Locked
trouble Flash 11
Apr 06, 2012 Apr 06, 2012
I have IE 9 and Window 7 64 bit operating system I tried to install Flash 11 and it ends with "Installation encountered errors, actionlist not found"
7.4K
Download the full (64-bit) installer from the link in http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_... and save it to disk.  Close all browser windows, then run the downloaded installer.
i followed the directions above and when the installer reached 100% the installer froze and stopped responding, i keep repeating the steps and the same result occurs every time.
Can you post the contents of the FlashInstall.log files from both C:\Windows\system32\Macromed\Flash and C:\Windows\syswow64\Macromed\Flash ?
Apr 07, 2012 Apr 07, 2012
Flash64_11_1_102.ocx, FlashInstall, FlashUtil64_11_1_102_ActiveX.dll, FlashUtil64_11_1_102_ActiveX, FlashUtil64_11_1_102_Plugin, NPSWF64_11_1_102.dll
FlashPlayerTrust, Flash11e.ocx, Flash11f.ocx, FlashInstall, flashplayer.xpt, FlashUtil11e_ActiveX, FlashUtil11e_Plugin, FlashUtil11f_ActiveX.dll, FlashUtil11f_ActiveX, install, NPSWF32.dll
Advisor ,
Download the current 64 bit uninstaller
Close all browser windows and run the uninstaller
Restart Windows
Delete all remaining files and folders located in the following directories. (tip: copy and paste these paths into the path bar in a Windows Explorer window)
  • C:\Windows\system32\Macromed\Flash
  • C:\Windows\SysWOW64\Macromed\Flash
  • %appdata%\Macromedia\Flash Player
  • %appdata%\Adobe\Flash Player
Verify that the file “FlashPlayerCPLApp.cpl” in C:\Windows\SysWOW64\ has been deleted.
Download the following installer file: 64 bit Flash Player for ActiveX (Internet Explorer)
Physically disconnect from the Internet and run the installer.
i followed the directions above and it still will not install
Advisor ,
Exactly what happens when you double click install_flash_player_ax_64bit.exe?
What files are in C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash?
SysWoW64/Macromed/Flash - Flash.ocx , I am the adminstrator and only user on this computer and It will not let me delete this ActiveX control
System32/Macromed/Flash - Empty
I open the installer, click the checkbox, then click install, the installing... screen appears the blue bar goes 100%, the installer stops working after this point and when I click on it ,it says (not responding) .
Advisor ,
Apr 08, 2012 Apr 08, 2012
Are you sure the file simply says Flash.ocx?
Have you tried the program Unlocker on Flash.ocx?
Have you virus scanned Flash.ocx?
What is the exact message you get when you try to delete Flash.ocx?
Have you tried booting in the safe mode and deleting Flash.ocx?
Apart from deleting that Flash.ocx file, you should also delete the folders, as you may have a permission problem:
  • C:\Windows\syswow64\Macromed\Flash
Apr 09, 2012 Apr 09, 2012
tried deleting it in safe mode and it would not delete, deleted the folders except sysWoW64/Macromed it agains says i need administrator permissions, the folder Flash with the Flash.ocx still remains. I scanned it with the Total Defense Security Suite and it showed no viruses. the exact message i get is :
Folder Access Denied
You need permission to perform this action
You require permission from an Administrators to make changes to this file
Adobe Employee ,
Hi Darkmoon2010,
Could you try running through this FAQ to see if it fixes your permission problem with that folder?
How do I fix Windows permission problems with Flash Player?
Chris
Apr 11, 2012 Apr 11, 2012
I followed the instructions above and the installer gets stuck on retrieving install i left it running for a day and it is still at 0%
Did you download the installer from the link that Carl provided in his earlier reply?  Apparently not, that installer would not retrieve anything during the install.
Apr 12, 2012 Apr 12, 2012
Did all those steps (I even gave everyone full 0_0) still no luck. Removed and updated java and reader without issue.
=== Verbose logging started: 4/12/2012  05:25:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
MSI (c) (F4:A0) [05:25:33:647]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (F4:64) [05:25:33:678]: Resetting cached policy values
MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'Debug' is 0
MSI (c) (F4:64) [05:25:33:678]: ******* RunEngine:
           ******* Product: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
MSI (c) (F4:64) [05:25:33:991]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (F4:64) [05:25:34:053]: Cloaking enabled.
MSI (c) (F4:64) [05:25:34:053]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (F4:64) [05:25:34:069]: End dialog not enabled
MSI (c) (F4:64) [05:25:34:069]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
MSI (c) (F4:64) [05:25:34:069]: Package we're running from ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (F4:64) [05:25:34:069]: MSCOREE not loaded loading copy from system32
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'TransformsSecure' is 0
MSI (c) (F4:64) [05:25:34:084]: User policy value 'TransformsAtSource' is 0
MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisablePatch' is 0
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (F4:64) [05:25:34:084]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (F4:64) [05:25:34:084]: Transforms are not secure.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
MSI (c) (F4:64) [05:25:34:084]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=4596
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
MSI (c) (F4:64) [05:25:34:084]: Product Code passed to Engine.Initialize:           ''
MSI (c) (F4:64) [05:25:34:084]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (c) (F4:64) [05:25:34:084]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (c) (F4:64) [05:25:34:084]: Product not registered: beginning first-time install
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (F4:64) [05:25:34:084]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (F4:64) [05:25:34:084]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (F4:64) [05:25:34:084]: Adding new sources is allowed.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (F4:64) [05:25:34:084]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
MSI (c) (F4:64) [05:25:34:084]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableMsi' is 0
MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (F4:64) [05:25:34:084]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (F4:64) [05:25:34:084]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (F4:64) [05:25:34:084]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (F4:64) [05:25:34:084]: TRANSFORMS property is now:
MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (F4:64) [05:25:34:100]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
MSI (c) (F4:A0) [05:25:34:100]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 4/12/2012  05:25:34 ===
MSI (c) (F4:64) [05:25:34:100]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'DisableRollback' is 0
MSI (c) (F4:64) [05:25:34:100]: User policy value 'DisableRollback' is 0
MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (F4:64) [05:25:34:116]: Doing action: INSTALL
Action 05:25:34: INSTALL.
Action start 05:25:34: INSTALL.
MSI (c) (F4:64) [05:25:34:116]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (F4:64) [05:25:34:116]: Running UISequence
MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (F4:64) [05:25:34:116]: Doing action: ISSetAllUsers
Action 05:25:34: ISSetAllUsers.
Action start 05:25:34: ISSetAllUsers.
MSI (c) (F4:64) [05:25:34:147]: Creating MSIHANDLE (1) of type 790542 for thread 1380
MSI (c) (F4:78) [05:25:34:147]: Invoking remote custom action. DLL: C:\Users\Ad~1\AppData\Local\Temp\MSIEDE8.tmp, Entrypoint: SetAllUsers
MSI (c) (F4:DC) [05:25:34:147]: Cloaking enabled.
MSI (c) (F4:DC) [05:25:34:147]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (F4:DC) [05:25:34:147]: Connected to service for CA interface.
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (2) of type 790531 for thread 2532
InstallShield 05:25:34: Begin SetAllUsers()
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (2) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (3) of type 790541 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (4) of type 790531 for thread 2532
InstallShield 05:25:34: Getting records from Upgrade table
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (4) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (5) of type 790540 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (6) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (7) of type 790531 for thread 2532
InstallShield 05:25:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (7) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (8) of type 790531 for thread 2532
InstallShield 05:25:34: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (8) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (6) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (9) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (10) of type 790531 for thread 2532
InstallShield 05:25:34: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (10) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (11) of type 790531 for thread 2532
InstallShield 05:25:34: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (11) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (9) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (12) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (13) of type 790531 for thread 2532
InstallShield 05:25:34: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (13) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (14) of type 790531 for thread 2532
InstallShield 05:25:34: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (14) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (12) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (15) of type 790531 for thread 2532
InstallShield 05:25:34: End SetAllUsers()
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (15) of type 790531 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (5) of type 790540 for thread 2532
MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (3) of type 790541 for thread 2532
MSI (c) (F4:78) [05:25:34:256]: Closing MSIHANDLE (1) of type 790542 for thread 1380
Action ended 05:25:34: ISSetAllUsers. Return value 1.
MSI (c) (F4:64) [05:25:34:256]: Doing action: AppSearch
Action 05:25:34: AppSearch. Searching for installed applications
Action start 05:25:34: AppSearch.
MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2205 2:  3: AppSearch
MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
Action ended 05:25:34: AppSearch. Return value 0.
MSI (c) (F4:64) [05:25:34:256]: Doing action: LaunchConditions
Action 05:25:34: LaunchConditions. Evaluating launch conditions
Action start 05:25:34: LaunchConditions.
Action ended 05:25:34: LaunchConditions. Return value 1.
MSI (c) (F4:64) [05:25:34:272]: Doing action: SetupInitialization
Action 05:25:34: SetupInitialization.
Action start 05:25:34: SetupInitialization.
Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 05:25:34: SetupInitialization. Dialog created
Action ended 05:25:34: SetupInitialization. Return value 1.
MSI (c) (F4:64) [05:25:34:288]: Doing action: FindRelatedProducts
Action 05:25:34: FindRelatedProducts. Searching for related applications
Action start 05:25:34: FindRelatedProducts.
Action ended 05:25:34: FindRelatedProducts. Return value 1.
MSI (c) (F4:64) [05:25:34:288]: Skipping action: CCPSearch (condition is false)
MSI (c) (F4:64) [05:25:34:288]: Skipping action: RMCCPSearch (condition is false)
MSI (c) (F4:64) [05:25:34:288]: Doing action: ValidateProductID
Action 05:25:34: ValidateProductID.
Action start 05:25:34: ValidateProductID.
Action ended 05:25:34: ValidateProductID. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: CostInitialize
Action 05:25:34: CostInitialize. Computing space requirements
Action start 05:25:34: CostInitialize.
MSI (c) (F4:64) [05:25:34:303]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
MSI (c) (F4:64) [05:25:34:303]: Baseline: New baseline 11.2.202 from transaction.
MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorted order Native: Order 0.
MSI (c) (F4:64) [05:25:34:303]: Baseline Data Table:
MSI (c) (F4:64) [05:25:34:303]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (c) (F4:64) [05:25:34:303]: Baseline File Table:
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 05:25:34: CostInitialize. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: FileCost
Action 05:25:34: FileCost. Computing space requirements
Action start 05:25:34: FileCost.
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: MsiAssembly
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Class
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Extension
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: TypeLib
Action ended 05:25:34: FileCost. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: IsolateComponents
Action 05:25:34: IsolateComponents.
Action start 05:25:34: IsolateComponents.
Action ended 05:25:34: IsolateComponents. Return value 0.
MSI (c) (F4:64) [05:25:34:303]: Doing action: setUserProfileNT
Action 05:25:34: setUserProfileNT.
Action start 05:25:34: setUserProfileNT.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
Action ended 05:25:34: setUserProfileNT. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (c) (F4:64) [05:25:34:303]: Doing action: setAllUsersProfile2K
Action 05:25:34: setAllUsersProfile2K.
