I've just installed Photoshop CS6 on an i7 PC wiht 16 gig of RAM and plenty of hard drive space. I've got 25 errors and 2 warning in the install logs. Can someone please tell me where or to whom I should send this file?
Doug
Further to the 64 bit install problems I've been having.
I'll post the summary here because I leave for interstate in half an hour and won't have access to the forum for 10 days.
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Bridge CS6 (64 Bit): Install failed
ERROR: DW050: - AdobePDFL x64 CS6: Install failed
ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS6 x64: Install failed
ERROR: DW050: - Adobe Photoshop CS6 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050: - Photoshop Camera Raw 7 (64 bit): Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS6 x64: Install failed
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - Adobe Player for Embedding x64 3.3: Install failed
ERROR: DW050: - AdobeCMaps x64 CS6: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS6: Install failed
ERROR: DW050: - Adobe Linguistics CS6 x64: Install failed
ERROR: DW050: - Adobe Photoshop CS6 English Language Pack_x64_AdobePhotoshop13-en_US_x64: Install failed
Doug has left for work interstate. I'm monitoring his mail until he returns. Margie is my Name, I am Doug's PA and can help you find any logs of other information you need in his absence.
Doug deleted all reference to Photoshop CS6 from his PC before leaving but by using Photoshop CS5, I obtained the following system information from his computer:
I'll monitor his mail and answer you when required.
Adobe Photoshop Version: 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch]) x64
Operating System: Windows 7 64-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:10, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Physical processor count: 4
Processor speed: 3073 MHz
Built-in memory: 12279 MB
Free memory: 8946 MB
Memory available to Photoshop: 10946 MB
Memory used by Photoshop: 75 %
Image tile size: 132K
Image cache levels: 6
Display: 2
Display Bounds:= top: 0, left: -1600, bottom: 1200, right: 0
Display: 1
Display Bounds:= top: 0, left: 0, bottom: 1080, right: 1920
Video Card Number: 1
Video Card: ATI Radeon HD 5800 Series
Driver Version: 8.951.0.0
Driver Date: 20120308000000.000000-000
Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,ati umd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdv a,atiumd6a.cap,atitmm64.dll
Video Mode: 1920 x 1080 x 4294967296 colors
Video Card Caption: ATI Radeon HD 5800 Series
Video Card Memory: 1024 MB
Serial number: 91198735701417563220
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\
Temporary file path: C:\Users\doug\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
K:\, 370.1G, 349.2G free
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2010/10/04-23:36:11 64.441628 64.441628
adbeape.dll Adobe APE 2010/02/23-12:40:58 61.421986 61.421986
AdobeLinguistic.dll Adobe Linguisitc Library 5.0.0
AdobeOwl.dll Adobe Owl 2010/06/03-13:43:23 3.0.93 61.433187
AdobeOwlCanvas.dll Adobe Owl Canvas 3.0.68 61.2954
AdobePDFL.dll PDFL 2010/12/13-23:37:10 64.341419 64.341419
AdobePIP.dll Adobe Product Improvement Program 5.0.0.2021
AdobeXMP.dll Adobe XMP Core 5.0 61.134777
AdobeXMPFiles.dll Adobe XMP Files 5.0 61.134777
AdobeXMPScript.dll Adobe XMP Script 5.0 61.134777
adobe_caps.dll Adobe CAPS 3,0,116,0
adobe_OOBE_Launcher.dll Adobe OOBE Launcher 1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00) 1.000000
