There have been several discussions on the lack of real alignment tools in Titler, for both PrE and PrPro. I use a workaround to this, and just Import a "grid" image, created in PS and Saved to .PSD with Transparency. I use the same technique to build layouts for PiP and similar.
One just Imports the .PSD into their NLE (Non Linear Editing) program, as a still, or as Footage in PrPro. The .PSD is then placed on the Timeline in a Video Track above any other Clips. The Title is then placed above the .PSD. In PrE, one sees the Video below the Title automatically. In PrPro there is a checkbox to do this.
The grid in the .PSD is used for alignment of the elements/text in the Title.
Be sure to remove the grid, when you are done, or in PrPro, you can turn off visibility for its Video Track. Otherwise, you WILL Export the grid, and that is not what you will likely want to do. Do not forget to disable this .PSD, before the Export.
Attached are an NTSC 16:9 .PSD and an NTSC 4:3 .PSD, with proper PAR for each.
Hope that this helps someone, where they need better alignment in Titler in either PrE, or PrPro.
Hunt
[Edit] Erroneous URL removed.
Oops, please ignore the URL that appears below. It is left over from a reply to a request for a converter in the Pr forum. It did not appear on the editing screen here, and I only saw it when I posted. I cannot find a way to edit it out and hope that Steve G. or other MOD will do this for me.
Sorry about that,
Hunt
Rod,
I use similar, when doing a lot of PiP work. I do not use PiP Presets, as I am usually doing something that is not covered by the Presets. In those cases, I will create a similar image, but create "boxes" in the position that I will be using. These "boxes" are just Shapes that get a Stroke, so I can see them, and are sized and positioned, as is required. Often, when I create those, I'll do an Export>Frame from my Video, and use it as a "guide" in PS to position my PiP's. When I Save the alignment guide image, I just turn off visibility for that Video Frame, so that it does not interfere with my alignment guide.
Back in PrE/PrPro, I use the fixed Effect>Motion>Position and Scale to adjust my PiP material to match my alignment guides.
Good luck,
Hunt
Hi
I tested the grid idea...works well. I ended up layering stills with transparency to see the grid and line up ...I did a test title page and stills in the same psd file...and I didn't create an overall background image...but left the screen black (black video) in premiere...can do background image later...this was first time doing a layered psd to premiere...
I found the grid (especially with the various "weights" of letters in different fonts ( like the letter T or the letter O ) need to be shifted a bit for balance and the grid helps a lot with that, as well as the horizontal postition of the images. For some reason the images appear to go into layer OK vertically (centered at least, and can adjust from there depending again on "weight" issue), but horizontally they are off a bit (not centered exactly) all the time.
At any rate, I can see how the grid helps to get a reference for lining things up...so thanks for uploading that and sharing it.
I ended up using the eyeball and transparency a lot in psd, finally turning everything on and opaque before saving for import to premiere, and when in premiere I did what you suggested..put the grid on top video channel and it worked well.
Rod
ps. I'm finding it fun to do my own cross dissolves...so they aren't all the same exactly. Takes time though...so I can see big benefit to just using preset with a lot of images to deal with.
Ann,
To have the PiP Videos appear to be "paused," you would just add a Frame Capture Still Image, of the necessary Duration, to the Head of the Video. The process for doing the Frame Capture Still Image will differ by the version of Premiere that you have. In some versions, it's as simple as clicking on a little "camera" icon, to a rather convoluted process, involving Adobe Media Encoder (AME). One must check the Help File for their particular version for doing Frame Capture.
Note: if, when the individual PiP Videos have run, if you then want them to appear "paused," just do a Frame Capture of the last Frame, and add that Still Image to the end, and extend it for the necessary Duration.
Good luck, and hope that helps.
Hunt
Many Many Thanks........
It is very very helpful... I will use it soon for my coming project...
I hope I am not inturrepting you!!!!!
I have one more doubt...
I have one project in adobe pre.pro CS5, with the aspect ratio of 15:9 and rendered to DVD. My problem is when I am seeing this video on normal TV, missing some portion of video from left and right. So is there any solution to adjust it automatically according to the TV screen size. Or how can I render this project to the ratio of 4:3 by putting blank space on top and bottom.
I am very thankful to you for your great support..
amn
Amn,
I would post to the PrPro CS 5 & 5.5 Forum, with the full specs. of your Source Footage, and your Sequence Preset, plus your output settings.
That would be a better place to address your issue, than here, as almost no one will see your post, and respond. The PrPro Forum will get you a lot more "eyes," and help.
Good luck, and will see you in the PrPro Forum.
Hunt
