Hi all. My brother in-law sent us two .mkv videos and a DVD .iso he wants me to use in a video I am cutting for him. The only trouble is, I've no idea how to get them into a format PremPro can handle.
I've searched and the only solutions I have found are infinitely complicated for me. Avisynth is certainly beyond me.
Anyone know of a way to convert .mkv (info lists 942x720 H.264 4:2:0 YUV MPEG4 AVC) into something useable?
Same question for an ISO file.
Thanks much
By the way, this is not for anything 'important' nor am I getting paid, so I have no budget tp purchase software. I am sure there must be a free solution.
I tried this trial version software...
http://www.moyea.com/import-flv/
But it would NOT install. It just errored in a loop and was unable to find or understand I have CS5 PremPro.
For the .ISO first burn it to disk and then copy the .VOB files to your hard disk and import those into your project. Notice this will only work if the .ISO is FULLY DVD compliant. If not, then you have to figure out your own approach. For the Matroska files, I haven't the faintest idea.
The best approach however is to ask your brother in law for the source material, since Matroska and ISO are not meant to be edited.
Hey there, Harn. Unfortunatelty, that is all he has. I explained this makes it difficult, but he lost the source material.
For the mkv I just found a freware that supposedly does not put a watermark on the video so I am testing it out.
As for the iso... Fully dvd compliant/ No idea. guess I will find out.
Off-topic replys branched and moved. Use the link at the top of this thread. Or this one:
http://forums.adobe.com/message/4360196#4360196
Jeff
EDIT: EuroSiti did offer this workaround for the OP:
Here's a workaround:
Use the freeware tool Avidemux to extract the H.264 AVC video stream from the MKV container.
Hopefully Premiere Pro will let you import that H.264 video file. Edit it and export it as a video stream again afterwards.
Then remux the H.264 stream with MKVmerge (also free). Open the original MKV file in MKVmerge and replace the old video stream with your edited version.
That way you may be able to preserve the advanced indexing and multiple audio+subtitle tracks in the Matroska file.
Good luck.
Does Adapter have a Direct Stream Copy option?
That way you don't have to actually convert the video & audio streams ( = quality loss). There is no reason to convert the actual streams.
The video has most likely already been MPEG4/H264 compressed when the MKV file was created.
A really good conversion tool will allow you to simply change the file container without transcoding the audio & video streams again - plus it saves quite a lot of time if it's a long video.
TEncoder has this feature - and it's also free.
But of course: You still have to bear in mind that the MP4 container is much more restrictive than the Matroska container, so you might be forced to convert anyway.
Lack of MKV support is usually an indication of commercial arrogance.
Can anyone explain how to use VLC to transcode? The settings are endless and NONE look correct. Everything is about coverting and shrinking and that is not what I want.
I have looked into this so many times and cannot find how to do it. I know it must be simple, but clearly I am blind.
What I need is to take whatever is inside that stupid MKV wrapper and extract it. Transcode it. I have been trying for A YEAR now and have never been able to find a solution.
I'm on a PC and unfortunately, there are free solutions for a MAC. But that won't help me.
EDIT: One option I see is tsMuxer! But which setting for Output? I can choose...
TS muxing... or M2TS musing... or Blu-ray disk... or AVCHD disk... or DEMUX
To explain more, I have a Blu-Ray I purchased and want to add the audio from my laserdisc, since the remixed audio on the disc sucks (hard). I'll also add English subtitles. To be clear, this work is for ME for my own personal use.
Here is a screen grab from tsMuxer. Which to choose? I will place the audio and video in Premiere Pro. Sync the old Laserdisc audio up and then EXPORT to Adobe Encore to burn a new BD.
