I just successfully installed LR4, however, it won't open the application because it says it is not supported on this type of Mac. I have a Intel MacBook Pro, OS 10.6.8, with 2 GB RAM, and enough HD space to load and run. I already have LR3 installed and it's up to date. What gives?
Which MacBook Pro model exactly? How was the operating system installed? Straight off the DVD or by patching an older version incrementally? Anything else we may need to know?
Mylenium
It's a MacBook Pro 2.16 GHz Intel Core Duo. The computer's operating system was already installed on the computer when purchased and has been updated regularly as updates are available. LR4 was installed from the recently purchased DVD. I bought the upgrade since I already had LR3 but I think it installs a complete version. I'm also running PS CS5.
Mmh, sounds odd. Any chance you could go fishing for install logs? This might reveal some more details.
Mylenium
Please excuse my ignorance but where do I find install logs for LR4? All I found were Photoshop install logs. Photoshop seems to run fine. Only LR4 has this problem.
The Intel Core Duo processor is a 32-bit processor. Per the system requirements - http://www.adobe.com/products/photoshop-lightroom/tech-specs.html you need a 64-bit processor. The Intel Core 2 Duo is the 64-bit version.
Awww, rats. Didn't think of that, but Jeff is no doubt right about this...
Mylenium
That leaves a lot of us out in the cold with perfectly good computers. I'm certainly not going to replace my computer just to satisfy Adobe. Seems they just limited their audience. I'm sure it was doable at 32 bit. In these economic times it would be descent to keep that in mind. So what do I do with a useless software purchase and more money wasted. If I missed that spec then I'm sure others will too. And why does it successfully load when it won't work. Hardly successful! Not too happy with Adobe right now.
Arnold you are certainly welcome to return the product. You can find the process for submitting a refund request at Return, change Adobe orders | North America - http://helpx.adobe.com/x-productkb/policy-pricing/return-change-orders-north-america.html.
I have a similar issue with my personal MacBook Pro as it is using an Intel Core 2 Duo at 2.33 ghz. While it can run 64-bit applications I am not able to run Snow Leopard in 64-bit mode without doing unsupported, by Apple, modifications to the OS.
You might also find this document useful 64-bit OS and Adobe applications - http://helpx.adobe.com/creative-suite/kb/64-bit-os-applications.html and it might help explain why we are transitioning many of our applications to 64-bit. It is especially useful for applications which can make use of a lot of memory such as image editing and video editing/processing applications.
