When cropping my crop area (square/rectangle/what-have-you) is always snapping to some sort of invisible grid. Is this just how Lr4 works or is there a setting I have settup incorrectly?
And also, When I crop an image I have to move the image into the cropping "square" and cut of a portion of the photo but it's only part of the image I want cropped. And when I do have the image I press "return" and the image appears to be cropped until I go to crop more of the image. Suddenly I'm left back at the state before the previous crop. What am I doing wrong?
Thanks! (I hope this makes sense)
No, not really ;-)
I am unclear whether you might be bitten from a bug or if you need some explanations about what to expect.
So I'll adress the latter. To chase a bug you need to give more info about your OS and the steps you are exactly doing.
Snapping while in crop mode is something I know when I try to switch from a portrait image to crop for landscape or vice versa. If I want to crop like this I hit the X key first, as this will give me the same image ratio with the side-lenghts swapped. Then I can drag around without further snapping.
LR displays cropping the opposite way as Photoshop: you move the image underneath the crop-rectangle, not placing the crop part on top the image.
As LR is non-destructive, you should get your latest crop rectangle ("overlay" in proper terms) displayed again whenever you return to crop mode. So you start refining from there.
If you do not see the crop overlay you may have toggled off the visibility of overlays. Set it back to visible from the menu choices in the crop panel in the top right corner.
Cornelia
OK...
Well first thing first... I'm running Lr4 on a Mac Pro... ![]()
The cropping is different then photoshop for sure... Basically, almost inverted. So, my Lr4 is functioning fine. It's just my tactics which are reversed. This is good to know.
One question... How do I tell Lr4 I'm done/satisfied with the newly cropped image? I guess the "Done" button at the bottom? Or do I need export the updated image?
Also, Is the rectangle the only way to crop an image? Can there be a square or even possibly a circular crop function?
When you are satisfied, you either hit the <enter> key or click on "close" on the crop-panel. It is the bottom of the crop panel, but that is still high on the right-hand panel.
I do not find a "done" in my LR4.0.
...as I am more of a keyboard-guy than mouse-guy I always have to take a look to answer.
<esc> is the shortest way to abandon the crop endeavour and return to where you started invoking the crop (which could be library module if you used the R key).
To my knowledge you can only crop in rectangular way. You have different overlays to guide your decision-making (like spiral etc. - toggle with O key), but the result will always be some rectangle, which can be square, of course.
If you open the padlock you are free to drag the ratio, or you could choose from the drop-down menu "Aspect" one of the presets or enter your own dimensions. LR will recalculate them, though and display maybe different.
So circular is not possible.
For circular you could employ a trick e.g. in Print module: create a watermark or identity plate with circular opening, opaque for the rest.
Yes, I am on windows.
X is "mark as delete" for me also when I am in Library module.
But once I am in crop tool (after having hit R) the X becomes "invert ratio width-length".
Crop overlays: I have two-thirds, diagonal envelop-like, spiral, narrow grid. That is hitting O once in crop tool (after R) to toggle them all thru.
Shortcuts are identical on Mac and Windows apart from the modifier keys ctrl-vs-cmd, alt-vs-opt.
So I'd expect you see the same.
Cornelia
Yes...
You are correct... But I also noticed I had "A" Constrain Aspect Ratio checked which was really giving me a difficult time until I unchecked it.
Thanks for the help... I understand now that it's not the application... It's just the way I'm used to designing as apposed to the way Lr4 works.
I still find it interesting though that you do not have a "Done" button at the lower right-hand corner of the crop window.
Thanks again