AFlame.dll AFlame 2010/02/23-17:27:33 61.421976 61.421976
AFlamingo.dll AFlamingo 2010/02/23-17:27:33 61.421978 61.421978
AGM.dll AGM 2010/10/04-23:36:11 64.441628 64.441628
ahclient.dll AdobeHelp Dynamic Link Library 1,5,0,30
aif_core.dll AIF 2.0 53.422628
aif_ogl.dll AIF 2.0 53.422628
amtlib.dll AMTLib (64 Bit) 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) 1.000000
amtservices.dll AMTServices (64 Bit) 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) 1.000000
ARE.dll ARE 2010/10/04-23:36:11 64.441628 64.441628
asneu.dll AsnEndUser Dynamic Link Library 1, 7, 0, 1
AXE8SharedExpat.dll AXE8SharedExpat 2010/02/23-17:27:33 61.421978 61.421978
AXEDOMCore.dll AXEDOMCore 2010/02/23-17:27:33 61.421978 61.421978
Bib.dll BIB 2010/10/04-23:36:11 64.441628 64.441628
BIBUtils.dll BIBUtils 2010/10/04-23:36:11 64.441628 64.441628
boost_threads.dll DVA Product 5.0.0
cg.dll NVIDIA Cg Runtime 2.0.0015
cgGL.dll NVIDIA Cg Runtime 2.0.0015
CoolType.dll CoolType 2010/10/04-23:36:11 64.441628 64.441628
data_flow.dll AIF 2.0 53.422628
dvaadameve.dll DVA Product 5.0.0
dvacore.dll DVA Product 5.0.0
dvaui.dll DVA Product 5.0.0
ExtendScript.dll ExtendScript 2010/10/19-10:22:12 61.445301 61.445301
FileInfo.dll Adobe XMP FileInfo 5.0 61.134777
icucnv36.dll International Components for Unicode 2009/06/17-13:21:03 Build gtlib_main.9896
icudt36.dll International Components for Unicode 2009/06/17-13:21:03 Build gtlib_main.9896
icudt42.dll International Components for Unicode 4, 2, 0, 0
icuin42.dll International Components for Unicode 4, 2, 0, 0
icuuc42.dll International Components for Unicode 4, 2, 0, 0
image_flow.dll AIF 2.0 53.422628
image_runtime.dll AIF 2.0 53.422628
JP2KLib.dll JP2KLib 2010/12/13-23:37:10 64.181312 64.181312
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 10.0
LogSession.dll LogSession 2, 0, 1, 11
MPS.dll MPS 2010/12/13-23:37:10 64.450375 64.450375
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.6161
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.6161
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.6161
onOneActivationToolbox.dll onOneActivationToolbox 1.0.1
onOneToolbox2.dll onOne Toolbox2 Dynamic Link Library 2.2.0
onOneWelcomeDialog.dll Essentials 1.0.0.1
OnOneWidgets.dll OnOneWidgets dll 2.5
ONProxySupport.dll TODO: <Product name> 1.0.0.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CS5 CS5
Plugin.dll Adobe Photoshop CS5 CS5
PlugPlug.dll Adobe(R) CSXS PlugPlug Standard Dll (64 bit) 2.0.0.746
PSArt.dll Adobe Photoshop CS5 CS5
PSViews.dll Adobe Photoshop CS5 CS5
SCCore.dll ScCore 2010/10/19-10:22:12 61.445301 61.445301
tbb.dll Threading Building Blocks 2, 1, 2009, 0201
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 1.0.0.68 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 1.0.0.68
WRServices.dll WRServices Thursday January 21 2010 12:13:3 Build 0.11423 0.11423
wu3d.dll U3D Writer 9.3.0.113
zlib.dll zlib 1.2.5
Installed plug-ins:
Accented Edges 12.0
ADM 3.11x01
Alias PIX 12.0 (12.0x20100407 [20100407.r.1103 2010/04/07:14:00:00 cutoff; r branch])
Angled Strokes 12.0
Average 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Bas Relief 12.0
BMP 12.0.2
Camera Raw 6.6
Chalk & Charcoal 12.0
Charcoal 12.0
Chrome 12.0
Cineon 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Clouds 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Color Halftone 12.0.2
Colored Pencil 12.0
CompuServe GIF 12.0.2
Contact Sheet II 12.0 (12.0x001)
Conté Crayon 12.0
Craquelure 12.0
