Hi all,
I have a swf doing some javascript calls. It works fine if the swf object is embeded as part of html. When creating it thru javascript, the code doesn't work. I've tried back &forth for a while, no luck. attached my code snippet below, can someone give me an idea on what might work?
TIA -s
/* javascript */
<script language="javascript">
var g31=false,g32=false,g33=-1,g1=-1;
function f31(p){
alert(p)
function f34()
g31=true;
g33>=0&&(window.clearTimeout(g33),g33=-1);
//alert("f34:g31="+g31+";g32="+g32);
if(g32){
var a=f37();
a&&(a.f34())
return
g33=window.setTimeout(f34, 100);
function f35()
// alert("f35:g31="+g31+";g32="+g32);
g32=!0;
function f36()
// alert("f36:g31="+g31+";g32="+g32);
return g31;
function f37()
if (navigator.appName.indexOf("Microsoft") != -1)
return window["testswf"];
else
return document["testswf"];
(function(){
var f0=function(){
g31=true;
f34();
var f00=function(){
g1&&(window.clearTimeout(g1),g1=-1);
if(!document.body)
g1=window.setTimeout(f00, 100);
return
var swf="<object classid='clsid:d27cdb6e-ae6d-11cf-96b8-444553540000'";
swf+="codebase='http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0'";
swf+="width='215' height='318' id='testswf' align='middle'>";
swf+="<param name='allowScriptAccess' value='always' />";
swf+="<param name='allowFullScreen' value='false' />";
swf+="<param name='movie' value='testswf.swf' />";
swf+="<param name='quality' value='high' />";
swf+="<param name='wmode' value='transparent' />";
swf+="<embed src='testswf.swf' quality='high' wmode='transparent' width='215' height='318' name='testswf' align='middle' allowScriptAccess='always' allowFullScreen='false' type='application/x-shockwave-flash' pluginspage='http://www.adobe.com/go/getflashplayer' /></object>";
var a=document.createElement("div");
a.innerHTML=swf;
f0();
f00();
</script>
/*as3 */
import flash.external.ExternalInterface;
flash.system.Security.allowDomain("*");
startTest();
function f0():void {
ExternalInterface.call("f31", "one");
function timerHandler(event:TimerEvent):void
if (isContainerReady())
Timer(event.target).stop();
setupCallbacks();
function startTest():void
if (ExternalInterface.available)
try
setupCallbacks();
else
var readyTimer:Timer = new Timer(100);
readyTimer.addEventListener(TimerEvent.TIMER, timerHandler);
readyTimer.start();
catch(error:Error) {
trace("An Error occurred: " + error.message + "\n");
else
trace("External interface is not available for this container.");
function isContainerReady():Boolean
var result:Boolean = ExternalInterface.call("f36");
return result;
function setupCallbacks():void
ExternalInterface.addCallback("f34", f0);
ExternalInterface.call("f35");
