Date nodes in XML
Apr 05, 2012 Apr 05, 2012
I'm working with XML in AS3. I'm loading in some xml that has dates in a format like:
2011-1-12-10-00-a
I am converting those to actual Flash Date so I can compare them and use the methods of the Date class, etc. I would prefer to convert them once and then store them back in the XML node they came from.
Is it possible to store complex values like date or what have you in an XML?
ActionScript
945
Community Expert , Apr 06, 2012 Apr 06, 2012
yes, or more directly use:
var ms:int=date.getTime();
var newDate:Date = new Date(ms);
you can but not as a date object.  you have to serialize your date object, save that to your xml and then unserialize your date object.
that may be less efficient than using a string to save to your xml and converting that back to ta date object.
Thanks.
Okay a follow up question.
If I store the number of milliseconds of the date using date.getValueOf(), is there an easy way to change those milliseconds back to a date object?
Never mind found it myself: date.setTime()
Apr 09, 2012 Apr 09, 2012
Thanks. Strange that they seem to do the same thing.