Action start 05:25:34: setAllUsersProfile2K.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action ended 05:25:34: setAllUsersProfile2K. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: ResolveSource
Action 05:25:34: ResolveSource.
Action start 05:25:34: ResolveSource.
MSI (c) (F4:64) [05:25:34:303]: Resolving source.
MSI (c) (F4:64) [05:25:34:303]: Resolving source to launched-from source.
MSI (c) (F4:64) [05:25:34:303]: Setting launched-from source as last-used.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR ==> C:\Users\Admin\Desktop\
MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
MSI (c) (F4:64) [05:25:34:303]: Determining source type
MSI (c) (F4:64) [05:25:34:303]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
MSI (c) (F4:64) [05:25:34:303]: Source path resolution complete. Dumping Directory table...
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
Action ended 05:25:34: ResolveSource. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: CostFinalize
Action 05:25:34: CostFinalize. Computing space requirements
Action start 05:25:34: CostFinalize.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Condition
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (c) (F4:64) [05:25:34:303]: Target path resolution complete. Dumping Directory table...
MSI (c) (F4:64) [05:25:34:303]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TARGETDIR , Object: E:\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 05:25:34: CostFinalize. Return value 1.
MSI (c) (F4:64) [05:25:34:303]: Doing action: MigrateFeatureStates
Action 05:25:34: MigrateFeatureStates. Migrating feature states from related applications
Action start 05:25:34: MigrateFeatureStates.
Action ended 05:25:34: MigrateFeatureStates. Return value 0.
MSI (c) (F4:64) [05:25:34:303]: Skipping action: PatchWelcome (condition is false)
MSI (c) (F4:64) [05:25:34:303]: Doing action: InstallWelcome
Action 05:25:34: InstallWelcome.
Action start 05:25:34: InstallWelcome.
Action 05:25:34: InstallWelcome. Dialog created
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (F4:9C) [05:25:34:319]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: BindImage
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: ProgId
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: PublishComponent
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: SelfReg
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Extension
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Font
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Shortcut
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Class
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: TypeLib
MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2727 2:
Action ended 05:25:36: InstallWelcome. Return value 1.
MSI (c) (F4:64) [05:25:36:022]: Skipping action: SetupResume (condition is false)
MSI (c) (F4:64) [05:25:36:022]: Skipping action: MaintenanceWelcome (condition is false)
MSI (c) (F4:64) [05:25:36:022]: Doing action: SetupProgress
Action 05:25:36: SetupProgress.
Action start 05:25:36: SetupProgress.
Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 05:25:36: SetupProgress. Dialog created
Action ended 05:25:36: SetupProgress. Return value 1.
MSI (c) (F4:64) [05:25:36:038]: Doing action: ExecuteAction
Action 05:25:36: ExecuteAction.
Action start 05:25:36: ExecuteAction.
MSI (c) (F4:64) [05:25:36:053]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (c) (F4:64) [05:25:36:053]: Grabbed execution mutex.
MSI (c) (F4:64) [05:25:36:053]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (F4:64) [05:25:36:053]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\" USERNAME="Viking" CLIENTPROCESSID="4596" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop"  ADDLOCAL=FlashPlayerAXInstaller
MSI (s) (28:94) [05:25:36:069]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
MSI (s) (28:94) [05:25:36:069]: Grabbed execution mutex.
MSI (s) (28:78) [05:25:36:069]: Resetting cached policy values
MSI (s) (28:78) [05:25:36:069]: Machine policy value 'Debug' is 0
MSI (s) (28:78) [05:25:36:069]: ******* RunEngine:
           ******* Action: INSTALL
MSI (s) (28:78) [05:25:36:069]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (28:78) [05:25:36:069]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
MSI (s) (28:78) [05:25:36:084]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
MSI (s) (28:78) [05:25:36:084]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
MSI (s) (28:78) [05:25:36:084]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (28:78) [05:25:36:084]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
MSI (s) (28:78) [05:25:36:084]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
MSI (s) (28:78) [05:25:46:319]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 390.
MSI (s) (28:78) [05:25:46:319]: File will have security applied from OpCode.
MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
MSI (s) (28:78) [05:25:46:538]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (28:78) [05:25:46:538]: End dialog not enabled
MSI (s) (28:78) [05:25:46:538]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
MSI (s) (28:78) [05:25:46:538]: Package we're running from ==> C:\Windows\Installer\1201d91.msi
MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (28:78) [05:25:46:553]: MSCOREE not loaded loading copy from system32
MSI (s) (28:78) [05:25:46:553]: Machine policy value 'TransformsSecure' is 0
MSI (s) (28:78) [05:25:46:553]: User policy value 'TransformsAtSource' is 0
MSI (s) (28:78) [05:25:46:553]: Note: 1: 2205 2:  3: MsiFileHash
MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisablePatch' is 0
MSI (s) (28:78) [05:25:46:553]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (28:78) [05:25:46:553]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (28:78) [05:25:46:553]: Transforms are not secure.
MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
MSI (s) (28:78) [05:25:46:553]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\ USERNAME=Viking CLIENTPROCESSID=4596 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
MSI (s) (28:78) [05:25:46:553]: Product Code passed to Engine.Initialize:           ''
MSI (s) (28:78) [05:25:46:553]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (s) (28:78) [05:25:46:553]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (s) (28:78) [05:25:46:553]: Product not registered: beginning first-time install
MSI (s) (28:78) [05:25:46:553]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
MSI (s) (28:78) [05:25:46:553]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (28:78) [05:25:46:553]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (28:78) [05:25:46:553]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (28:78) [05:25:46:553]: Adding new sources is allowed.
MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (28:78) [05:25:46:569]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
MSI (s) (28:78) [05:25:46:569]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
MSI (s) (28:78) [05:25:46:569]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableMsi' is 0
MSI (s) (28:78) [05:25:46:569]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (28:78) [05:25:46:569]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (28:78) [05:25:46:569]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (28:78) [05:25:46:569]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'ffdbe6677a09a542b5e6559f7939deaf'.
MSI (s) (28:78) [05:25:46:569]: RESTART MANAGER: Session opened.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (28:78) [05:25:46:569]: Engine has iefSecondSequence set to true.
MSI (s) (28:78) [05:25:46:569]: TRANSFORMS property is now:
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\'.
MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (28:78) [05:25:46:616]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (28:78) [05:25:46:616]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (28:78) [05:25:46:616]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1201d91.msi'.
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (28:78) [05:25:46:616]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (28:78) [05:25:46:616]: Machine policy value 'DisableRollback' is 0
MSI (s) (28:78) [05:25:46:616]: User policy value 'DisableRollback' is 0
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (28:78) [05:25:46:616]: Doing action: INSTALL
Action 05:25:46: INSTALL.
Action start 05:25:46: INSTALL.
MSI (s) (28:78) [05:25:46:616]: Running ExecuteSequence
MSI (s) (28:78) [05:25:46:616]: Doing action: ISSetAllUsers
Action 05:25:46: ISSetAllUsers.
Action start 05:25:46: ISSetAllUsers.
MSI (s) (28:78) [05:25:46:616]: Skipping action due to msidbCustomActionTypeFirstSequence option.
Action ended 05:25:46: ISSetAllUsers. Return value 0.
MSI (s) (28:78) [05:25:46:616]: Doing action: AppSearch
Action 05:25:46: AppSearch. Searching for installed applications
Action start 05:25:46: AppSearch.
MSI (s) (28:78) [05:25:46:616]: Skipping AppSearch action: already done on client side
Action ended 05:25:46: AppSearch. Return value 0.
MSI (s) (28:78) [05:25:46:616]: Doing action: LaunchConditions
Action 05:25:46: LaunchConditions. Evaluating launch conditions
Action start 05:25:46: LaunchConditions.
Action ended 05:25:46: LaunchConditions. Return value 1.
MSI (s) (28:78) [05:25:46:616]: Doing action: FindRelatedProducts
Action 05:25:46: FindRelatedProducts. Searching for related applications
Action start 05:25:46: FindRelatedProducts.
MSI (s) (28:78) [05:25:46:616]: Skipping FindRelatedProducts action: already done on client side
Action ended 05:25:46: FindRelatedProducts. Return value 0.
MSI (s) (28:78) [05:25:46:616]: Skipping action: CCPSearch (condition is false)
MSI (s) (28:78) [05:25:46:616]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (28:78) [05:25:46:616]: Doing action: ValidateProductID
Action 05:25:46: ValidateProductID.
Action start 05:25:46: ValidateProductID.
Action ended 05:25:46: ValidateProductID. Return value 1.
MSI (s) (28:78) [05:25:46:616]: Doing action: CostInitialize
Action 05:25:46: CostInitialize. Computing space requirements
Action start 05:25:46: CostInitialize.
MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (28:78) [05:25:46:616]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
MSI (s) (28:78) [05:25:46:616]: Baseline: New baseline 11.2.202 from transaction.
MSI (s) (28:78) [05:25:46:616]: Baseline: Sorted order Native: Order 0.
MSI (s) (28:78) [05:25:46:616]: Baseline Data Table:
MSI (s) (28:78) [05:25:46:616]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (s) (28:78) [05:25:46:616]: Baseline File Table:
MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (28:78) [05:25:46:616]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
MSI (s) (28:78) [05:25:46:631]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
Action ended 05:25:46: CostInitialize. Return value 1.
MSI (s) (28:78) [05:25:46:631]: Doing action: FileCost
Action 05:25:46: FileCost. Computing space requirements
Action start 05:25:46: FileCost.
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Class
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Extension
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: TypeLib
Action ended 05:25:46: FileCost. Return value 1.
MSI (s) (28:78) [05:25:46:631]: Doing action: IsolateComponents
Action 05:25:46: IsolateComponents.
Action start 05:25:46: IsolateComponents.
Action ended 05:25:46: IsolateComponents. Return value 0.
MSI (s) (28:78) [05:25:46:631]: Doing action: CostFinalize
Action 05:25:46: CostFinalize. Computing space requirements
Action start 05:25:46: CostFinalize.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Condition
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (28:78) [05:25:46:631]: Target path resolution complete. Dumping Directory table...
MSI (s) (28:78) [05:25:46:631]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TARGETDIR , Object: E:\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 05:25:46: CostFinalize. Return value 1.
MSI (s) (28:78) [05:25:46:631]: Doing action: SetARPINSTALLLOCATION
Action 05:25:46: SetARPINSTALLLOCATION.
Action start 05:25:46: SetARPINSTALLLOCATION.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
Action ended 05:25:46: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (28:78) [05:25:46:631]: Doing action: SetODBCFolders
Action 05:25:46: SetODBCFolders. Initializing ODBC directories
Action start 05:25:46: SetODBCFolders.
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action ended 05:25:46: SetODBCFolders. Return value 0.
MSI (s) (28:78) [05:25:46:631]: Doing action: MigrateFeatureStates
Action 05:25:46: MigrateFeatureStates. Migrating feature states from related applications
Action start 05:25:46: MigrateFeatureStates.
MSI (s) (28:78) [05:25:46:631]: Skipping MigrateFeatureStates action: already done on client side
Action ended 05:25:46: MigrateFeatureStates. Return value 0.
MSI (s) (28:78) [05:25:46:631]: Doing action: InstallValidate
Action 05:25:46: InstallValidate. Validating install
Action start 05:25:46: InstallValidate.
