grandill
Premiere Pro problem, it doesn't export my project,shows no error
Apr 5, 2012 5:11 PM
Hello everyone, I've been working on a short film for a while and now that it's finished I want to export it. The only problem is, that I can't! The export freezez at 10% sometimes 20% without showing any sign of error or anything. Is there any way to track the source of this freezing? I've done the rendering of the project from the work area and it's all fine, but when I export,it bugs on me. Any help please? I've been working with adobe dynamic link, also using some effects from after effects. Is there any kind of verification that I can do in order to find the problem?
    Apr 6, 2012 6:59 PM   in reply to grandill
    Had a similar problem that was solved in my case by having the AE project open that was the target of the dynamic links while exporting/rendering.
    Apr 6, 2012 7:52 PM   in reply to grandill
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainspector.massanti.com/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    If you have a red line over the timeline after importing a video and before adding any effects... your project is wrong for your video... read above about codecs
    Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
    The easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    Apr 8, 2012 5:33 AM   in reply to grandill
    Copy the timeline into a new timeline and replace some of the large and complex DL with uncompressed avi's (or some other intermediaire codec) from AE.
    See if that will help.
    Apr 8, 2012 8:04 AM   in reply to grandill
    Uncompressed is w/o loss.
    You have to try something.
    Apr 9, 2012 6:54 AM   in reply to grandill
    Premiere sometimes moves in mysterious ways
    Glad you are up an running again.
    Apr 9, 2012 6:55 AM   in reply to grandill
    Another possibility:  Open GL has been notoriously flaky in Ae.  Turn Open GL off in Ae (in Preferences>Previews), and see if that helps.  You could also see if any of your plugs have an "Use Open GL" or "Use GPU" checkbox, and uncheck them.
    "I tried now to export while AE project was open also and it crashed, the error said "a problem ocurred when processing OpenGL commands."
    Apr 16, 2013 11:37 AM   in reply to Jim Curtis
    THANKS!! I've been trying to crack down the root of this issue for weeks. It has to due with plug-ins trying to "Use GPU". For me it was Red Giants Denoiser Plug-in... Once I turned off "Use GPU" in the effects settings everything was fixed.
