Map artwork to a 3D object
Apr 5, 2012 3:39 PM
    Apr 5, 2012 3:39 PM   in reply to Community Help
    I'm trying to map art to a corrugated surface on a 3d shipping container I made in Illustrator. When I'm in 3D Extrude & Bevel Options: Map Art, there are 378 surfaces on my object. This makes mapping to one side of my object nearly impossible. I'm looking for a way to somehow merge or group the surfaces in such a way that each side of my shipping container is a single surface, rather than 100s of them. Perhaps this isn't possible in the current version, but it would make this feature a whole lot more useful to me if it was possible.
    Apr 5, 2012 4:07 PM   in reply to jodyr
    Do it the other way. Make the corrugations by means of gradients at the back of the artwork you want to map to the object and set the overlying stuff to multiply in the Transparency panel to pick up the light and dark of the gradient. Something like this
    It will take a little experimenting and you can make several symbols to map to the different sides.
    Apr 5, 2012 4:16 PM   in reply to Larry G. Schneider
    Hi Larry. Thanks for the workaround. Unfortunately, it's not going to work for my purposes. The scene I am depicting is a close up of a container at an oblique angle, so I need my artwork to look wrapped around the ribs. I've made an object in Strata CX and imported it into Photoshop.
    Apr 5, 2012 8:26 PM   in reply to jodyr
    Maybe you are going about it in the wroing way as to how you create the corrugated object and perhaps this video will lead you in the right direction.
    http://www.wadezimmerman.com/videos/CorrugatedExtrudeMapping.mov
    Apr 6, 2012 5:07 AM   in reply to jodyr
    The ribs have to be constructed in a  way that there are all smooth points on the side:
    http://www.vektorgarten.de/img/tut/map-container.png
    Apr 6, 2012 9:36 AM   in reply to Monika Gause
    Monica, this is awesome, and a trick I will use many more times. Thank you! --jody.
    Apr 6, 2012 9:39 AM   in reply to Wade_Zimmerman
    Hi Wade. Thanks a ton for taking the time to make the video. You've provided a solution as well. The lesson that you and Monica have taught me is that Illustrator will see a single surface in 3D mode when smooth points are being used. I was using corner points. --jody.
    Apr 6, 2012 10:45 AM   in reply to Community Help
    Thanks to everyone, and especially Monica, for helping me to solve this problem! --jody.
    http://atman.net/IFTF/container.png
    Apr 6, 2012 11:14 AM   in reply to jodyr
    Oops. I made the mistake of moving my object. I went from 4 to 42 surfaces. This is a very buggy feature. Once again, I'm having to figure out work arounds.
    Apr 6, 2012 11:19 AM   in reply to jodyr
    The exact nature of the bug is that upon resizing, Illustrator loses track of the fact that all my points were smooth, the result being that the surface gets arbitrarily divided up.
    Apr 6, 2012 1:44 PM   in reply to jodyr
    Instead of resizing using the scale tool or the selection tool  since it has an effect you want to resize it using another Effect which is;
    Effects>Distort and tr4ansform<Transform that is the right way to scale an effect.
    However you should also make certain you have Scale Strokes and Effects enabled in th eransform panel or your Illustrator Preferenbces under the general tab.
    Read about workjing with effects in the help files.
    Apr 6, 2012 1:48 PM   in reply to Wade_Zimmerman
    Thanks Wade.
    Apr 6, 2012 4:04 PM   in reply to jodyr
    You're welcome!
    This is one of those threads that which should be marked answer so if you mark Monika's response as the correct answer it will help other users in the future.
    Apr 6, 2012 4:26 PM   in reply to jodyr
    To eliminate the resize problems, with 3d objects, you can also make the object a symbol. Then you can edit a symbol instance by resizing, rotating, etc., without changing the 3d affect.
    Apr 7, 2012 12:16 PM   in reply to Wade_Zimmerman
    Wade, you unearthed a flaw in this auto-forwarding of "Community Help" questions: only the Original Poster can award points and mark a question as answered ...