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'ffdbe6677a09a542b5e6559f7939deaf'.
MSI (s) (28:78) [05:25:46:631]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (28:78) [05:25:46:631]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (28:78) [05:25:46:631]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (28:78) [05:25:46:631]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: BindImage
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ProgId
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Font
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiFileHash
MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2727 2:
MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: FilesInUse
MSI (s) (28:78) [05:25:46:647]: Note: 1: 2727 2:
Action ended 05:25:46: InstallValidate. Return value 1.
MSI (s) (28:78) [05:25:46:647]: Doing action: RemoveExistingProducts
Action 05:25:46: RemoveExistingProducts. Removing applications
Action start 05:25:46: RemoveExistingProducts.
Action ended 05:25:46: RemoveExistingProducts. Return value 1.
MSI (s) (28:78) [05:25:46:663]: Doing action: InstallInitialize
Action 05:25:46: InstallInitialize.
Action start 05:25:46: InstallInitialize.
MSI (s) (28:78) [05:25:46:663]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (28:78) [05:25:46:663]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (28:78) [05:25:46:663]: BeginTransaction: Locking Server
MSI (s) (28:78) [05:25:46:663]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
Action ended 05:25:50: InstallInitialize. Return value 1.
MSI (s) (28:78) [05:25:50:538]: Skipping action: CallExeUninstaller (condition is false)
MSI (s) (28:78) [05:25:50:538]: Doing action: MakePropsAvailable
Action 05:25:50: MakePropsAvailable.
Action start 05:25:50: MakePropsAvailable.
MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
Action ended 05:25:50: MakePropsAvailable. Return value 1.
MSI (s) (28:78) [05:25:50:538]: Doing action: AllocateRegistrySpace
Action 05:25:50: AllocateRegistrySpace. Allocating registry space
Action start 05:25:50: AllocateRegistrySpace.
Action ended 05:25:50: AllocateRegistrySpace. Return value 1.
MSI (s) (28:78) [05:25:50:538]: Doing action: ProcessComponents
Action 05:25:50: ProcessComponents. Updating component registration
Action start 05:25:50: ProcessComponents.
MSI (s) (28:78) [05:25:50:538]: Note: 1: 2205 2:  3: MsiPatchCertificate
MSI (s) (28:78) [05:25:50:538]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (28:78) [05:25:50:538]: Resolving source.
MSI (s) (28:78) [05:25:50:538]: Resolving source to launched-from source.
MSI (s) (28:78) [05:25:50:538]: Setting launched-from source as last-used.
MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (28:78) [05:25:50:538]: SOURCEDIR ==> C:\Users\Admin\Desktop\
MSI (s) (28:78) [05:25:50:538]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
MSI (s) (28:78) [05:25:50:538]: Determining source type
MSI (s) (28:78) [05:25:50:553]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
MSI (s) (28:78) [05:25:50:553]: Source path resolution complete. Dumping Directory table...
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
Action 05:25:50: GenerateScript. Generating script operations for action:
GenerateScript: Updating component registration
Action ended 05:25:50: ProcessComponents. Return value 1.
MSI (s) (28:78) [05:25:50:553]: Doing action: UnpublishComponents
Action 05:25:50: UnpublishComponents. Unpublishing Qualified Components
Action start 05:25:50: UnpublishComponents.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: UnpublishComponents. Return value 0.
MSI (s) (28:78) [05:25:50:569]: Doing action: MsiUnpublishAssemblies
Action 05:25:50: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 05:25:50: MsiUnpublishAssemblies.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: MsiUnpublishAssemblies. Return value 0.
MSI (s) (28:78) [05:25:50:569]: Doing action: UnpublishFeatures
Action 05:25:50: UnpublishFeatures. Unpublishing product features
Action start 05:25:50: UnpublishFeatures.
Action ended 05:25:50: UnpublishFeatures. Return value 1.
MSI (s) (28:78) [05:25:50:569]: Doing action: StopServices
Action 05:25:50: StopServices. Stopping services
Action start 05:25:50: StopServices.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 05:25:50: StopServices. Return value 1.
MSI (s) (28:78) [05:25:50:569]: Doing action: DeleteServices
Action 05:25:50: DeleteServices. Deleting services
Action start 05:25:50: DeleteServices.
Action ended 05:25:50: DeleteServices. Return value 1.
MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterComPlus
Action 05:25:50: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 05:25:50: UnregisterComPlus.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: Complus
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action ended 05:25:50: UnregisterComPlus. Return value 0.
MSI (s) (28:78) [05:25:50:569]: Doing action: SelfUnregModules
Action 05:25:50: SelfUnregModules. Unregistering modules
Action start 05:25:50: SelfUnregModules.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action ended 05:25:50: SelfUnregModules. Return value 1.
MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterTypeLibraries
Action 05:25:50: UnregisterTypeLibraries. Unregistering type libraries
Action start 05:25:50: UnregisterTypeLibraries.
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action ended 05:25:50: UnregisterTypeLibraries. Return value 0.
MSI (s) (28:78) [05:25:50:569]: Doing action: RemoveODBC
Action 05:25:50: RemoveODBC. Removing ODBC components
Action start 05:25:50: RemoveODBC.
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager
1: Removing ODBC components
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager64
Action ended 05:25:50: RemoveODBC. Return value 1.
MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterFonts
Action 05:25:50: UnregisterFonts. Unregistering fonts
Action start 05:25:50: UnregisterFonts.
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Font
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action ended 05:25:50: UnregisterFonts. Return value 1.
MSI (s) (28:78) [05:25:50:584]: Doing action: RemoveRegistryValues
Action 05:25:50: RemoveRegistryValues. Removing system registry values
Action start 05:25:50: RemoveRegistryValues.
Action ended 05:25:50: RemoveRegistryValues. Return value 1.
MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterClassInfo
Action 05:25:50: UnregisterClassInfo. Unregister class servers
Action start 05:25:50: UnregisterClassInfo.
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Class
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: UnregisterClassInfo. Return value 0.
MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterExtensionInfo
Action 05:25:50: UnregisterExtensionInfo. Unregistering extension servers
Action start 05:25:50: UnregisterExtensionInfo.
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Extension
MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: UnregisterExtensionInfo. Return value 0.
MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterProgIdInfo
Action 05:25:50: UnregisterProgIdInfo. Unregistering program identifiers
Action start 05:25:50: UnregisterProgIdInfo.
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: ProgId
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: UnregisterProgIdInfo. Return value 0.
MSI (s) (28:78) [05:25:50:600]: Doing action: UnregisterMIMEInfo
Action 05:25:50: UnregisterMIMEInfo. Unregistering MIME info
Action start 05:25:50: UnregisterMIMEInfo.
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: MIME
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: UnregisterMIMEInfo. Return value 0.
MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveIniValues
Action 05:25:50: RemoveIniValues. Removing INI file entries
Action start 05:25:50: RemoveIniValues.
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: IniFile
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action ended 05:25:50: RemoveIniValues. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveShortcuts
Action 05:25:50: RemoveShortcuts. Removing shortcuts
Action start 05:25:50: RemoveShortcuts.
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 05:25:50: RemoveShortcuts. Return value 0.
MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveEnvironmentStrings
Action 05:25:50: RemoveEnvironmentStrings. Updating environment strings
Action start 05:25:50: RemoveEnvironmentStrings.
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Environment
MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action ended 05:25:50: RemoveEnvironmentStrings. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveDuplicateFiles
Action 05:25:50: RemoveDuplicateFiles. Removing duplicated files
Action start 05:25:50: RemoveDuplicateFiles.
Action ended 05:25:50: RemoveDuplicateFiles. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveFolders
Action 05:25:50: RemoveFolders. Removing folders
Action start 05:25:50: RemoveFolders.
Action ended 05:25:50: RemoveFolders. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: CreateFolders
Action 05:25:50: CreateFolders. Creating folders
Action start 05:25:50: CreateFolders.
CreateFolders: Folder: Creating folders
Action ended 05:25:50: CreateFolders. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: MoveFiles
Action 05:25:50: MoveFiles. Moving files
Action start 05:25:50: MoveFiles.
Action ended 05:25:50: MoveFiles. Return value 1.
MSI (s) (28:78) [05:25:50:600]: Doing action: InstallFiles
Action 05:25:50: InstallFiles. Copying new files
Action start 05:25:50: InstallFiles.
MSI (s) (28:78) [05:25:50:616]: Dumping binary patch manager data...
MSI (s) (28:78) [05:25:50:616]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
InstallFiles: File: Copying new files,  Directory: ,  Size:
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: PatchPackage
Action ended 05:25:50: InstallFiles. Return value 1.
MSI (s) (28:78) [05:25:50:616]: Doing action: NewCustomAction1
Action 05:25:50: NewCustomAction1.
Action start 05:25:50: NewCustomAction1.
NewCustomAction1:
Action ended 05:25:50: NewCustomAction1. Return value 1.
MSI (s) (28:78) [05:25:50:616]: Doing action: PatchFiles
Action 05:25:50: PatchFiles. Patching files
Action start 05:25:50: PatchFiles.
Action ended 05:25:50: PatchFiles. Return value 1.
MSI (s) (28:78) [05:25:50:616]: Doing action: DuplicateFiles
Action 05:25:50: DuplicateFiles. Creating duplicate files
Action start 05:25:50: DuplicateFiles.
Action ended 05:25:50: DuplicateFiles. Return value 1.
MSI (s) (28:78) [05:25:50:616]: Doing action: BindImage
Action 05:25:50: BindImage. Binding executables
Action start 05:25:50: BindImage.
Action ended 05:25:50: BindImage. Return value 1.
MSI (s) (28:78) [05:25:50:631]: Doing action: CreateShortcuts
Action 05:25:50: CreateShortcuts. Creating shortcuts
Action start 05:25:50: CreateShortcuts.
CreateShortcuts: Shortcut: Creating shortcuts
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 05:25:50: CreateShortcuts. Return value 0.
MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterClassInfo
Action 05:25:50: RegisterClassInfo. Registering class servers
Action start 05:25:50: RegisterClassInfo.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Class
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 05:25:50: RegisterClassInfo. Return value 0.
MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterExtensionInfo
Action 05:25:50: RegisterExtensionInfo. Registering extension servers
Action start 05:25:50: RegisterExtensionInfo.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Extension
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 05:25:50: RegisterExtensionInfo. Return value 0.
MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterProgIdInfo
Action 05:25:50: RegisterProgIdInfo. Registering program identifiers
Action start 05:25:50: RegisterProgIdInfo.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: ProgId
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 05:25:50: RegisterProgIdInfo. Return value 0.
MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterMIMEInfo
Action 05:25:50: RegisterMIMEInfo. Registering MIME info
Action start 05:25:50: RegisterMIMEInfo.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: MIME
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 05:25:50: RegisterMIMEInfo. Return value 0.
MSI (s) (28:78) [05:25:50:631]: Doing action: WriteRegistryValues
Action 05:25:50: WriteRegistryValues. Writing system registry values
Action start 05:25:50: WriteRegistryValues.
WriteRegistryValues: Key: Writing system registry values, Name: , Value:
Action ended 05:25:50: WriteRegistryValues. Return value 1.
