Hey all,
I've run into a problem that I'm sure has been a popular one for many. I recently edited a photo of mine in Photoshop CS5 and when I save it to JPEG format and open it, the color is completely different. I've searched the web and have tried some of the solutions that have seemed to have helped others but for me it hasn't worked such as using sRGB and changing the working spaces to adobe RGB (1998). Both of which hasn't worked.
Any help would be greatly appreciated.
No answer but a few questions. What color space was the image edited in? When you saved it as a Jpeg file did you save it with an embedded color profile? When you opened the jpeg images did you open it with a color manages program like Photoshop or a non color image viewer or non color managed web browser?
Seeing as I'm a "newbie" when it comes photoshop, but to take a stab at your
first question, under Edit> 'Color Settings' it is set to 'North America General Purpose'.
2). If I saved it with an embedded color profile, I'm not even sure how to tell.
3).No I opened it using Microsoft Office Picture Manager and/or Windows Picture and Fax Viewer
Thanks Lundberg for the insight. I went ahead and adjusted the work space to ProRGB and proceeded to edit a photo. Then I started over and used the Adobe RGB (1998).
Both worked a little better than the Default profile that I'd been using. However, the colors still aren't spot on as they were in Photoshop once I'd saved them over from psd to jpeg.
time to get a mac i guess
That’s not my point at all – Mac OS has issues and I don’t consider it superior to Windows.
I just don’t know Microsoft Office Picture Viewer, so I don’t know how to trouble-shoot it – and the issue seems to be with that application if the image has an embedded profile and it is disregarded.
I know...just humoring myself. I am going to trouble shoot the program and research it a little further to see if I can get down to what is causing this issue. Thanks a lot thought, you all have been quite helpful and enlightening.
Interesting tid bit....
I took the image (the "second" one that I took a screenshot of in post 10 on the bottom) and uploaded it to ImageShack. When I opened it in ImageShack, I see that it looks just the way it did in Photoshop.![]()
However, when I go back to my desktop and use the Micorosoft Picture Viewer program, it comes out slightly distorted. So I can atleast deduce the fact that the issue lies within the viewer.
Photoshop is a color-managed viewer — its reads a source profile (or applies its working profile) and Converts it to the monitor profile for a theoretical true-color display.
Your Microsoft Picture Viewer program — if it is not matching Photoshop — is more than likely not a color-managed viewer (or the document does not contain an embedded ICC profile) — Microsoft Picture Viewer is more than likely merely sending the source RGB straight through to the monitor unchanged.
This would be very easy to prove in Photoshop by opening the image in Photoshop so it appears correctly, then: View> Proof Setup: Monitor RGB
First, open the image in the program that you call "Microsoft Picture Viewer program" and read carefully the name of the program. The name of the Microsoft programs is usually on the top left corner of the title bar and may be proceeded with the name of the currently open file. If you can't find it look Help > About menu of that program.
On Windows 7 the default image viewer is called "Windows Photo Viewer" and is fully color managed - it will display images with any profile with identical colors as Photoshop.
If the program that you are using to view the image is not color managed it cannot display identical colors with the color managed programs like Photoshop unless the image is in the color space of your monitor (not affected by color management)
Second, any changes in the color settings in Photoshop will not have any effect on the currently open images with color profiles. So, before starting anything to do with color management of an image the first step is to check what is the current color space of the document. In post #10 c.pfaffenbichler told you how to check that.
