Disable Highlight Field For Particular Field
Apr 5, 2012 2:05 AM
We are designing a PDF Form in LC designer and would want to disable highlight of a text field. We are presently using app.runtimeHighlight = 'false'; for the same on mouse enter and mouse exit. But is there any way to disable the highlight of particular field all the time.? Or any solution that on entering that page highlight option is disabled?
    Apr 5, 2012 7:10 AM   in reply to sheela.do
    You can not do that if you use the application object to highlight field. You can set and unset the border on individual fields either when created or during processing. You may have an issue if a user turns on form field highlighting.
    Apr 9, 2012 4:40 AM   in reply to sheela.do
    "Highlight fields" doesn't highlight read-only fields, so you can set it to
    be read-only.
    By the way, the correct syntax for setting the runtimeHighlight property is:
    app.runtimeHighlight = false;
    Not:
    Apr 9, 2012 5:12 AM   in reply to sheela.do
    I don't know of one... What's your reasoning behind this, anyway?
