Flash player download timeout at 47%
Apr 8, 2012 4:44 PM
Flash player failed on me, I can't attribute it to any specific reason at the time.  Any application that needs flash shows blank, no sound, vision or that I
need to download flash player.
Subsequently removed and reinstalled 11.2.202.228, and get the download timeout at 47% of installation.  Have tried a few times and get the same issue, also with earlier versions 11.1.102.63
& 10.3.183.15.  On attempting manual installation, it appears to install completely, however, I go back to the original issue on the first line above.
Have just completed a full scan for any malware, spyware, virus, etc. and come up with nothing.
Specs:  Vista 6 SP2, Firefox 11, 32-bit, but also failed with IE7 (in a desperate attempt to resolve the issue!)
    Apr 8, 2012 5:10 PM   in reply to Fox_HT
    Can you give a little bit more detailed symptoms than just "failed"?
    Also, what is your display adapter, driver version & date?
    Apr 8, 2012 8:52 PM   in reply to Fox_HT
    Can you try a clean install, as follows:
    1. Download the current uninstaller
    2. Close all browser windows and run the uninstaller
    3. Restart Windows
    4. Delete all remaining files and folders located in the following directories.  (tip: copy and paste these paths into the path bar in an Explorer window)
      • C:\Windows\system32\Macromed\Flash
      • C:\Windows\SysWOW64\Macromed\Flash (if it exists)
      • %appdata%\Adobe\Flash Player
      • %appdata%\Macromedia\Flash Player
    5. Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32\ for 32 bit systems or C:\Windows\SysWOW64\ if you are using a 64 bit system, has been deleted
    6. Download and run the offline installers
    If the problem persists, can you go to http://www.intel.com/p/en_US/support/detect and check if there are newer device drivers available for your display adapter?
    Apr 8, 2012 9:55 PM   in reply to Fox_HT
    Great; glad it was so easy!
    Apr 12, 2012 8:11 AM   in reply to Pat Willener
    Hi Pat:
    I just went through a long song and dance trying to get Adobe Flash up and running again.
    My son has a new computer, and after only 4 days of use, some update came along and changed something, and he tried to update//install flash so that he could play YouTube videos.  He followed the instructions, and things blew up, with the "stuck at 47% problem".
    I came along and made several attempts, but didn't fare any better.  Googled, and discovered the information that you had put up in this forum, and made 3 more failed attempts, in spite of following your directions...  :-(
    Then, this morning I had a flash (sic :-) ), and went and looked for failed 32 bit stuff...  And discovered some, and cleaned it out.  The next install of the 64 bit went fine.
    I am suggesting that you add instructions to clean out both the 32 bit system files and the 64 bit systems...
    Thanks, wasn't fun, but I am glad to be done,
    Warren
  • Chris Campbell
    May 4, 2010
    Apr 12, 2012 11:35 AM   in reply to WarrenLongGmail
    Hi Warren,
    For what it's worth, the original poster on this thread had said he was on a 32 bit system, so I suspect Pat modified the instructions a little bit for 32 bit.  The FAQ for this does cover both 32 and 64 bit
    How do I do a clean install of Flash Player?
    Regardless, very glad to hear you were able to figure it out and get Flash Player installed!
    Apr 12, 2012 8:21 PM   in reply to Chris Campbell
    P.S. the reason why I (and Carl as well) place the instructions directly into the forum topics, rather than referring to the FAQ, is that the FAQ entry does not contain the download links to the offline installers.  We know why these links are not there, but we need to supply these links, as most users with FP install problems are more likely to succeed with the offline installers.
    Nov 27, 2012 8:49 AM   in reply to Pat Willener
    Hello. I'm having the same problem as Fox was. I've tried turning off my antivirus, a clean install, and a clean install with my antivirus off, but it still times out at 47% every time. I'm running Windows 7 64-bit. Display adapter is Intel(R) HD Graphics Family. Version 8.15.10.2353 dated 4/4/2011. Any assistance would be appreciated. Thank you for your time.
    Nov 28, 2012 12:07 AM   in reply to Argus95
    Could you please download Flash Player from the following link: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#main-pars_header
    After downloading, close all browsers and double-click the downloaded file.
    Sunil
    May 3, 2013 9:17 AM   in reply to Pat Willener
    Your 32 bit uninstaller link gives 404 error message.  Can you update?
    May 3, 2013 7:23 PM   in reply to 1stused
    This topic is more than one year old; there is no longer a 32-bit uninstaller.
    Use http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