Crop and Straighten Photos 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Crop and Straighten Photos Filter 12.0.2
Crosshatch 12.0
Crystallize 12.0.2
Cutout 12.0
Dark Strokes 12.0
De-Interlace 12.0.2
Difference Clouds 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Diffuse Glow 12.0
Displace 12.0.2
Dry Brush 12.0
DxO FilmPack 3 NO VERSION
Eazel Acquire 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
ElectricImage 12.0
Embed Watermark 4.0
Extract 12.0 (12.0x001)
Extrude 12.0.2
FastCore Routines 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Fibers 12.0.2
Film Grain 12.0
Filter Gallery 12.0
FocalPoint 2 2.0.9 (Suite 6)
FocalPoint 2 Filter 2.0.9 (Suite 6)
FocalPoint 2 Hidden NO VERSION
Fresco 12.0
Glass 12.0
Glowing Edges 12.0
Grain 12.0
Graphic Pen 12.0
Halftone Pattern 12.0
HDRMergeUI 12.0
HSB/HSL 12.0
IFF Format 12.0.2
Ink Outlines 12.0
JPEG 2000 2.0
Lens Blur 12.0
Lens Correction 12.0.2
Lens Flare 12.0.2
Lighting Effects 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Liquify 12.0.1
Matlab Operation 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Measurement Core 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Mezzotint 12.0.2
MMXCore Routines 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Mosaic Tiles 12.0
Multiprocessor Support 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Mystical 2 10.0
Neon Glow 12.0
Nik Selective Tool 2.1.3.17318
Noise Ninja NO VERSION
Noiseware Professional 4.2.0.5
Note Paper 12.0
NTSC Colors 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Ocean Ripple 12.0
OpenEXR 12.0.2
Paint Daubs 12.0
Palette Knife 12.0
Patchwork 12.0
Paths to Illustrator 12.0.2
Pattern Maker 12.0 (12.0x001)
PCX 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Perfect Effects 6.0.0
Perfect Effects Filter 6.0.0
Perfect Effects Smart Filter 6.0.0
Perfect Mask 6.0.0
Perfect Mask Filter 6.0.0
Perfect Mask Smart Filter 6.0.0
Perfect Portrait 6.0.0
Perfect Portrait Filter 6.0.0
Perfect Portrait Smart Filter 6.0.0
Perfect Resize 7.0 Professional Edition 7.0.5 (Suite 6)
Perfect Resize 7.0 Professional Edition Batch 7.0.5 (Suite 6)
Perfect Resize 7.0 Professional Edition Filter 6.0
Perfect Resize 7.0 Professional Edition Format 7.0.5 (Suite 6)
PG-Processor 2.0.0
Photocopy 12.0
PhotoFrame 4.6 Professional Edition 4.6.5 (Suite 6)
PhotoFrame 4.6 Professional Edition Batch 4.6.5 (Suite 6)
PhotoFrame 4.6 Professional Edition Hidden 4.6.5 (Suite 6)
PhotoKit Capture Sharpener 1, 2, 11, 0
PhotoKit Capture Sharpener 2 2.0.4
PhotoKit Capture Sharpener Expert 1, 2, 11, 0
PhotoKit Creative Sharpener 1, 2, 11, 0
PhotoKit Creative Sharpener 2 2.0.4
PhotoKit Output Sharpener 1, 2, 11, 0
PhotoKit Output Sharpener 2 2.0.4
PhotoKit Preview Helper 2.2.2
PhotomergeUI 12.0 (12.0x001)
PhotoTools 2.6 Hidden NO VERSION
PhotoTools 2.6 Professional Edition 2.6.3 (Suite 5.5.3)
PhotoTools 2.6 Professional Edition Batch 2.6.3 (Suite 5.5.3)
PhotoTune 3 3.0.8 (Suite 5.5.3)
PhotoTune 3 Batch 3.0.8 (Suite 5.5.3)
PhotoTune 3 Filter 3.0.8 (Suite 5.5.3)
Picture Package 12.0 (12.0x001)
Picture Package Filter 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Pinch 12.0.2
Pixar 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
PixelGenius Toolbox 2.2.6
Plaster 12.0
Plastic Wrap 12.0
PNG 12.0.2
Pointillize 12.0.2
Polar Coordinates 12.0.2
Portable Bit Map 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Portrait Professional 1, 4, 1, 0
Poster Edges 12.0
Radial Blur 12.0.2
Radiance 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Read Watermark 4.0
Reticulation 12.0
Ripple 12.0.2