MSI (s) (28:78) [05:25:50:631]: Doing action: WriteIniValues
Action 05:25:50: WriteIniValues. Writing INI file values
Action start 05:25:50: WriteIniValues.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: IniFile
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action ended 05:25:50: WriteIniValues. Return value 1.
MSI (s) (28:78) [05:25:50:631]: Doing action: WriteEnvironmentStrings
Action 05:25:50: WriteEnvironmentStrings. Updating environment strings
Action start 05:25:50: WriteEnvironmentStrings.
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Environment
MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action ended 05:25:50: WriteEnvironmentStrings. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterFonts
Action 05:25:50: RegisterFonts. Registering fonts
Action start 05:25:50: RegisterFonts.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Font
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action ended 05:25:50: RegisterFonts. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: InstallODBC
Action 05:25:50: InstallODBC. Installing ODBC components
Action start 05:25:50: InstallODBC.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action ended 05:25:50: InstallODBC. Return value 0.
MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterTypeLibraries
Action 05:25:50: RegisterTypeLibraries. Registering type libraries
Action start 05:25:50: RegisterTypeLibraries.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action ended 05:25:50: RegisterTypeLibraries. Return value 0.
MSI (s) (28:78) [05:25:50:647]: Doing action: SelfRegModules
Action 05:25:50: SelfRegModules. Registering modules
Action start 05:25:50: SelfRegModules.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action ended 05:25:50: SelfRegModules. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterComPlus
Action 05:25:50: RegisterComPlus. Registering COM+ Applications and Components
Action start 05:25:50: RegisterComPlus.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Complus
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action ended 05:25:50: RegisterComPlus. Return value 0.
MSI (s) (28:78) [05:25:50:647]: Doing action: InstallServices
Action 05:25:50: InstallServices. Installing new services
Action start 05:25:50: InstallServices.
MSI (s) (28:78) [05:25:50:647]: Detected older ServiceInstall table schema
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action ended 05:25:50: InstallServices. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: StartServices
Action 05:25:50: StartServices. Starting services
Action start 05:25:50: StartServices.
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 05:25:50: StartServices. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterUser
Action 05:25:50: RegisterUser. Registering user
Action start 05:25:50: RegisterUser.
RegisterUser: Registering user
Action ended 05:25:50: RegisterUser. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterProduct
Action 05:25:50: RegisterProduct. Registering product
Action start 05:25:50: RegisterProduct.
RegisterProduct: Registering product
MSI (s) (28:78) [05:25:50:647]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
Action ended 05:25:50: RegisterProduct. Return value 1.
MSI (s) (28:78) [05:25:50:647]: Doing action: PublishComponents
Action 05:25:50: PublishComponents. Publishing qualified components
Action start 05:25:50: PublishComponents.
MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 05:25:50: PublishComponents. Return value 0.
MSI (s) (28:78) [05:25:50:663]: Doing action: MsiPublishAssemblies
Action 05:25:50: MsiPublishAssemblies. Publishing assembly information
Action start 05:25:50: MsiPublishAssemblies.
MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 05:25:50: MsiPublishAssemblies. Return value 0.
MSI (s) (28:78) [05:25:50:663]: Doing action: PublishFeatures
Action 05:25:50: PublishFeatures. Publishing product features
Action start 05:25:50: PublishFeatures.
PublishFeatures: Feature: Publishing product features
Action ended 05:25:50: PublishFeatures. Return value 1.
MSI (s) (28:78) [05:25:50:663]: Doing action: PublishProduct
Action 05:25:50: PublishProduct. Publishing product information
Action start 05:25:50: PublishProduct.
1: Publishing product information
Action ended 05:25:50: PublishProduct. Return value 1.
MSI (s) (28:78) [05:25:50:663]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (28:78) [05:25:50:663]: Doing action: InstallFinalize
Action 05:25:50: InstallFinalize.
Action start 05:25:50: InstallFinalize.
MSI (s) (28:78) [05:25:50:663]: Running Script: C:\Windows\Installer\MSI2E1D.tmp
MSI (s) (28:78) [05:25:50:663]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (28:78) [05:25:50:663]: Machine policy value 'DisableRollback' is 0
MSI (s) (28:78) [05:25:50:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (28:78) [05:25:50:678]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (28:78) [05:25:50:678]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
MSI (s) (28:78) [05:25:50:678]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
Action 5:25:50: ProcessComponents. Updating component registration
MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\system32\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=1)
1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe
MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
Action 5:25:50: RemoveODBC. Removing ODBC components
MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
Action 5:25:50: CreateFolders. Creating folders
MSI (s) (28:78) [05:25:50:678]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
Action 5:25:50: InstallFiles. Copying new files
MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
MSI (s) (28:78) [05:25:50:678]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
MSI (s) (28:78) [05:25:50:678]: Executing op: SetSourceFolder(Folder=1\Temp\)
MSI (s) (28:78) [05:25:50:678]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Installer\1201d91.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (28:78) [05:25:50:678]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=InstallAX64.exe,DestName=InstallAX64.exe,Attributes=16384,FileSize=8767136,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=11.2.202.228,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (28:78) [05:25:50:678]: File: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
MSI (s) (28:78) [05:25:50:678]: Source for file 'InstallAX64.exe' is compressed
InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Ad~1\AppData\Local\Temp\,  Size: 8767136
MSI (s) (28:78) [05:25:50:772]: Executing op: CacheSizeFlush(,)
MSI (s) (28:78) [05:25:50:772]: Executing op: ActionStart(Name=NewCustomAction1,,)
Action 5:25:50: NewCustomAction1.
MSI (s) (28:78) [05:25:50:772]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,Target=-install -msi,)
CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (28:78) [05:25:53:788]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
Info 2835.The control ErrorIcon was not found on dialog SetupError.
Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
MSI (s) (28:78) [05:25:58:694]: Product: Adobe Flash Player 11 ActiveX (x64) -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
Action ended 05:25:58: InstallFinalize. Return value 3.
MSI (s) (28:78) [05:25:58:694]: User policy value 'DisableRollback' is 0
MSI (s) (28:78) [05:25:58:694]: Machine policy value 'DisableRollback' is 0
MSI (s) (28:78) [05:25:58:694]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
MSI (s) (28:78) [05:25:58:694]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
Action 5:25:58: Rollback. Rolling back action:
Rollback: NewCustomAction1
MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=NewCustomAction1,,)
MSI (s) (28:78) [05:25:58:694]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
Rollback: Copying new files
MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
MSI (s) (28:78) [05:25:58:694]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
MSI (s) (28:78) [05:25:58:694]: Executing op: FileRemove(,FileName=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,,)
Rollback: Creating folders
MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
MSI (s) (28:78) [05:25:58:709]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,SecurityDescriptor=BinaryData,)
Rollback: Removing ODBC components
MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
Rollback: Updating component registration
MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
MSI (s) (28:78) [05:25:58:709]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (s) (28:78) [05:25:58:709]: Error in rollback skipped. Return: 5
MSI (s) (28:78) [05:25:58:709]: Note: 1: 2318 2:
MSI (s) (28:78) [05:25:58:709]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 390, szDescription: "".
MSI (s) (28:78) [05:25:58:709]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
MSI (s) (28:78) [05:25:58:709]: Unlocking Server
MSI (s) (28:78) [05:25:59:350]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 05:25:59: INSTALL. Return value 3.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(S): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
Property(S): ProductToBeRegistered = 1
Property(S): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
Property(S): SOURCEDIR = C:\Users\Admin\Desktop\
Property(S): VersionNT = 601
Property(S): TARGETDIR = E:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): MACROMED = C:\Windows\system32\Macromed\
Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): System64Folder = C:\Windows\system32\
Property(S): CostingComplete = 1
Property(S): SourceDir = C:\Users\Admin\Desktop\
Property(S): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
Property(S): USERPROFILE = C:\Users\Admin\
Property(S): Preselected = 1
Property(S): UILevel = 5
Property(S): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
Property(S): DATABASE = C:\Windows\Installer\1201d91.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 4/12/2012
Property(S): Time = 5:25:59
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): ScreenX = 1024
Property(S): ProductName = Adobe Flash Player 11 ActiveX (x64)
Property(S): ALLUSERS = 1
Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(S): ARPNOMODIFY = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): SystemLanguageID = 1033
Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): InstallChoice = AR
Property(S): Manufacturer = Adobe Systems Incorporated
Property(S): MsiLogging = voicewarmupx
Property(S): NewProperty2 = 0
Property(S): NewProperty3 = 0
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductVersion = 11.2.202.228
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
Property(S): ARPINSTALLLOCATION = C:\Windows\system32\Macromed\Flash\
Property(S): ComputerName = NSDQ01
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
Property(S): LogonUser = Admin
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): VirtualMemory = 6406
Property(S): PhysicalMemory = 4094
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Users\Admin\Pictures\
Property(S): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): USERNAME = Viking
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): PersonalFolder = C:\Users\Admin\Documents\
Property(S): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): FavoritesFolder = C:\Users\Admin\Favorites\
Property(S): AppDataFolder = C:\Users\Admin\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): RemoteAdminTS = 1
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder = C:\Windows\
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 1
Property(S): WindowsBuild = 7601
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): MsiSystemRebootPending = 1
Property(S): ADDLOCAL = FlashPlayerAXInstaller
Property(S): CURRENTDIRECTORY = C:\Users\Admin\Desktop
Property(S): CLIENTUILEVEL = 0
Property(S): CLIENTPROCESSID = 4596
Property(S): VersionDatabase = 200
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = E:\
Property(S): SECONDSEQUENCE = 1
Property(S): PackagecodeChanging = 1
Property(S): ProductState = -1
Property(S): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
Property(S): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
MSI (s) (28:78) [05:25:59:366]: MainEngineThread is returning 1603
MSI (s) (28:94) [05:25:59:366]: RESTART MANAGER: Session closed.
MSI (s) (28:94) [05:25:59:366]: User policy value 'DisableRollback' is 0
MSI (s) (28:94) [05:25:59:366]: Machine policy value 'DisableRollback' is 0
MSI (s) (28:94) [05:25:59:366]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (28:94) [05:25:59:366]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (28:94) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (s) (28:94) [05:25:59:381]: Restoring environment variables
MSI (c) (F4:64) [05:25:59:381]: Back from server. Return value: 1603
MSI (c) (F4:64) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (F4:64) [05:25:59:381]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
Action ended 05:25:59: ExecuteAction. Return value 3.
MSI (c) (F4:64) [05:25:59:381]: Doing action: SetupCompleteError
Action 05:25:59: SetupCompleteError.
Action start 05:25:59: SetupCompleteError.
Action 05:25:59: SetupCompleteError. Dialog created
Action ended 05:26:00: SetupCompleteError. Return value 2.
Action ended 05:26:00: INSTALL. Return value 3.
MSI (c) (F4:64) [05:26:00:694]: Destroying RemoteAPI object.
MSI (c) (F4:DC) [05:26:00:709]: Custom Action Manager thread ending.
