eobet
Rounded corner with outside stroke leaves gap
Apr 5, 2012 5:52 AM
I just got the trial of Illustrator CS5.5.1 and tried the following:
Set document to use pixels.
Draw a gradient filled rectangle.
Set 1px wide stroke on the outside.
Use the stylize effect rounded corners set to 2px.
Why did I get a gap?
    Apr 5, 2012 6:00 AM   in reply to eobet
    Turn off "Align to pixel grid" in transform panel. And please read about this feature, a search via Google should keep you busy for quite a long time.
    Apr 5, 2012 6:03 AM   in reply to eobet
    Is "Align to Pixel Grid" (Transform panel) turned on for the object?
    Apr 5, 2012 6:19 AM   in reply to eobet
    It's not "broken". It just does what it's meant to do.
    You only need to be aware of what it causes when applied improperly.
    Apr 5, 2012 7:14 AM   in reply to eobet
    Of course not.
    But since the function is intended for the output to screen you should maybe switch to pixel preview and see if it's still there...
    Apr 5, 2012 2:24 PM   in reply to eobet
    The Align to Pixel Grid idea in AI is a callow draft. Only obedient AI advocates would praise it.