Rough Pastels 12.0
Save for Web & Devices 12.0
ScriptingSupport 12.0.4
SGI RGB 12.0 (12.0x20100407 [20100407.r.1103 2010/04/07:14:00:00 cutoff; r branch])
Shear 12.0.2
Smart Blur 12.0.2
Smudge Stick 12.0
SoftImage 12.0 (12.0x20100407 [20100407.r.1103 2010/04/07:14:00:00 cutoff; r branch])
Solarize 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Spatter 12.0
Spherize 12.0.2
Sponge 12.0
Sprayed Strokes 12.0
Stained Glass 12.0
Stamp 12.0
Sumi-e 12.0
Targa 12.0.2
Texturizer 12.0
Tiles 12.0.2
Topaz Adjust 5 10.0
Topaz BW Effects 10.0
Topaz Clean 3 10.0
Topaz DeNoise 5 10.0
Topaz InFocus 10.0
Topaz ReMask 3 10.0
Topaz Star Effects 10.0
TopazRemaskAutomate NO VERSION
Torn Edges 12.0
Twirl 12.0.2
Underpainting 12.0
Vanishing Point 12.0
Variations 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Viveza 2 2.0.2.10710
VueScan 1.0.00
Water Paper 12.0
Watercolor 12.0
Wave 12.0.2
Web Photo Gallery 12.0 (12.0x001)
WIA Support 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
Wind 12.0.2
Wireless Bitmap 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
ZigZag 12.0.2
Plug-ins that failed to load: NONE
Flash:
onOne
Flash
Mini Bridge
Access CS Live
CS News and Resources
Flash
Kuler
CS Review
Installed TWAIN devices: NONE
Tomorrow I can. I'm no expert at Photoshop but I know may way around a Computer. There is a version on the network drive now that was downloaded this morning. I believe it is the one that produced the errors. There is also one downloaded a few days ago that seems to me to be identical. The first one only installed into Programs (x86) and showed non fatal errors. There was no 64 bit version in Programs so I guess both files are probably identical.
I've rolled back the PC to an earlier version and run some registry cheching on it. No errors but I did find an unauthorised (by the company) malware rmonitoring program. I've deleted that and removed a couple of other redundant programs. I'm satisfied the PC has no software on it that was not there when Photoshop Lightroom 4.01 RC was installed a week ago. That has installed in the 64 bit folder.
Do you want me to use one of these existing downloads or get a fresh copy?
Margie
To be safe, you should go to the site listed below and download the file. Extract it from the zipped folder and install it. You will get 32 and 64 bit installed unless you specify otherwise. Unless there are special circumstances on your system, it should install and run. Be sure not to point your plugins to the CS5 plugins, which is a common mistake people make. Let us know how it goes!
Pattie
Try following the below mentioned steps:
1) Reboot your system
2) Re-download the installer, Unzip the installer using winzip or winrar
3) Run the the set-up.exe by using clicking on the right mouse button and choosing Run As Administrator.
Please let me know if it helps, Otherwise I will setup a connect session to resolve the issue.
Ashutosh
I followed your instructions and got the same results as before.
The failure log is the same size as previous one I sent you.
Perhaps if you have the DL software on a different server or an Australian server I can get it from there and try again?
My reading of the errors leads me to believe the downloaded file might be corrupt or missing data.
I used winrar to unzip the files.
You are certainly welcome tosetup a connect session if you feel you can accomplish the installation. Keep in mind we are in time zone GMT +10 hours. I can give you access between 10:00am and 5:00pm (GMT+10 hours).
