Export from Lightroom to Facebook
Mar 15, 2012 6:41 PM
Replies 1 2 Previous Next
    Calculating status...
    Mar 15, 2012 6:41 PM   in reply to Community Help
    This doesn't work. Facebook replys " No registered app for this extension".  Facebook then opens to my home page, no instructions.
    Mar 15, 2012 7:14 PM   in reply to ED_S_SMITH
    Yes seems to be a problem with the Authentication Token as if you delete the application and re-register you get the following message:
    "Failed to receive the authentication token." and clicking on it brings up "lightroom://..." under the Facebook Authorization URL
    It's all explained here http://developers.facebook.com/docs/authentication/ and since the process was updated in October 2011 it may have changed because LR4 is a new application.
    Apr 2, 2012 6:49 PM   in reply to Community Help
    I'm having the same problem "Failed to recieve the authentication token". I delete the original Lightroom app from the facebook account in an attempt to solve some upload issues I've been having. Now it doesn't work at all because it can't complete authentication. Looks like Lightroom is registered correctly if I go to my facebook account on facebook. Lightroom doesn't know it though.
    Apr 2, 2012 7:34 PM   in reply to brianwrx
    I found I was able to complete it only using Microsoft IE on windows using the following method:
    1. Delete Lightroom from the Apps on your account
    2. Re-authorize from Lightroom (make sure Microsoft IE is the default internet browser)
    3. When authorizing IE will go to an invalid URL - just copy all of the URL
    4. When Lightroom notifies "Failed to receive the authentication token." Click on it to bring up "lightroom://..." under the Facebook Authorization URL
    5 Replace "lightroom://..." with the URL you copied and it will be authorized
    Note it doesn't seem to work with either Firefox or Google Chrome
    Apr 3, 2012 3:47 PM   in reply to BKKDon
    This works, thanks
    Apr 3, 2012 6:11 PM   in reply to BKKDon
    Yes, thanks BKKDon! That worked!
    Now let's see if I can actually upload an album   It would freeze after 2-4 photos before which is why I was attempting to reauthorize.
    Update: No. Still fails to upload to facebook. Of course I can't upload into Facebook even with their own web browser based uploaded either...
    Apr 6, 2012 9:14 AM   in reply to Community Help
    I kept having the error using the facebook publishing function in LR4. It kept saying "Return Error #10 Application's Activtiy Privacy for User is insufficient to perform this action"
    Apr 6, 2012 3:02 PM   in reply to Community Help
    im having many keychains requests, Ill check "always" but Ill get many many requests from Snow Leopard (or LR4.1 rc).
    With LR3 no error nor trouble about facebook publishing... some ideas?
    Apr 15, 2012 1:06 PM   in reply to Community Help
    Hi all
    I have problem with LR4. I do not have problem with new album on facebook but if I want update or upload new pictures to existing album, I recieved error.
    LR shows two messages:
    1) error: photo upload failed
    2) Can´t update this collection. Photo upload failed
    thank you for any help!
    Karel
    May 27, 2012 9:07 PM   in reply to CarlosRigga
    Thank you so much for this post, worked perfectly!
    May 28, 2012 4:16 AM   in reply to Community Help
    worked fine after updating to 4.1 RC.
    Jun 1, 2012 11:57 PM   in reply to Community Help
    Just installed latest update,and now everytime I go to the Publishing manager to get authorised to use my FB account,it says i.m authorised but i cant save my settings because there is an internal problem with my LR plugin...it worked fine before ?!?
    Jun 26, 2012 1:51 PM   in reply to Community Help
    I cannot choose a Facebook album to upload to. It uploads everything to my Wall (which was special just now, as I didn't know that, and now I have a feed with 59 photos as separate entires).
    I go to edit the Facebook publishing service, and there is a drop-down to select an album, but it is set to Wall Photos and is greyed out, so I can't change it.