Property(C): DiskPrompt = [1]
Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(C): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
Property(C): PrimaryVolumeSpaceRemaining = 0
Property(C): PrimaryVolumeSpaceRequired = 0
Property(C): PrimaryVolumeSpaceAvailable = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): OutOfDiskSpace = 0
Property(C): VersionNT = 601
Property(C): TARGETDIR = E:\
Property(C): ALLUSERSPROFILE = C:\ProgramData\
Property(C): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): MACROMED = C:\Windows\system32\Macromed\
Property(C): FLASH = C:\Windows\system32\Macromed\Flash\
Property(C): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(C): System64Folder = C:\Windows\system32\
Property(C): CostingComplete = 1
Property(C): ROOTDRIVE = E:\
Property(C): SourceDir = C:\Users\Admin\Desktop\
Property(C): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
Property(C): USERPROFILE = C:\Users\Admin\
Property(C): EXECUTEACTION = INSTALL
Property(C): ACTION = INSTALL
Property(C): UILevel = 5
Property(C): VersionHandler = 5.00
Property(C): SOURCEDIR = C:\Users\Admin\Desktop\
Property(C): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
Property(C): DATABASE = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
Property(C): Privileged = 1
Property(C): MsiRunningElevated = 1
Property(C): RedirectedDllSupport = 2
Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
Property(C): MsiNetAssemblySupport = 4.0.30319.1
Property(C): Date = 4/12/2012
Property(C): Time = 05:26:00
Property(C): TTCSupport = 1
Property(C): ISCHECKFORPRODUCTUPDATES = 1
Property(C): ApplicationUsers = AllUsers
Property(C): AgreeToLicense = No
Property(C): _IsMaintenance = Change
Property(C): RestartManagerOption = CloseRestart
Property(C): IS_SQLSERVER_USERNAME = sa
Property(C): IS_SQLSERVER_AUTHENTICATION = 0
Property(C): SetupType = Typical
Property(C): _IsSetupTypeMin = Typical
Property(C): Display_IsBitmapDlg = 1
Property(C): ProductName = Adobe Flash Player 11 ActiveX (x64)
Property(C): ALLUSERS = 1
Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(C): ARPNOMODIFY = 1
Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(C): ARPURLINFOABOUT = http://www.adobe.com
Property(C): ColorBits = 32
Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
Property(C): DWUSINTERVAL = 30
Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(C): DefaultUIFont = Tahoma8
Property(C): DialogCaption = InstallShield for Windows Installer
Property(C): DisplayNameCustom = Custom
Property(C): DisplayNameMinimal = Minimal
Property(C): DisplayNameTypical = Typical
Property(C): ErrorDialog = SetupError
Property(C): INSTALLLEVEL = 100
Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(C): ISVROOT_PORT_NO = 0
Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(C): InstallChoice = AR
Property(C): Manufacturer = Adobe Systems Incorporated
Property(C): MsiLogging = voicewarmupx
Property(C): NewProperty2 = 0
Property(C): NewProperty3 = 0
Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(C): ProductID = none
Property(C): ProductLanguage = 1033
Property(C): ProductVersion = 11.2.202.228
Property(C): ProgressType0 = install
Property(C): ProgressType1 = Installing
Property(C): ProgressType2 = installed
Property(C): ProgressType3 = installs
Property(C): RebootYesNo = Yes
Property(C): ReinstallModeText = omus
Property(C): SHOWLAUNCHPROGRAM = 0
Property(C): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(C): TextInternalLeading = 3
Property(C): TextHeight = 16
Property(C): BorderSide = 1
Property(C): BorderTop = 1
Property(C): AdminUser = 1
Property(C): CaptionHeight = 22
Property(C): ScreenY = 1080
Property(C): ScreenX = 1920
Property(C): SystemLanguageID = 1033
Property(C): ComputerName = NSDQ01
Property(C): UserLanguageID = 1033
Property(C): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
Property(C): LogonUser = Admin
Property(C): MsiTrueAdminUser = 1
Property(C): VirtualMemory = 6439
Property(C): PhysicalMemory = 4094
Property(C): Intel = 6
Property(C): Msix64 = 6
Property(C): MsiAMD64 = 6
Property(C): ShellAdvtSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): GPTSupport = 1
Property(C): FontsFolder = C:\Windows\Fonts\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): USERNAME = Viking
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): MyPicturesFolder = C:\Users\Admin\Pictures\
Property(C): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): PersonalFolder = C:\Users\Admin\Documents\
Property(C): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): FavoritesFolder = C:\Users\Admin\Favorites\
Property(C): AppDataFolder = C:\Users\Admin\AppData\Roaming\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): RemoteAdminTS = 1
Property(C): SystemFolder = C:\Windows\SysWOW64\
Property(C): WindowsVolume = C:\
Property(C): WindowsFolder = C:\Windows\
Property(C): MsiNTProductType = 1
Property(C): ServicePackLevelMinor = 0
Property(C): ServicePackLevel = 1
Property(C): WindowsBuild = 7601
Property(C): VersionNT64 = 601
Property(C): VersionMsi = 5.00
Property(C): VersionDatabase = 200
Property(C): MsiSystemRebootPending = 1
Property(C): CLIENTPROCESSID = 4596
Property(C): CLIENTUILEVEL = 0
Property(C): CURRENTDIRECTORY = C:\Users\Admin\Desktop
Property(C): PackagecodeChanging = 1
Property(C): ProductState = -1
Property(C): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
Property(C): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
=== Logging stopped: 4/12/2012  05:26:00 ===
MSI (c) (F4:64) [05:26:00:709]: Note: 1: 1708
MSI (c) (F4:64) [05:26:00:709]: Product: Adobe Flash Player 11 ActiveX (x64) -- Installation operation failed.
MSI (c) (F4:64) [05:26:00:709]: Windows Installer installed the product. Product Name: Adobe Flash Player 11 ActiveX (x64). Product Version: 11.2.202.228. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
MSI (c) (F4:64) [05:26:00:709]: Grabbed execution mutex.
MSI (c) (F4:64) [05:26:00:709]: Cleaning up uninstalled install packages, if any exist
MSI (c) (F4:64) [05:26:00:709]: MainEngineThread is returning 1603
=== Verbose logging stopped: 4/12/2012  05:26:00 ===
Adobe Employee ,
Apr 12, 2012 Apr 12, 2012
Are you running the .msi or .exe?  If .msi, can you try the .exe instead?
Chris, I did all three: MSI, MSI extracted EXE, and EXE. With a re-check or permissions and a Adobe clean up w/ reboot between. Running as admin. SW, reader, and java all removed and reinstalled without issue.
Thnak you.
Adobe Employee ,
could you post the contents of your flashinstall.log?
Where do I find the Flash Player installation log on Windows?
Installed the EXE extracted from the MSI.
32 BIT:
=O====== M/11.2.202.228 2012-04-13+02-38-35.903 ========
0000 00000010 "C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit\InstallAX64.exe"
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0004 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
0012 00000018
0013 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
0014 00000011 1
=X====== M/11.2.202.228 2012-04-13+02-40-02.410 ========
And now 64 BIT:
=O====== M/11.2.202.228 2012-04-13+02-38-44.262 ========
0000 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
0001 00000010 "C:\Users\Admin\AppData\Local\Temp\{962A8EE6-178E-4769-95EC-7ADB7C363052}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1
0002 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00001102
0012 00001106
0013 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
0014 00000018
0015 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
=X====== M/11.2.202.228 2012-04-13+02-38-49.458 ========
Thank you.
There are obviously some permission problems (80070005).
Can you try
P.S. you got the names wrong: system32 is 64-bit, syswow64 is 32-bit.
Done and rebooted. @ PS Long day . Tried install, same results.
=O====== M/11.2.202.228 2012-04-13+03-21-24.389 ========
0000 00001113 C:\Windows\system32\Macromed\Flash\\* 3
0001 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_64bit.exe" -force
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 00001018
0006 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
0007 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0008 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0009 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0010 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0011 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0012 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0013 00001021
0014 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0016 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0017 00001048
0018 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0019 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0020 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0021 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0022 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0023 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0024 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0025 00001018
0026 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0027 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0028 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0029 00001019
0030 00001020
0031 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0032 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0033 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0034 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0035 00001021
0036 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0037 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0038 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0039 00001048
0040 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0041 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0042 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0043 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0044 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0045 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0046 00001036 Software\Opera Software/Last CommandLine 2
0047 00001036 Software\Opera Software/Last CommandLine 2
0048 00001036 Software\Opera Software/Plugin Path 2
0049 00001036 Software\Opera Software/Plugin Path 2
0050 00000011 1
=X====== M/11.2.202.228 2012-04-13+03-21-29.170 ========
=O====== M/11.2.202.228 2012-04-13+03-34-50.133 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe" -install -msi
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
0010 00000018
=X====== M/11.2.202.228 2012-04-13+03-34-57.058 ========
Next
=O====== M/11.2.202.228 2012-04-13+03-21-19.202 ========
0001 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_32bit.exe" -force
0002 00001042
=X====== M/11.2.202.228 2012-04-13+03-21-22.061 ========
=O====== M/11.2.202.228 2012-04-13+03-21-27.717 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{5BB16666-101E-410A-B931-A384C4339FEC}\InstallFlashPlayer.exe" -force  -uninstall
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00001018
0003 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
0005 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0006 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0007 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0008 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0009 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0010 00001021
0011 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0012 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0013 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
0014 00001048
0015 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0016 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0017 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0018 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
0021 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0022 00001018
0023 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0024 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0025 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0026 00001019
0027 00001020
0028 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0029 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0030 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0031 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0032 00001021
0033 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0034 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0035 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
0036 00001048
0037 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0038 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0039 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0040 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
0043 00001036 Software\Opera Software/Last CommandLine 2
0044 00001036 Software\Opera Software/Last CommandLine 2
0045 00001036 Software\Opera Software/Plugin Path 2
0046 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.2.202.228 2012-04-13+03-21-27.874 ========
And
=== Verbose logging started: 4/12/2012  22:33:46  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
MSI (c) (64:A0) [22:33:46:086]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (64:B0) [22:33:46:102]: Resetting cached policy values
MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'Debug' is 0
MSI (c) (64:B0) [22:33:46:102]: ******* RunEngine:
           ******* Product: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi' against software restriction policy
MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi has a digital signature
MSI (c) (64:B0) [22:33:46:243]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (64:B0) [22:33:46:336]: Cloaking enabled.
MSI (c) (64:B0) [22:33:46:336]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (64:B0) [22:33:46:336]: End dialog not enabled
MSI (c) (64:B0) [22:33:46:336]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
MSI (c) (64:B0) [22:33:46:336]: Package we're running from ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (64:B0) [22:33:46:383]: MSCOREE not loaded loading copy from system32
MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'TransformsSecure' is 0
MSI (c) (64:B0) [22:33:46:415]: User policy value 'TransformsAtSource' is 0
MSI (c) (64:B0) [22:33:46:415]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisablePatch' is 0
MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (64:B0) [22:33:46:430]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (64:B0) [22:33:46:430]: Transforms are not secure.
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
MSI (c) (64:B0) [22:33:46:430]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download CLIENTUILEVEL=0 CLIENTPROCESSID=3940
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
MSI (c) (64:B0) [22:33:46:430]: Product Code passed to Engine.Initialize:           ''
MSI (c) (64:B0) [22:33:46:430]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (c) (64:B0) [22:33:46:430]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (c) (64:B0) [22:33:46:430]: Product not registered: beginning first-time install
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (64:B0) [22:33:46:430]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (64:B0) [22:33:46:430]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (64:B0) [22:33:46:430]: Adding new sources is allowed.
