Spry vertical menu bar not working in IE
Apr 1, 2012 8:16 PM
I have a simple (well I thought) Spry Vertical Menu bar in my site that works great in every browser except - in you guessed it Internet Explorer.  One of the sub-items moves right on top of a main menu item when it's hovered (is that a real verb LOL) over; so you can't really even click on that particular main menu item...  Here's the web site:  www.meridianwaterfiltration.com
Any help would be appreicated!!
    Calculating status...
    Apr 2, 2012 3:30 AM   in reply to fourwhitesocks
    The validator says you have a missing <tr> element here:
    <table id="sample" cellspacing="2">
    <tr>
          <td class="data"><a href="index.html">Home</a></td>
    I wonder if that's it?
    Martin
    Apr 2, 2012 5:34 AM   in reply to fourwhitesocks
    Martin has probably given you your answer, but I wanted to express my admiration for your logo, typography and background design.  Just perfect.
    Also spotted a typo for you.  In your menu"Contacts Us"
    Apr 2, 2012 11:22 AM   in reply to fourwhitesocks
    -----del, wrong suggestion, bad advice-----
    Hans-Günter
    Apr 2, 2012 7:10 AM   in reply to fourwhitesocks
    Add/modify the following
    ul.MenuBarVertical {
        width: 10em;
    Gramps
    Apr 2, 2012 7:33 AM   in reply to fourwhitesocks
    I still see
    ul.MenuBarVertical
    list-style-type: none;
    font-size: 100%;
    cursor: default;
    width: 0em;
    padding: 0;
    margin-top: 75px;
    font-weight: bold;
    Gramps
    Apr 2, 2012 7:49 AM   in reply to fourwhitesocks
    Please open the site in Firefox, right click the page and choose 'view page source' then, in the resulting window, click on SpryAssets/SpryMenuBarVertical.css and view the script.
    Gramps
    Apr 2, 2012 8:27 AM   in reply to fourwhitesocks
    Yep. You are right, you have not changed anything at all. Have a look at the screen dump below
    Gramps
    Apr 2, 2012 8:53 AM   in reply to fourwhitesocks
    Gramps is pointing out that you may have changed the width on your local file,
    but you have not uploaded the revised SpryMenuBarVertical.css to the server
    Apr 2, 2012 9:26 AM   in reply to fourwhitesocks
    Check to be sure you are uploading to a folder in your root directory named "SpryAssets"
    Apr 2, 2012 9:35 AM   in reply to fourwhitesocks
    Looks like you got it now
    Apr 2, 2012 9:55 AM   in reply to fourwhitesocks
    That's just the way IE works... they've always felt free to play fast and loose with standards.
    You could ask Bill Gates the next time he posts here *grin*
    Apr 6, 2012 4:49 AM   in reply to fourwhitesocks
    Hi everybody,
    I've had the same problem with the spry menu in IE9. Hoover on main menu is ok but not sub menu coming.
    After some research I found this solution. I hope that will help you .......
    Put this line in the head section of your html page
    <meta http-equiv="X-UA-Compatible" content="IE=9" >
    Enjoy ...
    Apr 6, 2012 5:11 AM   in reply to Scouby_12
    Welcome Scouby
    Thanks for jumping in here...
    Much appreciated
    Apr 6, 2012 7:43 AM   in reply to fourwhitesocks
    Hi fourwhitesocks,
    If it's ok for you, I suppose you don't need this line. (but maybe it's better to put it to be sure it's ok on the differents clients using IE9)
    I just find it cause here, on the same IE9 configuration but on the differents computers, the submenus list didn't come. Was just the hoover on the title menus and no more.
    I don't know why with some IE9 it's ok and with some others IE9 it's not ok.
    This is a part of the mysterious of microsoft maybe.
    May 4, 2012 9:13 PM   in reply to fourwhitesocks
    I am also having the same sort of problem... I think. My head is spinning having just spent the last 2 days experimenting with Spry Menus.  I have one site with 2 layouts (home page & content pages) - each containing 2 vertical Spry menus. In both instances, using IE7 & 8, the 2nd or right menu throw the drop down way off from where it should be appearing. Of course works fine in Chrome on the same PC and all browsers on Mac.
    The site is: www.stride.on.ca
    I've been racking my brain over this, reading all sorts of forums but without success.
    PLEASE HELP! SOMEONE?
    May 4, 2012 9:36 PM   in reply to Elevate_Me
    Bcause you have set the width to 100%, the menubar will go feral in IE
    ul.MenuBarVertical
    margin: 0;
    padding: 0;
    font-size: 180%;
    cursor: default;
    width: 100%;
    font-weight: normal;
    text-transform: none;
    color: #FFF;
    border: 0;
    I do not know why you have got two complete style sheets for each of the two menu bars. All you need to do is place the rule that you want to change into a selector that uses the ID of the menu bar as per
    ul#MenuBar1.MenuBarVertical a {
        background-color: red;
    Gramps
    May 5, 2012 5:48 AM   in reply to Ben Pleysier
    Thanks for the reply, though I'm unsure what the solution to the width issue is. I've since made it 8em (noticed that as an earlier solution on the thread), not perfect, but anything else moves the menu out of the light blue area. However the submenus are way off to the upper right.
    Weird that the left/centre SPRY menu works fine but not this one?
    Really appreciate the help - thank you!
    PS: As for me, I'm just trying to get back into the game - been stuck using images & tables till now. Working at trying to improve my understanding of CSS, I'm sure there is plenty of better ways to implement it than I have.
    May 5, 2012 5:57 AM   in reply to Elevate_Me
    Forum etiquette says "Please start a new topic giving a short description of the problem and a link to the site."
    Gramps
