Hi all,
I need something like a hundred different thumbnails from each image in a series of images, that is, hundred random sections of the same image, saved in a folder as jpg, and i was hoping that i could find a script for this.
What the script has to do is:
I dont think this should be to difficult to make a script for, but unfortunately i don´t know how to code.
Is there anybody that could help me with this?
This would save me a lot of time!
Maybe because you have not considered the difficulty of calculating the offset of the rotated content so as not to exceed the existing image’s edge – or maybe your math-skills are just better than mine.
In any case it should be possible to achieve the intended result.
What do you need it for, if I may ask?
Edit: Not 100% sure about the randomization, but the resulting files look fairly random …
dear, C.Pfaffenbichler,
This looks really good - exactly what i was looking for! Is it possible to chose the dimensions and number of thumbnails? If so, its perfect!
It´s something i want to try out for an art project - the intention is to use the thumbnails as a base for a series of drawings, so its not a big problem if not all the thumbnails are inside the format. I just need a big selection.
Could you send me the code? That would be amazing!
You can give this a try:
// create copies with pseudo random clipped and rotated parts of image;
// thanks to xbytor;
// 2012, use at your own risk;
#target photoshop
if (app.documents.length > 0) {
var originalRulerUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.POINTS;
// set name for folder to save jpgs to;
var folderName = "rotatedJpgs";
// set number of jpgs;
var theNumber = 100;
// width and height;
var theWidth = 500;
var theHeight = 500;
// calculate some values;
var theDiagonal = Math.sqrt ((theWidth * theWidth) + (theHeight * theHeight));
var diagAngle = angleFromRadians(Math.acos((theWidth) / (theDiagonal)));
// get file name and path;
var myDocument = app.activeDocument;
var docName = myDocument.name;
try {
var basename = docName.match(/(.*)\.[^\.]+$/)[1];
var docPath = myDocument.path;
catch (e) {
basename = docName;
var docPath = "~/Desktop";
// create folder if it does not exist yet;
if (Folder(docPath + "/" + folderName).exists == true) {
var docPath = docPath + "/" + folderName;
else {
var theFolder = Folder(docPath + "/" + folderName).create();
// document dimensions;
var docWidth = myDocument.width;
var docHeight = myDocument.height;
// jpg options;
var jpegOptions = new JPEGSaveOptions();
jpegOptions.quality = 10;
jpegOptions.embedColorProfile = true;
jpegOptions.matte = MatteType.NONE;
// duplicate image;
var theCopy = myDocument.duplicate (theCopy, true);
var origResolution = theCopy.resolution;
theCopy.resizeImage(undefined, undefined, 72, ResampleMethod.NONE);
var docHalfWidth = theCopy.width / 2;
var docHalfHeight = theCopy.height / 2;
var theLayer = smartify2010(theCopy.layers[0]);
theCopy.resizeCanvas (theWidth, theHeight, AnchorPosition.MIDDLECENTER);
var theHistoryState = theCopy.activeHistoryState;
// do the variations;
for (var m = 0; m < theNumber; m++) {
var theAngle = Math.random() * 360;
theLayer.rotate (theAngle, AnchorPosition.MIDDLECENTER);
//theCopy.resizeCanvas (theWidth, theHeight, AnchorPosition.MIDDLECENTER);
// get tolerance offset;
var theHor1 = Math.abs(Math.cos(radiansOf(theAngle + diagAngle)) * theDiagonal / 2);