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (64:B0) [22:33:46:430]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
MSI (c) (64:B0) [22:33:46:430]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableMsi' is 0
MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (64:B0) [22:33:46:430]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (64:B0) [22:33:46:430]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (64:B0) [22:33:46:430]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
MSI (c) (64:B0) [22:33:46:430]: TRANSFORMS property is now:
MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (64:B0) [22:33:46:446]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
MSI (c) (64:B0) [22:33:46:446]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (c) (64:A0) [22:33:46:477]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 4/12/2012  22:33:46 ===
MSI (c) (64:B0) [22:33:46:477]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (64:B0) [22:33:46:477]: Machine policy value 'DisableRollback' is 0
MSI (c) (64:B0) [22:33:46:477]: User policy value 'DisableRollback' is 0
MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (64:B0) [22:33:46:477]: Doing action: INSTALL
Action 22:33:46: INSTALL.
Action start 22:33:46: INSTALL.
MSI (c) (64:B0) [22:33:46:477]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (64:B0) [22:33:46:477]: Running UISequence
MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (64:B0) [22:33:46:477]: Doing action: ISSetAllUsers
Action 22:33:46: ISSetAllUsers.
Action start 22:33:46: ISSetAllUsers.
MSI (c) (64:B0) [22:33:46:524]: Creating MSIHANDLE (1) of type 790542 for thread 1968
MSI (c) (64:2C) [22:33:46:540]: Invoking remote custom action. DLL: C:\Users\Admin\AppData\Local\Temp\MSI8A0F.tmp, Entrypoint: SetAllUsers
MSI (c) (64:A8) [22:33:46:540]: Cloaking enabled.
MSI (c) (64:A8) [22:33:46:540]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (64:A8) [22:33:46:540]: Connected to service for CA interface.
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (2) of type 790531 for thread 3748
InstallShield 22:33:46: Begin SetAllUsers()
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (2) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (3) of type 790541 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (4) of type 790531 for thread 3748
InstallShield 22:33:46: Getting records from Upgrade table
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (4) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (5) of type 790540 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (6) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (7) of type 790531 for thread 3748
InstallShield 22:33:46: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (7) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (8) of type 790531 for thread 3748
InstallShield 22:33:46: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (8) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (6) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (9) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (10) of type 790531 for thread 3748
InstallShield 22:33:46: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (10) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (11) of type 790531 for thread 3748
InstallShield 22:33:46: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (11) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (9) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (12) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (13) of type 790531 for thread 3748
InstallShield 22:33:46: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (13) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (14) of type 790531 for thread 3748
InstallShield 22:33:46: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (14) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (12) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (15) of type 790531 for thread 3748
InstallShield 22:33:46: End SetAllUsers()
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (15) of type 790531 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (5) of type 790540 for thread 3748
MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (3) of type 790541 for thread 3748
MSI (c) (64:2C) [22:33:46:821]: Closing MSIHANDLE (1) of type 790542 for thread 1968
Action ended 22:33:46: ISSetAllUsers. Return value 1.
MSI (c) (64:B0) [22:33:46:821]: Doing action: AppSearch
Action 22:33:46: AppSearch. Searching for installed applications
Action start 22:33:46: AppSearch.
MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2205 2:  3: AppSearch
MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
Action ended 22:33:46: AppSearch. Return value 0.
MSI (c) (64:B0) [22:33:46:821]: Doing action: LaunchConditions
Action 22:33:46: LaunchConditions. Evaluating launch conditions
Action start 22:33:46: LaunchConditions.
Action ended 22:33:46: LaunchConditions. Return value 1.
MSI (c) (64:B0) [22:33:46:821]: Doing action: SetupInitialization
Action 22:33:46: SetupInitialization.
Action start 22:33:46: SetupInitialization.
Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 22:33:46: SetupInitialization. Dialog created
Action ended 22:33:46: SetupInitialization. Return value 1.
MSI (c) (64:B0) [22:33:46:852]: Doing action: FindRelatedProducts
Action 22:33:46: FindRelatedProducts. Searching for related applications
Action start 22:33:46: FindRelatedProducts.
Action ended 22:33:46: FindRelatedProducts. Return value 1.
MSI (c) (64:B0) [22:33:46:852]: Skipping action: CCPSearch (condition is false)
MSI (c) (64:B0) [22:33:46:852]: Skipping action: RMCCPSearch (condition is false)
MSI (c) (64:B0) [22:33:46:852]: Doing action: ValidateProductID
Action 22:33:46: ValidateProductID.
Action start 22:33:46: ValidateProductID.
Action ended 22:33:46: ValidateProductID. Return value 1.
MSI (c) (64:B0) [22:33:46:852]: Doing action: CostInitialize
Action 22:33:46: CostInitialize. Computing space requirements
Action start 22:33:46: CostInitialize.
MSI (c) (64:B0) [22:33:46:852]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (64:B0) [22:33:46:852]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
MSI (c) (64:B0) [22:33:46:852]: Baseline: New baseline 11.2.202 from transaction.
MSI (c) (64:B0) [22:33:46:899]: Baseline: Sorted order Native: Order 0.
MSI (c) (64:B0) [22:33:46:899]: Baseline Data Table:
MSI (c) (64:B0) [22:33:46:899]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (c) (64:B0) [22:33:46:899]: Baseline File Table:
MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 22:33:46: CostInitialize. Return value 1.
MSI (c) (64:B0) [22:33:46:915]: Doing action: FileCost
Action 22:33:46: FileCost. Computing space requirements
Action start 22:33:46: FileCost.
MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: MsiAssembly
MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Class
MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Extension
MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: TypeLib
Action ended 22:33:46: FileCost. Return value 1.
MSI (c) (64:B0) [22:33:46:915]: Doing action: IsolateComponents
Action 22:33:46: IsolateComponents.
Action start 22:33:46: IsolateComponents.
Action ended 22:33:46: IsolateComponents. Return value 0.
MSI (c) (64:B0) [22:33:46:915]: Doing action: setUserProfileNT
Action 22:33:46: setUserProfileNT.
Action start 22:33:46: setUserProfileNT.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
Action ended 22:33:46: setUserProfileNT. Return value 1.
MSI (c) (64:B0) [22:33:46:930]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (c) (64:B0) [22:33:46:930]: Doing action: setAllUsersProfile2K
Action 22:33:46: setAllUsersProfile2K.
Action start 22:33:46: setAllUsersProfile2K.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action ended 22:33:46: setAllUsersProfile2K. Return value 1.
MSI (c) (64:B0) [22:33:46:930]: Doing action: ResolveSource
Action 22:33:46: ResolveSource.
Action start 22:33:46: ResolveSource.
MSI (c) (64:B0) [22:33:46:930]: Resolving source.
MSI (c) (64:B0) [22:33:46:930]: Resolving source to launched-from source.
MSI (c) (64:B0) [22:33:46:930]: Setting launched-from source as last-used.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
MSI (c) (64:B0) [22:33:46:930]: Determining source type
MSI (c) (64:B0) [22:33:46:930]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
MSI (c) (64:B0) [22:33:46:930]: Source path resolution complete. Dumping Directory table...
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
Action ended 22:33:46: ResolveSource. Return value 1.
MSI (c) (64:B0) [22:33:46:930]: Doing action: CostFinalize
Action 22:33:46: CostFinalize. Computing space requirements
Action start 22:33:46: CostFinalize.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: Condition
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (c) (64:B0) [22:33:46:930]: Target path resolution complete. Dumping Directory table...
MSI (c) (64:B0) [22:33:46:930]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TARGETDIR , Object: E:\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: MsiAssembly
MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 22:33:46: CostFinalize. Return value 1.
MSI (c) (64:B0) [22:33:46:930]: Doing action: MigrateFeatureStates
Action 22:33:46: MigrateFeatureStates. Migrating feature states from related applications
Action start 22:33:46: MigrateFeatureStates.
Action ended 22:33:46: MigrateFeatureStates. Return value 0.
MSI (c) (64:B0) [22:33:46:930]: Skipping action: PatchWelcome (condition is false)
MSI (c) (64:B0) [22:33:46:930]: Doing action: InstallWelcome
Action 22:33:46: InstallWelcome.
Action start 22:33:46: InstallWelcome.
Action 22:33:46: InstallWelcome. Dialog created
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (64:D8) [22:33:46:946]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: BindImage
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: ProgId
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: PublishComponent
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: SelfReg
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Extension
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Font
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Shortcut
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Class
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: TypeLib
MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2727 2:
Action ended 22:33:48: InstallWelcome. Return value 1.
MSI (c) (64:B0) [22:33:48:430]: Skipping action: SetupResume (condition is false)
MSI (c) (64:B0) [22:33:48:430]: Skipping action: MaintenanceWelcome (condition is false)
MSI (c) (64:B0) [22:33:48:430]: Doing action: SetupProgress
Action 22:33:48: SetupProgress.
Action start 22:33:48: SetupProgress.
Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 22:33:48: SetupProgress. Dialog created
Action ended 22:33:48: SetupProgress. Return value 1.
MSI (c) (64:B0) [22:33:48:477]: Doing action: ExecuteAction
Action 22:33:48: ExecuteAction.
Action start 22:33:48: ExecuteAction.
MSI (c) (64:B0) [22:33:48:477]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (c) (64:B0) [22:33:48:477]: Grabbed execution mutex.
MSI (c) (64:B0) [22:33:48:477]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (64:B0) [22:33:48:477]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\__Download\" USERNAME="Jasper" CLIENTPROCESSID="3940" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop\__Download"  ADDLOCAL=FlashPlayerAXInstaller
MSI (s) (F8:E8) [22:33:48:493]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
MSI (s) (F8:E8) [22:33:48:493]: Grabbed execution mutex.
MSI (s) (F8:C8) [22:33:48:493]: Resetting cached policy values
MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'Debug' is 0
MSI (s) (F8:C8) [22:33:48:493]: ******* RunEngine:
           ******* Action: INSTALL
MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109110000000000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109110000000000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109440090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109440090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109510090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109510090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109511090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109511090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109610090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109610090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109611090400100000000F01FEC
MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109611090400100000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109711090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109711090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109810090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109810090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109910090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109910090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (F8:C8) [22:33:48:508]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (F8:C8) [22:33:48:508]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
MSI (s) (F8:C8) [22:33:48:508]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
MSI (s) (F8:C8) [22:34:43:743]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 394.
MSI (s) (F8:C8) [22:34:43:743]: File will have security applied from OpCode.
MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi' against software restriction policy
MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi has a digital signature
MSI (s) (F8:C8) [22:34:44:524]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (F8:C8) [22:34:44:524]: End dialog not enabled
MSI (s) (F8:C8) [22:34:44:524]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
MSI (s) (F8:C8) [22:34:44:524]: Package we're running from ==> C:\Windows\Installer\869bf.msi
MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (F8:C8) [22:34:44:524]: MSCOREE not loaded loading copy from system32
MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'TransformsSecure' is 0
MSI (s) (F8:C8) [22:34:44:524]: User policy value 'TransformsAtSource' is 0
MSI (s) (F8:C8) [22:34:44:524]: Note: 1: 2205 2:  3: MsiFileHash
MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisablePatch' is 0
MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (F8:C8) [22:34:44:524]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (F8:C8) [22:34:44:540]: Transforms are not secure.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
MSI (s) (F8:C8) [22:34:44:540]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\__Download\ USERNAME=Jasper CLIENTPROCESSID=3940 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
MSI (s) (F8:C8) [22:34:44:540]: Product Code passed to Engine.Initialize:           ''
MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
MSI (s) (F8:C8) [22:34:44:540]: Product not registered: beginning first-time install
MSI (s) (F8:C8) [22:34:44:540]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
MSI (s) (F8:C8) [22:34:44:540]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (F8:C8) [22:34:44:540]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (F8:C8) [22:34:44:540]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (F8:C8) [22:34:44:540]: Adding new sources is allowed.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (F8:C8) [22:34:44:540]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
MSI (s) (F8:C8) [22:34:44:540]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
MSI (s) (F8:C8) [22:34:44:540]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableMsi' is 0
MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F8:C8) [22:34:44:540]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F8:C8) [22:34:44:540]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (F8:C8) [22:34:44:540]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'da7e3209e9117142ada46c8feb786c33'.
MSI (s) (F8:C8) [22:34:44:540]: RESTART MANAGER: Session opened.
MSI (s) (F8:C8) [22:34:44:540]: Engine has iefSecondSequence set to true.
MSI (s) (F8:C8) [22:34:44:540]: TRANSFORMS property is now:
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (F8:C8) [22:34:44:586]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (F8:C8) [22:34:44:602]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\869bf.msi'.
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (F8:C8) [22:34:44:602]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'DisableRollback' is 0
MSI (s) (F8:C8) [22:34:44:602]: User policy value 'DisableRollback' is 0
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: INSTALL
Action 22:34:44: INSTALL.
Action start 22:34:44: INSTALL.
MSI (s) (F8:C8) [22:34:44:602]: Running ExecuteSequence
MSI (s) (F8:C8) [22:34:44:602]: Doing action: ISSetAllUsers
Action 22:34:44: ISSetAllUsers.
Action start 22:34:44: ISSetAllUsers.
MSI (s) (F8:C8) [22:34:44:602]: Skipping action due to msidbCustomActionTypeFirstSequence option.
Action ended 22:34:44: ISSetAllUsers. Return value 0.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: AppSearch
Action 22:34:44: AppSearch. Searching for installed applications
Action start 22:34:44: AppSearch.
MSI (s) (F8:C8) [22:34:44:602]: Skipping AppSearch action: already done on client side
Action ended 22:34:44: AppSearch. Return value 0.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: LaunchConditions
Action 22:34:44: LaunchConditions. Evaluating launch conditions
Action start 22:34:44: LaunchConditions.
Action ended 22:34:44: LaunchConditions. Return value 1.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: FindRelatedProducts
Action 22:34:44: FindRelatedProducts. Searching for related applications
Action start 22:34:44: FindRelatedProducts.
MSI (s) (F8:C8) [22:34:44:602]: Skipping FindRelatedProducts action: already done on client side
Action ended 22:34:44: FindRelatedProducts. Return value 0.
MSI (s) (F8:C8) [22:34:44:602]: Skipping action: CCPSearch (condition is false)
MSI (s) (F8:C8) [22:34:44:602]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (F8:C8) [22:34:44:602]: Doing action: ValidateProductID
Action 22:34:44: ValidateProductID.
Action start 22:34:44: ValidateProductID.
Action ended 22:34:44: ValidateProductID. Return value 1.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostInitialize
Action 22:34:44: CostInitialize. Computing space requirements
Action start 22:34:44: CostInitialize.
MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
MSI (s) (F8:C8) [22:34:44:602]: Baseline: New baseline 11.2.202 from transaction.
MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorted order Native: Order 0.
MSI (s) (F8:C8) [22:34:44:602]: Baseline Data Table:
MSI (s) (F8:C8) [22:34:44:602]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (s) (F8:C8) [22:34:44:602]: Baseline File Table:
MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
MSI (s) (F8:C8) [22:34:44:602]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
Action ended 22:34:44: CostInitialize. Return value 1.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: FileCost
Action 22:34:44: FileCost. Computing space requirements
Action start 22:34:44: FileCost.
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Class
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Extension
MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: TypeLib
Action ended 22:34:44: FileCost. Return value 1.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: IsolateComponents
Action 22:34:44: IsolateComponents.
Action start 22:34:44: IsolateComponents.
Action ended 22:34:44: IsolateComponents. Return value 0.
MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostFinalize
Action 22:34:44: CostFinalize. Computing space requirements
Action start 22:34:44: CostFinalize.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Condition
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (F8:C8) [22:34:44:618]: Target path resolution complete. Dumping Directory table...
MSI (s) (F8:C8) [22:34:44:618]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TARGETDIR , Object: E:\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 22:34:44: CostFinalize. Return value 1.
MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetARPINSTALLLOCATION
Action 22:34:44: SetARPINSTALLLOCATION.
Action start 22:34:44: SetARPINSTALLLOCATION.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
Action ended 22:34:44: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetODBCFolders
Action 22:34:44: SetODBCFolders. Initializing ODBC directories
Action start 22:34:44: SetODBCFolders.
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action ended 22:34:44: SetODBCFolders. Return value 0.
MSI (s) (F8:C8) [22:34:44:618]: Doing action: MigrateFeatureStates
Action 22:34:44: MigrateFeatureStates. Migrating feature states from related applications
Action start 22:34:44: MigrateFeatureStates.
MSI (s) (F8:C8) [22:34:44:618]: Skipping MigrateFeatureStates action: already done on client side
Action ended 22:34:44: MigrateFeatureStates. Return value 0.
MSI (s) (F8:C8) [22:34:44:618]: Doing action: InstallValidate
Action 22:34:44: InstallValidate. Validating install
Action start 22:34:44: InstallValidate.
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'da7e3209e9117142ada46c8feb786c33'.
MSI (s) (F8:C8) [22:34:44:618]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (F8:C8) [22:34:44:618]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (F8:C8) [22:34:44:618]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (F8:C8) [22:34:44:618]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: BindImage
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ProgId
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Extension
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Font
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Class
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiFileHash
MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2727 2:
MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: FilesInUse
MSI (s) (F8:C8) [22:34:44:743]: Note: 1: 2727 2:
Action ended 22:34:44: InstallValidate. Return value 1.
MSI (s) (F8:C8) [22:34:44:743]: Doing action: RemoveExistingProducts
Action 22:34:44: RemoveExistingProducts. Removing applications
Action start 22:34:44: RemoveExistingProducts.
Action ended 22:34:44: RemoveExistingProducts. Return value 1.
MSI (s) (F8:C8) [22:34:44:743]: Doing action: InstallInitialize
Action 22:34:44: InstallInitialize.
Action start 22:34:44: InstallInitialize.
MSI (s) (F8:C8) [22:34:44:743]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F8:C8) [22:34:44:743]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F8:C8) [22:34:44:743]: BeginTransaction: Locking Server
MSI (s) (F8:C8) [22:34:44:743]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
Action ended 22:34:48: InstallInitialize. Return value 1.
MSI (s) (F8:C8) [22:34:48:727]: Skipping action: CallExeUninstaller (condition is false)
MSI (s) (F8:C8) [22:34:48:727]: Doing action: MakePropsAvailable
Action 22:34:48: MakePropsAvailable.
Action start 22:34:48: MakePropsAvailable.
MSI (s) (F8:C8) [22:34:48:727]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
Action ended 22:34:48: MakePropsAvailable. Return value 1.
MSI (s) (F8:C8) [22:34:48:743]: Doing action: AllocateRegistrySpace
Action 22:34:48: AllocateRegistrySpace. Allocating registry space
Action start 22:34:48: AllocateRegistrySpace.
Action ended 22:34:48: AllocateRegistrySpace. Return value 1.
MSI (s) (F8:C8) [22:34:48:743]: Doing action: ProcessComponents
Action 22:34:48: ProcessComponents. Updating component registration
Action start 22:34:48: ProcessComponents.
MSI (s) (F8:C8) [22:34:48:743]: Note: 1: 2205 2:  3: MsiPatchCertificate
MSI (s) (F8:C8) [22:34:48:743]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (F8:C8) [22:34:48:743]: Resolving source.
MSI (s) (F8:C8) [22:34:48:743]: Resolving source to launched-from source.
MSI (s) (F8:C8) [22:34:48:743]: Setting launched-from source as last-used.
MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
MSI (s) (F8:C8) [22:34:48:743]: Determining source type
MSI (s) (F8:C8) [22:34:48:743]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
MSI (s) (F8:C8) [22:34:48:743]: Source path resolution complete. Dumping Directory table...
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
Action 22:34:48: GenerateScript. Generating script operations for action:
GenerateScript: Updating component registration
Action ended 22:34:48: ProcessComponents. Return value 1.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishComponents
Action 22:34:48: UnpublishComponents. Unpublishing Qualified Components
Action start 22:34:48: UnpublishComponents.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: UnpublishComponents. Return value 0.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: MsiUnpublishAssemblies
Action 22:34:48: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 22:34:48: MsiUnpublishAssemblies.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: MsiUnpublishAssemblies. Return value 0.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishFeatures
Action 22:34:48: UnpublishFeatures. Unpublishing product features
Action start 22:34:48: UnpublishFeatures.
Action ended 22:34:48: UnpublishFeatures. Return value 1.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: StopServices
Action 22:34:48: StopServices. Stopping services
Action start 22:34:48: StopServices.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 22:34:48: StopServices. Return value 1.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: DeleteServices
Action 22:34:48: DeleteServices. Deleting services
Action start 22:34:48: DeleteServices.
Action ended 22:34:48: DeleteServices. Return value 1.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterComPlus
Action 22:34:48: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 22:34:48: UnregisterComPlus.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: Complus
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action ended 22:34:48: UnregisterComPlus. Return value 0.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: SelfUnregModules
Action 22:34:48: SelfUnregModules. Unregistering modules
Action start 22:34:48: SelfUnregModules.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action ended 22:34:48: SelfUnregModules. Return value 1.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterTypeLibraries
Action 22:34:48: UnregisterTypeLibraries. Unregistering type libraries
Action start 22:34:48: UnregisterTypeLibraries.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action ended 22:34:48: UnregisterTypeLibraries. Return value 0.
MSI (s) (F8:C8) [22:34:48:836]: Doing action: RemoveODBC
Action 22:34:48: RemoveODBC. Removing ODBC components
Action start 22:34:48: RemoveODBC.
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2711 2: ODBCDriverManager
1: Removing ODBC components
MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2711 2: ODBCDriverManager64
Action ended 22:34:48: RemoveODBC. Return value 1.
MSI (s) (F8:C8) [22:34:48:852]: Doing action: UnregisterFonts
Action 22:34:48: UnregisterFonts. Unregistering fonts
Action start 22:34:48: UnregisterFonts.
MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2205 2:  3: Font
MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action ended 22:34:48: UnregisterFonts. Return value 1.
