mfarfan18
LR4 Disc won't install…help!
Apr 5, 2012 1:07 PM
so I insert the disc on my mac...nothing happens. So I go into the disc click on the adobe LR 4 pkg...and it asks to pick a program to "open it with"!!!
what do I do. I don't know what to pick...never had to before. I picked Adobe reader...and ofcourse that didn't work.
What am I doing wrong? do I need to dl something in order to install this?
help
    Apr 5, 2012 1:16 PM   in reply to mfarfan18
    What exactly are you clicking on?  Could please post a screen shot?
    Apr 5, 2012 1:32 PM   in reply to mfarfan18
    Go to applications>utilities>installer and select this pkg file , and check
    Apr 5, 2012 2:17 PM   in reply to mfarfan18
    Sorry , for posting incomplete info , my internet died for some reason
    Select any .pkg file, press COMMAND-I to open the Get Info window. In the section labeled "Open With" select the Installer application from the drop down list. Then click on the Change All button.
    If you dont find the Installer then It's located in /System/Library/CoreSerivces/ folder., if still not present then check on you Mac OS disc ,in  Applications/Utilities folder. You should be able to copy it onto your hard drive.
    Apr 5, 2012 2:35 PM   in reply to mfarfan18
    If you are missing the Installer.app then it will not be possible for you to install your software or most any software.  Were you able to locate the /System/Library/CoreServices folder as Manish suggested?
    Apr 5, 2012 2:44 PM   in reply to mfarfan18
    No, wait....
    Do you have the disc of Lion or you will install it from internet.
    Apr 5, 2012 2:45 PM   in reply to Manish-Sharma
    You can try doing an Archive and Install of your OS from your recovery partition.  I would highly recommend you contact Apple though directly for them to advise you on the process.
    Apr 5, 2012 2:56 PM   in reply to mfarfan18
    Great then , open the drive and do not run the lion installation , just open it and look under applications/utilities, if found , copy and paste on the default location mentioned above , if not found contact Apple