var theVer1 = Math.abs(Math.sin(radiansOf(theAngle + diagAngle)) * theDiagonal/ 2);
var theHor2 = Math.abs(Math.cos(radiansOf(theAngle - diagAngle)) * theDiagonal / 2);
var theVer2 = Math.abs(Math.sin(radiansOf(theAngle - diagAngle)) * theDiagonal / -2);
// calculate max offset for unrotated overall rectangle;
var thisHalfWidth = docHalfWidth - Math.max(theHor1, theHor2);
var thisHalfHeight = docHalfHeight - Math.max(theVer1, theVer2);
// calculate random offset for unrotated overall rectangle;
var randomX = thisHalfWidth * (Math.random() - 0.5) * 2;
var randomY = thisHalfHeight * (Math.random() - 0.5) * 2;
var aDiag = Math.sqrt (randomX * randomX + randomY * randomY);
var anAngle = angleFromRadians(Math.asin((randomY) / (aDiag))) + theAngle;
anAngle = anAngle + Math.floor(Math.random() * 2) * 180;
// calculate offset for rotated overall rectangle;
var offsetX = Math.cos(radiansOf(anAngle)) * aDiag;
var offsetY = Math.sin(radiansOf(anAngle)) * aDiag;
//alert (theAngle+"\n\n"+offsetX +"\n"+ offsetY+"\n\n"+ thisHalfWidth+"\n"+thisHalfHeight);
theLayer.translate(offsetX, offsetY);
theCopy.resizeImage(undefined, undefined, origResolution, ResampleMethod.NONE);
theCopy.saveAs((new File(docPath+"/"+basename+"_"+bufferNumberWithZeros(m+1, 3)+".jpg")),jpegOptions,true);
theCopy.activeHistoryState = theHistoryState;
// clean up;
theCopy.close(SaveOptions.DONOTSAVECHANGES);
app.preferences.rulerUnits = originalRulerUnits;
////// radians //////
function radiansOf (theAngle) {
return theAngle * Math.PI / 180
function angleFromRadians (theRad) {
return theRad / Math.PI * 180
////// buffer number with zeros //////
function bufferNumberWithZeros (number, places) {
var theNumberString = String(number);
for (var o = 0; o < (places - String(number).length); o++) {
theNumberString = String("0" + theNumberString)
return theNumberString
////// function to smartify if not //////
function smartify2010 (theLayer) {
// make layers smart objects if they are not already;
app.activeDocument.activeLayer = theLayer;
// process pixel-layers and groups;
if (theLayer.kind == "LayerKind.GRADIENTFILL" || theLayer.kind == "LayerKind.LAYER3D" || theLayer.kind == "LayerKind.NORMAL" ||
theLayer.kind == "LayerKind.PATTERNFILL" || theLayer.kind == "LayerKind.SOLIDFILL" ||
theLayer.kind == "LayerKind.TEXT" || theLayer.kind == "LayerKind.VIDEO" || theLayer.typename == "LayerSet") {
var id557 = charIDToTypeID( "slct" );
var desc108 = new ActionDescriptor();
var id558 = charIDToTypeID( "null" );
var ref77 = new ActionReference();
var id559 = charIDToTypeID( "Mn " );
var id560 = charIDToTypeID( "MnIt" );
var id561 = stringIDToTypeID( "newPlacedLayer" );
ref77.putEnumerated( id559, id560, id561 );
desc108.putReference( id558, ref77 );
executeAction( id557, desc108, DialogModes.NO )
return app.activeDocument.activeLayer
if (theLayer.kind == LayerKind.SMARTOBJECT || theLayer.kind == "LayerKind.VIDEO") {return theLayer};
////// get an angle, 3:00 being 0˚, 6:00 90˚, etc. //////
function getAngle (pointOne, pointTwo) {
// calculate the triangle sides;
var width = pointTwo[0] - pointOne[0];
var height = pointTwo[1] - pointOne[1];
var sideC = Math.sqrt(Math.pow(width, 2) + Math.pow(height, 2));
// calculate the angles;
if (width+width > width) {theAngle = Math.asin(height / sideC) * 360 / 2 / Math.PI}
else {theAngle = 180 - (Math.asin(height / sideC) * 360 / 2 / Math.PI)};
if (theAngle < 0) {theAngle = (360 + theAngle)};
return theAngle
