This discussion is locked
J0elamite
I get Exit code 15  issue on CS installation, should I use the CS6 Cleaner Tool?
Apr 8, 2012 8:23 PM
Tags: #error #install
Upon startup the CS6 Beta would pop up the error that the sniffer_gpu.exe stopped working, and would not open.  I updated my graphics card drivers suspecting an OpenGL issue, but that didn't solve my problem.
I then uninstalled CS6 via the control panel, and attempted to reinstall hoping that would fix things, but 2% into the process the installation fails with the following error:  Inconsistency in the installer database - please restart your computer and install again.
There is a link to an error summary file, which reads:
Exit Code: 15
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 0 error(s), 0 warning(s)
I have restarted and retried the process several times after cleaning the registry with the same results.
Does the normal Creative Suite Cleaner work for this release?  I haven't run it to find out as I have CS5.5 installed, and would rather not screw that one up as well.
Thanks for any help I can get.
Joel
    Apr 8, 2012 10:12 AM   in reply to J0elamite
    I just saw this in another post earlier today. https://www.adobe.com/support/contact/cscleanertool.html
    Apr 8, 2012 4:14 PM   in reply to J0elamite
    J0elamite wrote:
    …I have not run it yet because it does not mention CS6 specifically as one of the versions it "cleans", and I would rather not "clean" my current install of CS5.5.
    Very wise decision!
    Stay the heck away from that Cleaner Tool.  From the above link:
    The Adobe Creative Suite Cleaner Tool helps resolve installation problems for Adobe Creative Suite 5 - 5.5, Adobe Creative Suite 4, and Adobe Creative Suite 3 software. The tool can clean up install records for any pre-release (beta) installations of these Creative Suite products.
    Apr 8, 2012 10:33 PM   in reply to J0elamite
    We are tracking this issue at: http://forums.adobe.com/thread/978912?tstart=30.
    I will lock this particular thread and forward your issue to the installation guys . They will check the link above for your information and get back to you there.
    I suggest you copy your issue there and an intstallation expert can help determine if the cleanter tool is appropriate for your situation.
    Please note whether it is a MAC or PC and what OS you are running.
    Thanks and sorry you are having issues.
    Pattie