MSI (s) (F8:C8) [22:34:48:868]: Doing action: RemoveRegistryValues
Action 22:34:48: RemoveRegistryValues. Removing system registry values
Action start 22:34:48: RemoveRegistryValues.
Action ended 22:34:48: RemoveRegistryValues. Return value 1.
MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterClassInfo
Action 22:34:48: UnregisterClassInfo. Unregister class servers
Action start 22:34:48: UnregisterClassInfo.
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Class
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: UnregisterClassInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterExtensionInfo
Action 22:34:48: UnregisterExtensionInfo. Unregistering extension servers
Action start 22:34:48: UnregisterExtensionInfo.
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Extension
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: UnregisterExtensionInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterProgIdInfo
Action 22:34:48: UnregisterProgIdInfo. Unregistering program identifiers
Action start 22:34:48: UnregisterProgIdInfo.
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: ProgId
MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: UnregisterProgIdInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterMIMEInfo
Action 22:34:48: UnregisterMIMEInfo. Unregistering MIME info
Action start 22:34:48: UnregisterMIMEInfo.
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: MIME
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: UnregisterMIMEInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveIniValues
Action 22:34:48: RemoveIniValues. Removing INI file entries
Action start 22:34:48: RemoveIniValues.
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: IniFile
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action ended 22:34:48: RemoveIniValues. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveShortcuts
Action 22:34:48: RemoveShortcuts. Removing shortcuts
Action start 22:34:48: RemoveShortcuts.
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 22:34:48: RemoveShortcuts. Return value 0.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveEnvironmentStrings
Action 22:34:48: RemoveEnvironmentStrings. Updating environment strings
Action start 22:34:48: RemoveEnvironmentStrings.
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Environment
MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action ended 22:34:48: RemoveEnvironmentStrings. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveDuplicateFiles
Action 22:34:48: RemoveDuplicateFiles. Removing duplicated files
Action start 22:34:48: RemoveDuplicateFiles.
Action ended 22:34:48: RemoveDuplicateFiles. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveFolders
Action 22:34:48: RemoveFolders. Removing folders
Action start 22:34:48: RemoveFolders.
Action ended 22:34:48: RemoveFolders. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: CreateFolders
Action 22:34:48: CreateFolders. Creating folders
Action start 22:34:48: CreateFolders.
CreateFolders: Folder: Creating folders
Action ended 22:34:48: CreateFolders. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: MoveFiles
Action 22:34:48: MoveFiles. Moving files
Action start 22:34:48: MoveFiles.
Action ended 22:34:48: MoveFiles. Return value 1.
MSI (s) (F8:C8) [22:34:48:899]: Doing action: InstallFiles
Action 22:34:48: InstallFiles. Copying new files
Action start 22:34:48: InstallFiles.
MSI (s) (F8:C8) [22:34:48:915]: Dumping binary patch manager data...
MSI (s) (F8:C8) [22:34:48:915]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
InstallFiles: File: Copying new files,  Directory: ,  Size:
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: PatchPackage
Action ended 22:34:48: InstallFiles. Return value 1.
MSI (s) (F8:C8) [22:34:48:946]: Doing action: NewCustomAction1
Action 22:34:48: NewCustomAction1.
Action start 22:34:48: NewCustomAction1.
NewCustomAction1:
Action ended 22:34:48: NewCustomAction1. Return value 1.
MSI (s) (F8:C8) [22:34:48:946]: Doing action: PatchFiles
Action 22:34:48: PatchFiles. Patching files
Action start 22:34:48: PatchFiles.
Action ended 22:34:48: PatchFiles. Return value 1.
MSI (s) (F8:C8) [22:34:48:946]: Doing action: DuplicateFiles
Action 22:34:48: DuplicateFiles. Creating duplicate files
Action start 22:34:48: DuplicateFiles.
Action ended 22:34:48: DuplicateFiles. Return value 1.
MSI (s) (F8:C8) [22:34:48:946]: Doing action: BindImage
Action 22:34:48: BindImage. Binding executables
Action start 22:34:48: BindImage.
Action ended 22:34:48: BindImage. Return value 1.
MSI (s) (F8:C8) [22:34:48:946]: Doing action: CreateShortcuts
Action 22:34:48: CreateShortcuts. Creating shortcuts
Action start 22:34:48: CreateShortcuts.
CreateShortcuts: Shortcut: Creating shortcuts
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 22:34:48: CreateShortcuts. Return value 0.
MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterClassInfo
Action 22:34:48: RegisterClassInfo. Registering class servers
Action start 22:34:48: RegisterClassInfo.
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Class
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 22:34:48: RegisterClassInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterExtensionInfo
Action 22:34:48: RegisterExtensionInfo. Registering extension servers
Action start 22:34:48: RegisterExtensionInfo.
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Extension
MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 22:34:48: RegisterExtensionInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterProgIdInfo
Action 22:34:48: RegisterProgIdInfo. Registering program identifiers
Action start 22:34:48: RegisterProgIdInfo.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ProgId
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 22:34:48: RegisterProgIdInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterMIMEInfo
Action 22:34:48: RegisterMIMEInfo. Registering MIME info
Action start 22:34:48: RegisterMIMEInfo.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: MIME
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 22:34:48: RegisterMIMEInfo. Return value 0.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteRegistryValues
Action 22:34:48: WriteRegistryValues. Writing system registry values
Action start 22:34:48: WriteRegistryValues.
WriteRegistryValues: Key: Writing system registry values, Name: , Value:
Action ended 22:34:48: WriteRegistryValues. Return value 1.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteIniValues
Action 22:34:48: WriteIniValues. Writing INI file values
Action start 22:34:48: WriteIniValues.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: IniFile
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action ended 22:34:48: WriteIniValues. Return value 1.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteEnvironmentStrings
Action 22:34:48: WriteEnvironmentStrings. Updating environment strings
Action start 22:34:48: WriteEnvironmentStrings.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Environment
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action ended 22:34:48: WriteEnvironmentStrings. Return value 1.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterFonts
Action 22:34:48: RegisterFonts. Registering fonts
Action start 22:34:48: RegisterFonts.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Font
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action ended 22:34:48: RegisterFonts. Return value 1.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: InstallODBC
Action 22:34:48: InstallODBC. Installing ODBC components
Action start 22:34:48: InstallODBC.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action ended 22:34:48: InstallODBC. Return value 0.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterTypeLibraries
Action 22:34:48: RegisterTypeLibraries. Registering type libraries
Action start 22:34:48: RegisterTypeLibraries.
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action ended 22:34:48: RegisterTypeLibraries. Return value 0.
MSI (s) (F8:C8) [22:34:48:977]: Doing action: SelfRegModules
Action 22:34:48: SelfRegModules. Registering modules
Action start 22:34:48: SelfRegModules.
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action ended 22:34:48: SelfRegModules. Return value 1.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterComPlus
Action 22:34:48: RegisterComPlus. Registering COM+ Applications and Components
Action start 22:34:48: RegisterComPlus.
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: Complus
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action ended 22:34:48: RegisterComPlus. Return value 0.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: InstallServices
Action 22:34:48: InstallServices. Installing new services
Action start 22:34:48: InstallServices.
MSI (s) (F8:C8) [22:34:48:993]: Detected older ServiceInstall table schema
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action ended 22:34:48: InstallServices. Return value 1.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: StartServices
Action 22:34:48: StartServices. Starting services
Action start 22:34:48: StartServices.
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 22:34:48: StartServices. Return value 1.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterUser
Action 22:34:48: RegisterUser. Registering user
Action start 22:34:48: RegisterUser.
RegisterUser: Registering user
Action ended 22:34:48: RegisterUser. Return value 1.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterProduct
Action 22:34:48: RegisterProduct. Registering product
Action start 22:34:48: RegisterProduct.
RegisterProduct: Registering product
MSI (s) (F8:C8) [22:34:48:993]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
Action ended 22:34:48: RegisterProduct. Return value 1.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: PublishComponents
Action 22:34:48: PublishComponents. Publishing qualified components
Action start 22:34:48: PublishComponents.
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 22:34:48: PublishComponents. Return value 0.
MSI (s) (F8:C8) [22:34:48:993]: Doing action: MsiPublishAssemblies
Action 22:34:49: MsiPublishAssemblies. Publishing assembly information
Action start 22:34:49: MsiPublishAssemblies.
MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 22:34:49: MsiPublishAssemblies. Return value 0.
MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishFeatures
Action 22:34:49: PublishFeatures. Publishing product features
Action start 22:34:49: PublishFeatures.
PublishFeatures: Feature: Publishing product features
Action ended 22:34:49: PublishFeatures. Return value 1.
MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishProduct
Action 22:34:49: PublishProduct. Publishing product information
Action start 22:34:49: PublishProduct.
1: Publishing product information
Action ended 22:34:49: PublishProduct. Return value 1.
MSI (s) (F8:C8) [22:34:49:024]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (F8:C8) [22:34:49:024]: Doing action: InstallFinalize
Action 22:34:49: InstallFinalize.
Action start 22:34:49: InstallFinalize.
MSI (s) (F8:C8) [22:34:49:024]: Running Script: C:\Windows\Installer\MSI7D49.tmp
MSI (s) (F8:C8) [22:34:49:024]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (F8:C8) [22:34:49:024]: Machine policy value 'DisableRollback' is 0
MSI (s) (F8:C8) [22:34:49:086]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F8:C8) [22:34:49:086]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082963033,LangId=1033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
MSI (s) (F8:C8) [22:34:49:102]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
Action 22:34:49: ProcessComponents. Updating component registration
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\system32\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=1)
1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
Action 22:34:49: RemoveODBC. Removing ODBC components
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
Action 22:34:49: CreateFolders. Creating folders
MSI (s) (F8:C8) [22:34:49:102]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
Action 22:34:49: InstallFiles. Copying new files
MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetTargetFolder(Folder=C:\Users\Admin\AppData\Local\Temp\)
MSI (s) (F8:C8) [22:34:49:118]: Executing op: SetSourceFolder(Folder=1\Temp\)
MSI (s) (F8:C8) [22:34:49:118]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Installer\869bf.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F8:C8) [22:34:49:118]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=InstallAX64.exe,DestName=InstallAX64.exe,Attributes=16384,FileSize=8767136,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=11.2.202.228,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (F8:C8) [22:34:49:118]: File: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
MSI (s) (F8:C8) [22:34:49:118]: Source for file 'InstallAX64.exe' is compressed
InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Admin\AppData\Local\Temp\,  Size: 8767136
MSI (s) (F8:C8) [22:34:49:290]: Executing op: CacheSizeFlush(,)
MSI (s) (F8:C8) [22:34:49:290]: Executing op: ActionStart(Name=NewCustomAction1,,)
Action 22:34:49: NewCustomAction1.
MSI (s) (F8:C8) [22:34:49:290]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe,Target=-install -msi,)
CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (F8:C8) [22:34:57:066]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
Info 2835.The control ErrorIcon was not found on dialog SetupError.
Apr 12, 2012 Apr 12, 2012
Now it worked!! Just reapplied the steps again. Thank you for the help!
Apr 14, 2012 Apr 14, 2012
i just used the link that carl provided to run the installer . My flash sucessfully installed and everything works fine now. Thank you everyone
