removin bullets from stage after game over
Apr 07, 2012 Apr 07, 2012
in my game enemy Planes shoot at my plane and everything is working fine
enemy bullets are inside an array
the problem is when my plane gets destroyed by enemy Planes ,the last bullets shot by the enemyPlanes still shows on the screen
eventhough i called a removelistener function and added a game over screen
enemy planes use timer which i have a listener for it
how can i remove the last bullets that still shows on the screen?
ActionScript
881
LEGEND , Apr 07, 2012 Apr 07, 2012
yep, and clear the array
If the bullets are stored in an array, then use removeChild to remove them and set any references to them as null.  Empty the array when you are done.
// responsible for making an enemy plane shoot when the timer start
public function e1ShootBullet(event:TimerEvent):void
            //Create a bullet and add it to the stage
            enemyBullet1 = new Bullets(getAngle2(enemyPlane1));
            stage.addChild(enemyBullet1);
            //Set the bullet's starting position
            var radius:int = 30;
            var angle:Number = enemyPlane1.rotation * Math.PI / 180;
            enemyBullet1.x = enemyPlane1.x + radius * Math.cos(angle);
            enemyBullet1.y = enemyPlane1.y + radius * Math.sin(angle);
            //Set the bullet's velocity based
            //on the angle
            enemyBullet1.vx = Math.cos(angle) * 5;
            enemyBullet1.vy = Math.sin(angle) * 5;
            //Push the bullet into the _bullets array
            _eBullet.push(enemyBullet1);
            //Find a random start time for the next bullet
            var randomFireTime:Number = Math.round(Math.random() * 1000) + 200;
            //_timer1.delay = randomFireTime;
// responsible for moving the enemy Planes bullets called from an enter frame function
private function moveEnemyBullet( enemyPlane :MovieClip)
            if (enemyPlane == enemyPlane1)
                for (var i:int = 0; i < _eBullet.length; i++)
                    enemyBullet1 = _eBullet;
                    enemyBullet1.x +=  enemyBullet1.vx;
                    enemyBullet1.y +=  enemyBullet1.vy;
                    if (enemyBullet1.y < 0 || enemyBullet1.x < 0 || enemyBullet1.x > stage.stageWidth || enemyBullet1.y > 609)
                        //Remove the bullet from the stage
                        stage.removeChild(enemyBullet1);
                        bullethit.play();
                        //Remove the bullet from the _bullets;
                        //array
                        _eBullet.splice(i,1);
                        enemyBullet1 = null;
                        //Reduce the loop counter
                        //by one to compensate
                        //for the removed bullet
// end Game function
private function endGame( endMessage:String):void
            endScreen = new winLoose();
            endScreen.end_txt.text = endMessage;
            //endScreen.score_txt.text = String(_PlaneScoreDisplay);
            addChild(endScreen);
            endScreen.x = 0;
            endScreen.y = 0;
            _timer1.removeEventListener(TimerEvent.TIMER, e1ShootBullet);
            _timer2.removeEventListener(TimerEvent.TIMER, e2ShootBullet);
            _timer1.stop();
            _timer2.stop();
            _PlaneScoreDisplay.text = "";
            bombsLeftDisplay.text = "";
            endScreen.playAgain_btn.addEventListener(MouseEvent.CLICK, startGame);
I am not sure why you are showing the code without any explanation, but I do not see where you are removing any of the bullets in your endGame function, which is where you say you wanted them to go away... you only do it in your moveEnemyBullet function
damn i missed that  ^^ damn i just get lost in my own code
i should do the same