    Jan 2, 2013 7:43 AM   in reply to EdHoover
    Samissue as EdHoover here.
    Any help ?
    Jan 9, 2013 8:04 AM   in reply to EdHoover
    remove LR apps into facebook, remove account facebook into LR e restart
    I'havent any issue from 4.1 to last release.
    Jan 9, 2013 7:44 PM   in reply to Community Help
    Thanks for the info. My photos are being published just fine, however, they are not published to Facebook in the order they are in the collection. Since there is no way to 'reverse order' in Facebook any more (you can only drag and drop individual photos), is there something I should be doing differently to get them to upload in the original order I intended? Everything looks normal in Lightroom 4.3, and I am completely up to date on software. Any ideas?
    Jan 9, 2013 7:45 PM   in reply to Community Help
    Jan 30, 2013 5:41 PM   in reply to iloveskipper
    Did you ever figure out how to resolve this?  I'm having a similar problem
    Feb 17, 2013 4:26 PM   in reply to ED_S_SMITH
    No it doesn't.  Glad it did for you, but not me.  There is no invalid URL to copy from.  None of these solutions work.  Anyone have any fresh ideas or should Adobe pull their heads out of their butts and make programs that work without and undue amount of hassle.....
    Feb 18, 2013 12:28 PM   in reply to brianbhood
    I'havent any issue from 4.1 to last releases.
    Please, its most important to remove facebook apps, then remove into Lightroom and again resyncro account, adding it to facebook apps!!
    Feb 18, 2013 1:15 PM   in reply to Larsenio
    Thank you for the response but I'm sorry, I do not understand why you're saying to do.  The instructions are not clear to me.  Do you mean remove the Lr app in the Facebook account?  If so, I tried that and it didn't work.  What does "remove account facebook into Lr and restart" mean?  What does remove into lightroom and re synchro mean?  How do you do that?
    Brian
    Feb 18, 2013 2:02 PM   in reply to brianbhood
    sorry for my bad english too..
    1. yes, remove Adobe Photoshop Lightroom application in Facebook account
    2. yes, remove Facebook account into Lightroom
    3. make a new account into Lightroom, with same Facebook settings
    4. accept Adobe Photoshop Lightroom policy into Facebook
    must work.
    Feb 18, 2013 2:12 PM   in reply to Larsenio
    Thank you, we're still not quite there.  How do you do step #2, remove facebook account into Lightroom?  I see no way to do that. There is simply a button to authorize and that sends me to my web browser to log into FB.  How do I scrub Lr of any old FB info?
    Thanks for all your help.  I appreciate your time.
    Brian
    Feb 18, 2013 4:23 PM   in reply to Larsenio
    I'm sorry and I know you're trying to help me but the procedures you're suggesting are the very same as those listed above in this posting and they do not work, at least for me.  I've tried these procedures numerous times that you (and many others) suggest and they don't work despite some claims that they do.  That's why I'm asking for fresh ideas from anyone who has solved this problem.
    #1) I have deleted the app from Facebook as you suggest.
    #2) I then go back into Lr and click authorize.
    #3) I even changed to Internet Explorer as the default browser as some have told me that Firefox is the problem.
    #4) I do what Facebook asks of me inside IE and it accepts it.
    #5) Lr then gives me the "did not accept authorization token error".
    I have done these procedures over and over many times and they do not work.
    I still don't see the answer to how do you remove "Facebook account into Lightroom"?  All this link shows me is how to create one (asssuming the procedures work, which they do not).  It also does not help with what to do if the procedures fail.
    I need a fresh idea if anyone has new info as these procdures do not work and doing the same thing over and over that does not work is a waste of time.
    Feb 19, 2013 12:15 AM   in reply to BKKDon
    Will this procedure affect the previously uploaded pictures and albums ?
    I mean, will Lightroom keep the "link" to the pictures and albums previously uploaded to Facebook ?
