Dynamically embedded swf with externalInterface calling
Guest
Apr 08, 2012 Apr 08, 2012
Hi all,
I have a swf doing some javascript calls. It works fine if the swf object is embeded as part of html. When creating it thru javascript, the code doesn't work. I've tried back &forth for a while, no luck. attached my code snippet below, can someone give me an idea on what might work?
TIA -s
/* javascript */
<script language="javascript">
var g31=false,g32=false,g33=-1,g1=-1;
function f31(p){
   alert(p)
function f34()
g31=true;
g33>=0&&(window.clearTimeout(g33),g33=-1);
//alert("f34:g31="+g31+";g32="+g32);
if(g32){
     var a=f37();
  a&&(a.f34())
    return
g33=window.setTimeout(f34, 100);
  function f35()
// alert("f35:g31="+g31+";g32="+g32);
  g32=!0;
function f36()
//  alert("f36:g31="+g31+";g32="+g32);
  return g31;
function f37()
    if (navigator.appName.indexOf("Microsoft") != -1)
         return window["testswf"];
       else
        return document["testswf"];
(function(){
     var f0=function(){
       g31=true;
       f34();
   var f00=function(){
    g1&&(window.clearTimeout(g1),g1=-1);
    if(!document.body)
     g1=window.setTimeout(f00, 100);
     return
       var swf="<object classid='clsid:d27cdb6e-ae6d-11cf-96b8-444553540000'";
      swf+="codebase='http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0'";
      swf+="width='215' height='318' id='testswf' align='middle'>";
      swf+="<param name='allowScriptAccess' value='always' />";
            swf+="<param name='allowFullScreen' value='false' />";
            swf+="<param name='movie' value='testswf.swf' />";
               swf+="<param name='quality' value='high' />";
               swf+="<param name='wmode' value='transparent' />";
               swf+="<embed src='testswf.swf' quality='high' wmode='transparent' width='215' height='318' name='testswf' align='middle' allowScriptAccess='always' allowFullScreen='false' type='application/x-shockwave-flash' pluginspage='http://www.adobe.com/go/getflashplayer' /></object>";
     var a=document.createElement("div");
      a.innerHTML=swf;
      f0();
    f00();
</script>
/*as3 */
import flash.external.ExternalInterface;
flash.system.Security.allowDomain("*");
startTest();
function f0():void {
ExternalInterface.call("f31", "one");
function timerHandler(event:TimerEvent):void
    if (isContainerReady())
         Timer(event.target).stop();
         setupCallbacks();
function startTest():void
   if (ExternalInterface.available)
        try
               setupCallbacks();
            else
                var readyTimer:Timer = new Timer(100);
                readyTimer.addEventListener(TimerEvent.TIMER, timerHandler);
                readyTimer.start();
        catch(error:Error) {
   trace("An Error occurred: " + error.message + "\n");
    else
        trace("External interface is not available for this container.");
function isContainerReady():Boolean
    var result:Boolean = ExternalInterface.call("f36");
    return result;
function setupCallbacks():void
    ExternalInterface.addCallback("f34", f0);
    ExternalInterface.call("f35");
ActionScript
569
Guest
added document.body.appendChild(a); added space at the beginning of each line of swf object.
still not working
