Sameer G
How do I specify folder and file options for memory cards in LR4?
Apr 4, 2012 7:54 AM
Tags: #lightroom #copy_files #lr4 #import_files #memory_card_reader #memory_card #destination_folder
Hello!
I have read the sections Set import and file-handling preferences and Specify Auto Import settings in the manual. But they don't seem to answer my question. The other stuff that's written about importing files in Lightroom seem to only cover the import of photos to the Lightroom catalog, which is not my primary concern, although I do want them imported to the catalog as well. But before the photos can go to the Lightroom catalog they need to be improted, in other words copied over from the memory card to the local disk drive. Simply put, all I want is for Lightroom to take over the responsibility from Canon EOS Utility and behave the same way when importing/copying files to the local disk drive. How do I set up Lightroom to do just that?
I just want this type of folder and file structure:
J:\2010_08_22\IMG_0372.CR2
J:\2010_11_29\IMG_1405.CR2
J:\2011_06_17\IMG_2887.CR2
... etc!
1. First things first, where the heck do I specify the destination folder for new photos?
There is an option titled Show import dialog when a memory card is detected under the General tab in Preferences, but there is no folder destination option associated with this.
2. How do I tell Lightroom to leave original file names as they are (i.e. IMG_2887.CR2) and place them in a new sub-folder (i.e. 2011_06_17) of the destination folder (J:\) named after the capture date of the photo (July 17, 2011)?
There are a few options under the File Handling tab in the Preferences, but they don't seem to concern the importation of files to the local disk drive.
3. This maybe should have been the first question really; is Lightroom capable of importing files from the camera or a card reader to the local disk drive at all?
I sure would expect it to be able to do that, but from the looks of it I am not too confident about that.
For starters I would like it to just copy my photo files, either directly from camera or from a card reader to a destination folder of my choice, in the same fashion that Canon EOS Utility does it. I don't wat to just import the files to the Lightroom catalog and start working with the files directly from camera or memory card. Hell no! It's not an external disk drive for God's sake!
Please advise!
    Apr 4, 2012 8:30 AM   in reply to Sameer G
    Get yourself a copy of Downloader Pro from breezezsys.com
    Apr 4, 2012 8:36 AM   in reply to Sameer G
    In my opinion, it is faster, and safer to just transfer the images directly to the desired folder on the HD from the card first outside of LR. Then import from there. You want to get this transfer done as fast as possible. In the off chance that there is a computer glitch (a power fluctuation for example) you could get damaged files.
    Apr 4, 2012 8:41 AM   in reply to Sameer G
    Yes, Lightroom can copy files from card reader or camera to any disk you want, and gives you a wide variety of renaming options! You set this up in the Import Dialog box! Be confident!
    Unfortunately, I am at work, and Lightroom is at home, so I can't provide exact details on how to do this, but I'm sure someone else will be able to provide the details.
    Apr 4, 2012 9:28 AM   in reply to Sameer G
    I think what you want is on the far right side of the Import screen, towards the bottom. There is a Destination area. It may be collapsed. Just click on the small triangle next to "Destination" to expand it. All you need is there.
    Apr 4, 2012 10:22 AM   in reply to Sameer G
    I think this is little odd, because I would expect this kind of thing to be found in the Preferences. Since I always import photos to the same location I would like to be able to set it and forget it, not to be asked about it every time I want to import photos from the camera or a memory card reader. That's why I think it would be good if the destination folder could be set in the Preferences of the application, perhaps in addition to the import dialog. One does not have to exclude the other.
    I think you need to start giving Lightroom credit for having some intelligent features.
    If you set the import destination once in the Import Dialog, Lightroom remembers and uses the same folder in all future imports (adding a subfolder by capture date if you choose to do so), until you tell LR to use some other folder. There is no need to put information about your import into Preferences.
    While Lightroom is indeed able to copy files from cameras or memory card readers to local disk drives, it cannot copy them without also adding them to the Lightroom catalog. There are situations where I just want to use a photo application, like Canon EOS Utility, to just copy some photos from a memory card to a local disk drive but not actually work on them in Lightroom. This could be a situation where I already have these photos in the Lightroom catalog but they are stored on a different disk drive and I want to copy another set to a different disk drive as an extra backup copy, or when dealing with duplicate files, or slightly different versions of the files but with the same names. (UPDATE: Lightroom apparently does have an option for the purpose of creating extra backup copies on a second disk location. This is also found on the import dialog.)
    Lightroom was not designed to manage photos that are not imported into in the catalog. Yes, I know lots of other programs are available to do so, but Lightroom will not.
    Apr 5, 2012 9:46 AM   in reply to Sameer G
    Sameer G wrote:
    . Which is why I have decided to purchase Downloader Pro. Thanks all for your help. I appreciate it!
         You're welcome
         David
