Title Tools crash on Mac
Apr 7, 2012 12:57 AM
Can anyone help me with this? I've been trying to get the Titler applet in Premiere Pro CS5 to work, but no matter what I do it just gives me the beachball of death upon trying to spawn a new title. I did practically everything from removing duplicate fonts and clearing the font caches, to even reinstalling the whole thing, but still it doesn't let me make a title at all!
I'm running the app on OS X 10.5.8, by the way.
    Apr 7, 2012 8:18 AM   in reply to bgripling
    I know that on a PC, bad, poorly-written, or corrupt fonts will cause Titler to hang, or crash. Not sure how different fonts might be on a Mac. Could be the same, or totally different. This ARTICLE goes into some detail, but you might have to "read between the lines," as I wrote it for the PC.
    Many Adobe programs, such as Photoshop, Illustrator and InDesign, are very sensitive to fonts, and Titler is sensitive to another level.
    Good luck,
    Hunt
    PS - If you narrow things down to a "bad" font (not one that is corrupt), please update this thread, and I will add that one to the article.
    Apr 8, 2012 5:23 PM   in reply to bgripling
    So have you done the other standard procedures when things get funky on a Mac...Trash Prefs and Repair Permissions ?
    Apr 8, 2012 7:05 PM   in reply to bgripling
    I did however manage to make the thing load when I started OS X in Safe Boot mode, as only the fallback fonts are loaded when in that mode.
    Hm-m, sounds like a classic "bad font" issue, but I could be wrong.
    Good luck,
    Hunt
    Apr 8, 2012 7:19 PM   in reply to Bill Hunt
    I agree Bill. It certainly does sound like a bad font issue.
    Apr 9, 2012 7:00 AM   in reply to lasvideo
    Thirded.
    Try using Font Book (or another font management app, if you use it), and disable all but the system fonts, and if that keeps Pr from crashing, then start enabling the ones you previously had activated a few at a time until it crashes again, and that should tell you which fonts are bad.
    You could also try something like FontExplorer X to run a search and repair for bad fonts.  The repair function is iffy, but it does a good job of finding bad fonts.
    Apr 9, 2012 7:15 AM   in reply to Jim Curtis
    Jim,
    Being a PC-only guy, I am obviously not familiar with that program, but have seen fonts that "passed muster" with some pretty good PC font repair tools, that still were written in such a way, that Titler crashed (can happen with Photoshop, InDesign and Illustrator, but those programs seem to be more lenient, than Titler). In two cases, I just found that replacing them with a commercially available version, fixed things. Where the font was not corrupt, but still caused a crash, I have just found something similar commercially, and used that, instead. Some foundries just design better fonts, than others.
    Good luck to the OP,
    Hunt
    Apr 9, 2012 7:22 AM   in reply to Bill Hunt
    Bill, my experience is similar to yours... I replace bad fonts with a fresh copy when FEX fails to fix them.  I keep a copy of my fonts zipped in a backup file, and can replace them pretty easily when disaster strikes.
    Apr 9, 2012 1:58 PM   in reply to Jim Curtis
    Jim,
    It's the same here. I do a DVD backup of my fonts, keeping the old ones (once were on CD's), just in case I have to re-install them. It also helps, when I get a new machine, due to all the fonts that I have bought, or collected over the years.
    I use a font manager, so only ~ 350 are installed at any one time (unless I have a lot of different clients' Projects going at one time), so it is easy (or relatively so) to track a bad, or corrupt font on my system. If I load a client/Project font set, and get a crash, then I know that one of those is the culprit.
    Going back some years, I ran Font Dr. (Extensis) on ALL of my fonts. Most were not loaded, and obviously, when they had been, I was working in less sensitive programs, as I was getting no crashes. There were a couple of dozen, that needed repair, but only ~ 12 (out of then many thousands), that could not be fixed, and I studied them, as much as I could, and just bought any, that I found useful. Some, I just deleted.
    Hunt
