I get an error when I try to bring the default colors by pressing "D" then I try to swith them pressing "X" while I select some area.
When I select D and X, they work as expected.
I guess the obvious first question to you would be, "What is the error that you get?"
Some other things that may be helpful to know are:
What type of system are you on? (mac/pc, what OS)
What video board are you using and is the driver up to date?
When you say "while I select some area" I assume that means you have an area selected on the screen when you do this , right?
Pattie
ok, when I press on D and X they work without any problems.
but when I try to do this while I'm selecting an area I get the error message.
- pc windows 7 ultimate 64bit
-Nividia G-force 525, the driver is the latest update.
-right, when I have an Area selected on the screen then try to press D then X I get the error message that photoshop has stopped working.
OK. so which specific driver are you using for nVidia, file name and date? (I have an nVidia board and it was out of date the day my pc arrived, causing crashes) Also, are there two video boards in you system or one? In some cases, Nvidia has a setup screen as to which to use for heavy GPU processing in Photoshop and other programs.
I tried with and without a selection on my screen and had no issues, so let's figure out what is different on your machine.
When Photoshop crashes doesn't it give you a window that allows you to copy crash information?
If f it does, will you please copy that information here along with the information from your system information in Photoshop (all above the serial number), then we'll take a look at it. If it does not give you this screen, then is it just hung up (stuck) and you have to exit using task manager?
Pattie
I am interpreting that you loaded the new driver, made sure of the settings using nVidia board instead of Intel for Photoshop, and that the error is gone, right?
If you do get a crash again, (that is what happens when it asks you to close the program) please copy the information from the crash and post it here along with all the information above your serial number in the system information (from the main Photoshop menu, Hellp>System Info)
Pattie
Reply from Kareem:
well the driver is 296.10 and I've two graphics boards one is intel and the other is nvidia.
also I made sure that photoshop runs on the nvidia's one.
something strange happend that the error is no longer been appears !!!
about the error message it just included that photoshop has stopped working and asked me to close the program.
