DAMJ
howto create realistic stitched patch effect
Dec 16, 2010 2:08 PM
the title says it all, how do you realisticly recreate a embroided patch effect.
think of militairy patches.
this pictures shows what i mean
http://e-patches.com/wp-content/uploadszsedc/2008/05/airsoft.jpg
http://www.emblemworks.com/zencart/images/sec.jpg
i have been fiddling around with the scribble effect. but i cant get the lighting to look right.
tnx in advance,
-Diego
    Dec 16, 2010 2:44 PM   in reply to DAMJ
    I find expanding the scribble effect and applying a gradient to the resuting shape helps a great deal.
    Dec 16, 2010 3:35 PM   in reply to DAMJ
    You would need to create a custom pattern brush to get the stitching to follow the path. Not easily done, but possible.
    Dec 17, 2010 7:43 PM   in reply to DAMJ
    Edit: Never mind misunderstood your issue.
    Learn the appearance palette it is your friend.
    Bert
    Dec 18, 2010 6:31 AM   in reply to DAMJ
    Embroidery border.
    Store the Appearance as a Graphic Style. Apply it to any path. Create the original grad using only grays, set the Colorization mode of the Pattern Brush to Hue Shift or Tints & Shades, and the one Brush will serve for any color "thread".
    JET
    Apr 6, 2012 7:19 PM   in reply to DAMJ
    Hi, Thank for the short tutorial. It is very helpful but in my case I must be missing something because I can't make it work.
    I follow this tutorial but when I get to the "pathfinder:merge" I don't know with which other shape I have to merge it.
    If I skip the merge and drag it to the brushes, I get an error "The selected artwork contains an element that cannot be used
    in a pattern brush". I found out that the problem is the gradient because if I do all the same without gradient then I can use
    the artwork as a pattern. The problem is that I nedd the gradient to make it realistic. Can somebody tell me what I am doing wrong?
    Thank you very much in advance for your help
    Carlos
    Apr 6, 2012 8:06 PM   in reply to carlosllebry
    You can't use grad fills in a Brush. So, as the instructions indicate, you have to:
    1. Object>Expand Appearance. (Flattens the live Scribble Effect.)
    2. Object>Expand...>Fill. Specify Steps: 20. (Flattens the live Gradient Fill into a set of discrete paths with normal solid fills.)
    3. PathFinder palette>Merge. (Unions adjacent areas of same color, and punches areas of overlap. This is just to further optimize the Brush by minimizing the number of paths.)
    These steps are all mentioned in the demo, but are not as explicitly spelled-out, because the assumption is the reader has read the manual and is familiar with the basic features and commands, and would therefore understand the "shorthand" instructions.
    JET
    Apr 7, 2012 9:29 AM   in reply to JETalmage
    In my case, the Round Corners effect doesn't give small round corners. What would I be doing wrong?
    Apr 7, 2012 9:53 AM   in reply to jay fresno
    Try something larger than 0.001 in. That can't even be shown on the screen.
    Apr 7, 2012 10:10 AM   in reply to Larry G. Schneider
    Thanks for the suggestion. I couldn't get the round corner effect to work for me no matter what. But the round any corner script worked.
    Apr 7, 2012 11:56 AM   in reply to jay fresno
    Not entirely relevant, but maybe helpful to anyone who happens upon this thread later (get it?  Thread! I crack myself up.)
    I had cooked up a way to "embroider" a while back which might come in handy for the rest of the patch or whatever you might be making.
    Source file here: http://www.illustratorhints.com/2010/05/embroidered-text-effect/
    Apr 7, 2012 1:48 PM   in reply to Jesseham
    COOL!
    Apr 7, 2012 2:06 PM   in reply to Jesseham
    Thanks, Jesse.
    (That was sew funny. You have me in stitches. I'll needle little time to recover.)
    Apr 7, 2012 3:22 PM   in reply to DAMJ
    Maybe we shall all be stitched up before we knowhowto.
    Apr 7, 2012 8:32 PM   in reply to Jacob Bugge
    Ah, you guys are a rip!
