randy1639
In bridge i select a jpg image with cntrl r to open in camera raw but get "camera raw not avail"
Apr 7, 2012 12:11 PM
In bridge i select a jpg image with cntrl r to open in camera raw but get "camera raw not available"  camera raw editing requires that a qualifying product has been launched at least once to enable this feature.  I can open nef. in camera raw with no problem.
    Aug 5, 2012 1:13 PM   in reply to randy1639
    Did you ever solve this? I am having the same issue.
    Aug 6, 2012 11:29 AM   in reply to takav2987
    Hi, can you please check to make sure that JPEG support is enabled in the Camera Raw preferences menu?
    Aug 6, 2012 11:47 AM   in reply to johnkwon9
    I get the same error when I try to click on camera raw preferences
    Sent from my iPhone
  • Noel Carboni
    Dec 23, 2006
    Aug 6, 2012 3:19 PM   in reply to randy1639
    Out of curiosity, do you have a 64 bit Windows OS?
    Have you run both 32 and 64 bit versions of Photoshop at least once?
    This is just a wildass guess, but since I assume johnkwon9's suggestion didn't net a success, you're not getting a lot of other help, and it doesn't take long to try...
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 6, 2012 4:18 PM   in reply to randy1639
    Hm, what I suggested might actually be a possibility then...
    Close whatever version you have open first...
    I think Adobe installs shortcuts for both 32 and 64 bit Photoshop in the start menu.
    If you can't find the 32 bit Start menu entry, look for the 32 executable here (changing the CS version number to whatever yours is):
    C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Photoshop.exe
    -Noel
    Aug 16, 2012 1:17 AM   in reply to Noel Carboni
    I have the same problem with Bridge, same nagging "Bridge requires....".
    I have only the 64 bit version of CS6 installed (have uninstalled CS5) and I can´t see why the 32 bit version would be the qualifying product.
    The problem was the same before I uninstalled CS5 so it has nothing to do with that.
    FWIW, double clicking a RAW file in Bridge opens up PS and ACR, but ctrl-R doesn´t work, i.e no direct access to CameraRaw.
    Would appreciate further investigation into this.
    Aug 16, 2012 2:38 AM   in reply to wurre
    Of course I could be wrong, but I was under the impression that Bridge was a 32-bit-only application in both platforms in CS5.  That changed in CS6 of course, and on the Mac there is only a 64-bit version of CS6.
    Edited to add: in CS5
    Message was edited by: station_two
    Aug 16, 2012 2:40 AM   in reply to wurre
    Note to those reading by email:
    Please note that I edited my previous post to add in CS5.
  • Noel Carboni
    Dec 23, 2006
    Aug 16, 2012 2:44 AM   in reply to station_two
    You are not wrong.
    On PC there are both 32 and 64 bit variants of Bridge only for Photoshop CS6.
    -Noel
    Aug 16, 2012 2:46 AM   in reply to Noel Carboni
    Up already?
