Trying to upgrade to CF 9 from 8.01, the unstall of 8.01 hung on folders.
Now I can't reinstall as the option is greyed out message :
"This option is disabled because JRun 4 has been detected on this machine"
I have removed the JRun directory, all instances of CF, any key's I could
in Regedit.
Does anyone know what I need to delete to allow me to reinstall?
Gary
Try re-installing ColdFusion 8. Then uninstall it by the book.
Try Rob Brooks-Bilson's tip for removing a Windows Service from the Command Line . (I am assuming you will see the names when you open Services.)
Thanks guys, resolved the problem the registry key to delete is
"Uninstall Adobe ColdFusion 8 (Multiserver)". I had previously removed all the instances using the command
line which is : sc delete [INSTANCE_NAME].
Found the registry key using the registry search using Adobe, however I never realised how many abobe fields there would be.
Should have just searched for ColdFusion which was obvious.
Thanks again
Gary
