K3NetSolutions
Retrieve xml-data from text-column
Apr 5, 2012 12:33 AM
Tags: #cfquery #coldfusion #sql #cf9
I've a table which has a field (datatype "text") that contains a xml-file. After some try and error I found out that the only way to fetch the complete xml-file from that table is to use the "FOR XML" clause of ms sql. But my next problem is, that the colum containing the xml-file is named something like "XML_F52E2B61-18A1-11D1-B105-00805F49916B" which is an invald identifier for cf.
Is there a way to access that column by its id instead of its name or what's the best way to access this column?
The SQL statement I'm using is:
SELECT XmlPackage
FROM LogK3OnChange
WHERE DealerID = IsNull(<cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.dealerid#">, DealerID)
AND LogID = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.logid#">
FOR XML RAW
Heiko
    Apr 5, 2012 1:04 AM   in reply to K3NetSolutions
    SELECT XmlPackage
    FROM LogK3OnChange
    FOR XML RAW
    Use aliasing:
    SELECT XML_F52E2B61-18A1-11D1-B105-00805F49916B as myXML
    from LogK3OnChange
    or
    SELECT XML_F52E2B61-18A1-11D1-B105-00805F49916B myXML
    from LogK3OnChange
    Apr 5, 2012 2:02 AM   in reply to K3NetSolutions
    I took it for granted your SQL is embedded in cfquery. Do you mean that, when you run "SELECT XmlPackage" the result is a column named XML_F52E2B61-18A1-11D1-B105-00805F49916B?
    Apr 5, 2012 2:49 AM   in reply to K3NetSolutions
    SELECT XmlPackage as testXML
    FROM LogK3OnChange
    FOR XML RAW
    I hope it may work.
    Apr 5, 2012 3:40 AM   in reply to K3NetSolutions
    You have the datatype of that XML column as "TEXT" of what length?
    Try to change the datatype to varchar2(4000) and check it.
    Apr 5, 2012 3:58 AM   in reply to K3NetSolutions
    Does it help when you specify the XML's root? I believe the syntax is:
    FOR XML RAW, ROOT('myRoot')
