Integrating Spry DataSet with YUI Calendar
Apr 1, 2012 8:00 PM
I am trying to integrate a Spry dataset with a YUI calendar. I want to do the following: (a) read dates from a simple HTML table (Spry datatset) and render the YUI calendar with those dates shaded, (b) information about an event on a particular day will be displayed when that date is clicked. Below is my complete code. I have trried as much as I can. Can anyone help me?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:spry="http://ns.adobe.com/spry">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<link href="common/css/styles.css" rel="stylesheet" type="text/css" />
<script src="SpryAssets/SpryData.js" type="text/javascript"></script>
<script src="SpryAssets/SpryHTMLDataSet.js" type="text/javascript"></script>
<script src="../YUI/2.6.0/build/yahoo-dom-event/yahoo-dom-event.js" type="text/javascript"></script>
<script src="../YUI/2.6.0/build/calendar/calendar-min.js" type="text/javascript"></script>
<script type="text/javascript">
var dsCalendar = new Spry.Data.HTMLDataSet("calendarList.html", "eventDetails", {firstRowAsHeaders: false, useColumnsAsRows: true, sortOnLoad: "column0", sortOrderOnLoad: "ascending"});
dsCalendar.setColumnType("column0", "date");
</script>
<link href="YUI/2.6.0/build/fonts/fonts-min.css" rel="stylesheet" type="text/css" />
<link href="../YUI/2.6.0/build/calendar/assets/skins/sam/calendar.css" rel="stylesheet" type="text/css" />
</head>
<body>
        <div id="CalendarView">
        <div id="CalendarViewInfo">
            <h2>Events Calendar View Control:</h2>
            <p>Click any date on the calendar below to see current and upcoming events.</p>
        </div><!-- end #CalendarViewInfo -->
        <div id="calendarDetails">
            <div id="calendar">
                <div id="yuicalendar1"></div>
// BeginWebWidget YUI_Calendar: yuicalendar1
  (function() {
    var cn = document.body.className.toString();
    if (cn.indexOf('yui-skin-sam') == -1) {
      document.body.className += " yui-skin-sam";
  var inityuicalendar1 = function() {
    var yuicalendar1 = new YAHOO.widget.Calendar("yuicalendar1");
    // The following event subscribers demonstrate how to handle
    // YUI Calendar events, specifically when a date cell is
    // selected and when it is unselected.
    // See: http://developer.yahoo.com/yui/calendar/ for more
    // information on the YUI Calendar's configurations and
    // events.
    // The YUI Calendar API cheatsheet can be found at:
    // http://yuiblog.com/assets/pdf/cheatsheets/calendar.pdf
    //--- begin event subscribers ---//
    yuicalendar1.selectEvent.subscribe(selectHandler, yuicalendar1, true);
    yuicalendar1.deselectEvent.subscribe(deselectHandler, yuicalendar1, true);
    //--- end event subscribers ---//
    yuicalendar1.render();
  function selectHandler(event, data) {
  // The JavaScript function subscribed to yuicalendar1.  It is called when
  // a date cell is selected.
  // alert(event) will show an event type of "Select".
  // alert(data) will show the selected date as [year, month, date].
      var formattedDateString = data[0][0][1] + "/" + data[0][0][2] + "/" + data[0][0][0];
        var r = dsCalendar.findRowsWithColumnValues({"Date": formattedDateString }, true);
        var region = Spry.Data.getRegion("eventDetail");
        if(r){
        dsCalendar.setCurrentRow(r.ds_RowID);
        region.setState("showEvent", true);
      } else {
        region.setState("ready", true);
  function deselectHandler(event, data) {
  // a selected date cell is unselected.
  // Create the YUI Calendar when the HTML document is usable.
  YAHOO.util.Event.onDOMReady(inityuicalendar1);
// EndWebWidget YUI_Calendar: yuicalendar1
                </script>
           </div><!-- end #calendar -->
            <div id="events">
                <div spry:region="dsCalendar" id="eventDetail">
                  <table cellpadding="5" cellspacing="5">
                    <tr>
                      <th spry:sort="column0">Column0</th>
                      <th spry:sort="column1">Column1</th>
                    </tr>
                    <tr spry:repeat="dsCalendar">
                      <td width="120px" align="right" valign="top"><strong>{column0}</strong></td>
                      <td align="left" valign="top"><div align="justify">{column1}</div></td>
                    </tr>
                  </table>
                </div>
                  <div>No events to display</div>
            </div><!-- end #events -->
        </div><!-- end #calendarDetails -->
    </div><!-- end #CalendarView -->
</body>
</html>
My calendarList.html file contains one HTML table with the id="eventDetails" and contains 4 columns, 'Event Name', 'Event Date', 'Event Location' and 'Event Details'. Currently I have two events on two different dates. One event date shows on loading the page. Events details do not show when a date is clicked. Does not matter which date is clicked, the event that showed when the page loaded does not change. If there is more than one event on a particular date, that event that showed when the page loaded still does not change. Can anyone help me. Thanks in advance.
    Apr 2, 2012 6:57 AM   in reply to barb2466
    Have a look here http://www.dmxzone.com/go?19516
    Gramps
    Apr 2, 2012 4:10 PM   in reply to barb2466
    barb2466 wrote:
    Thanks. Helps but does not answer the spry problem.
    I fail to see why it does not help you with your Spry problem. I am in the process of finishing off a website right now where I have employed said widget. OK I did use values from a database, but these values could just as easily have been obtained from a Spry dataset.
    Gramps
