remove Program, I still see Adobe Flash Player 11 Active X listed there.  (I have hopefully attached a picture)add remove Flash.JPG
As you can, hopefully, see, it looks a little funny as the "Click here for more support info is missing."  What's more is when I go to http://www.adobe.com/software/flash/about/ to test the Flash install using Internet Explorer 8, I get prompted to install Adobe Flash.  (Hopefully the second picture shows up)
I have tried running my script written as this:
"<network location>\uninstall_flash_player_32bit.exe" -uninstall -force and that does not work.
I also tried running a Powershell script and that does not work.
I did a search on the PC for flash.ocx and swflash.ocx and tried the regsrv32 -u trick and that does not work.
As a last resort, I even tried running the Remove from one PC in Add/ remove programs to just see and I get this error:
I even click Browse and point this to the loation that has a copy of this file and I then get this error:
The only solution that really works is when I use Microsft's Installer Cleanup Utility and then run the Adobe Flash uninstaller again.
This is fine and dandy except I have MANY PC's that this has happened to and I would really like a foolproof way to completely remove Adobe Flash Player.  This needs to happen because I cannot successful install the latest version of Adobe Flash Player until this corrupted version gets removed.
Can anyone offer a solution?
Thanks.
matt
PS - Nice job updating the forums Adobe.
Branched to a new discussion.
    Apr 4, 2012 7:46 PM   in reply to WMB-mdillon
    Not sure why this is happening; the only thing I can think of that you may not be using the latest uninstaller?
    Download: http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
    Can you post the contents of the FlashInstall.log file (from C:\Windows\system32\Macromed\Flash) from one of the failed uninstalls?
  • Chris Campbell
    May 4, 2010
    Apr 5, 2012 11:16 AM   in reply to WMB-mdillon
    I'll forward this to our installer team, but as pat mentioned we'll need a FlashInstall.log from one of the affected systems.
    Where do I find the Flash Player installation log on Windows?
    Chris