    Feb 19, 2013 4:36 AM   in reply to Sammy_70
    this procedure dont affect previously uploaded pictures, these picture must be removed from Facebook.
    @Brian, these procedure arent so easy, but be done with cookies and temp files cleaned before... read comments.
    Feb 19, 2013 5:00 AM   in reply to Larsenio
    @Larsenio: what do you mean by "...these picture must be removed from Facebook" ?
    Thanks.
    Feb 19, 2013 6:33 AM   in reply to Larsenio
    Again, I'm sorry, but I have no idea what you mean.  What does "be done with cookies and temp files cleaned" mean?  What are the procedures to do that?
    Feb 19, 2013 1:42 PM   in reply to Sammy_70
    Sammy, if you need to remove some albums from FB, you must remove it manually.
    Lightroom fb's plugin dont remove anything!
    Feb 20, 2013 12:57 AM   in reply to Larsenio
    @Larsenio: Good, thanks for your feedbck :-)
    Feb 21, 2013 12:35 PM   in reply to brianbhood
    Does anyone have any fresh ideas how to solve this problem?  The delete app from facebook and re-authorize from Internet Explorer approach does not work.
    Thanks.
    Feb 22, 2013 8:20 PM   in reply to brianbhood
    Larsenio, since you're "tried and true" methods didn't work, I had to figure it out myself.  The answer to the Facebook problem is to uninstall the program, then do the following procedures:
    First run Microsoft Fix It.  That enabled one to run Lr uninstall.  Uninstall Lr.  Then go to the following link and do a manual uninstall of Lr to clean up residual files.
    http://helpx.adobe.com/lightroom/kb/preference-file-locations-lightroo m-4.html
    Then run your registry clean up.  Next do a computer restart.  Now you should be ready to reinstall and after doing all this, you will be performing a virgin install (like the computer had never seen Lr before).  Do the install and run the Facebook link up procedures within Lr and it works.
    Thanks for trying, but the procedures mentioned above do not always work.  This one worked for me.
    Feb 23, 2013 3:12 AM   in reply to brianbhood
    there is no need to unistall Lightroom:
    1. remove facebook application "adobe photoshop lightroom"
    2. remove Lightroom publish services into lightroom
    3. make a new publish service facebook
    4. ie/firefox etc.. accept application "adobe photoshop lightroom"
    5. just do it!
    every step need to close and restar Lr app - see feeback.
    http://help.adobe.com/en_US/lightroom/using/WS2bacbdf8d487e58258d44eb8 130dd470977-8000.html
    Feb 23, 2013 3:58 AM   in reply to Larsenio
    Yes there is.  I've said several times your procedures DO NOT work and do not make sense.  People cannot follow what you're telling them to do.  I'm trying to save someone else the countless hours of wasted time that I had following what you tell them to do.  My solution works and it's a fresh approach.
    Please do not keep wasting people's time with procedures that do not work!!
    Feb 23, 2013 4:22 AM   in reply to brianbhood
    Brian, it worked fine for me and many users without unistalling Lightroom, someone also replied above - could be you got some trouble with ur installation.
    Unistalling LR its wasting time but if you get a working approach in that scenario, well done.
    Have you removed cookies and temporary internet files?
    IE doesnt works fine if you dont clean this one - must be executed step-by-step, not so easy but worked fine by many users.
    Feb 24, 2013 8:47 AM   in reply to Larsenio
    No, you did not respond to me about how to remove cookies and temp internet files.
    Feb 24, 2013 9:30 AM   in reply to brianbhood
    Brian, google -> http://www.inf.aber.ac.uk/advisory/faq/434
    How do I delete cookies and temporary Internet files from my web browser?
    Mar 14, 2013 6:06 AM   in reply to CarlosRigga
    I've tried all the workarounds but I'm still getting this error:
    Photo upload failed, but no error string was returned from Facebook.
    Lightroom 4.3 - Mountain Lion
1 2 Previous Next
